Question about Tools & Hardware - Others
I have a 6 volt tractor battery. Will the 25AMP Smart fully automatic charger work on 6 volts?
  • 1,169 Answers
Most likely not as most of the automatic chargers are setup for 12V only. You need look at specs on the charge that interested in to find this this info.
Posted on Nov 27, 2014
clyde2j2
  • 137 Answers
SOURCE: Black & Decker 24 volt battery will not hold a
I had the same problem, the batteries are burned out, I know you can replacements at Home Depot but if you can wait try the interenet.
"Google" what you want.
Posted on Mar 02, 2009
  • 360 Answers
SOURCE: the light don't come on and want charge my 12 volt battery
My charger has a fuse located on the circuit board inside the unit....when mine stopped working, it was the fuse...replaced it and it is working fine for one battery, the other blows the fuse every time....bad battery.
Posted on May 20, 2009
venexcsd
  • 1185 Answers
Click on the link below and you will find replacments
You need to work out if the cost of two batteries is cheaper than a deal on a new drill pack
http://www.svcvacuum.com/black_and_decker/black_and_decker_battery.htm
Posted on Jun 01, 2009
  • 20 Answers
SOURCE: My Black and Decker Firestorm 24 volt charger is not working
change batteries, your charger should indicate wheather you battery is good or noot on the pause inbetween blinks.
Posted on Aug 15, 2009
farmerbear
  • 490 Answers
SOURCE: will m 24 volt batt
Nope. It takes a different charger.
Farmerbear at FixYa.com
Posted on Sep 11, 2010
What volt charger do i need to charg mower 12volt battery?
Doug, Any 12 volt automotive charger will work for your lawn tractor, the cheaper no frills chargers will work fine.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Battery Chargers Canadian Tire
Amazon com Battery Chargers Jump Starters Battery Chargers Portable Power...
Car Battery Chargers
Feb 27, 2016 | Cub Cadet Garden
CAN YOU LEAVE A RECHARGEABLE BATTERY FOR A 19.2 VOLT CRAFTSMAN CORDLESS DRILL IN THE CHARGER ALL THE TIME/
It depends on the charger taht comes with this drill, the dumb charger will just keep on charging the batteries even when it if fully charge and does not sop, which will be bad for the batteries, the smart charger (more expensive and has electronics inside the charger) will go into floating charge when the batteries are fully charge which will prevent the batteries from being overcharged. If in doubt, remove it from the charger after overnight charging.
Nov 23, 2011 | Drills
Can I use a 8 volt battery on a 6 volt tractor or will it trip the voltage regulator and blcck the generator?
YOU CAN USE AN 8 VOLT BATTERY, IT SHOULDN'T HURT ANYTHING. THE ONLY THING IS IT WON'T STAY FULLY CHARGED. THE GENERATOR IS DESIGNED FOR A 6 VOLT BATTERY NOT 8 VOLTS. WHAT I DO IS CHANGE THE SYSTEM TO 12 VOLTS. NOTHING WILL HAVE TO BE DONE TO THE STARTER, IF THE TRACTOR STARTS LIKE IT IS SUPPOSED TO. IT WILL JUST START FASTER. YOU WILL NEED NEW POINTS & CONDENSER & A RESISTOR FOR THE DISTRIBUTOR. ALSO A 12 VOLT BATTERY & A MID 1970'S INTERNALLY REGULATED ALTERNATOR, MOUNTED IN PLACE OF THE GENERATOR. THIS A LITTLE WORK BUT THE TRACTOR WILL START AMAZINGLY FAST. I HAVE DONE THIS SEVERAL TIMES & IT WORKS GREAT. IF THE FUEL GAUGE STILL WORKS YOU WILL NEED A SPECIAL RESISTOR FOR THAT. OF COURSE ANY LIGHTS WILL HAVE TO BE CHANGED TO 12 VOLT GOOD LUCK. DR. VOLT.
Jan 25, 2011 | Ford Expedition Cars & Trucks
Was advised to put an 8 volt battery in my 6 volt 600, peppped up the starter; worked fine. now generator not working. can a 6 volt generator charge an 8 volt battery? did it for 2 years without...
It won't charge it fully. When you put an eight-volt battery in a six-volt machine you want to adjust the voltage generator to charge at about 9.5 volts. 9.9 will be the outgassing point for an eight-volt battery, if you keep it between the two points I specify you'll be happy.
If you need help with the regulator give me a write back with the 'comments' button and we'll go through the process.
lp
Jan 11, 2011 | Ford Naa 600 800 Tractor Tachometer...
12v 1.5amp fully auto, alwyas worked, hook up to battery 12v 8.5amph, alwys red light flashed, went solid while charging, then off, or flashed, and off cause was already fully charged. now red light just...
I really don't have any idea as to what you're talking about here other than a battery and maybe a charger. Seems as if you're saying that you have a 12 volt 1.5 amp automatic battery charger connected to a 12 volt, 8.5amph battery but the red light on your charger is blinking. The blinking red light indicates that the charger is not seeing a proper connection such as crossed polarity connection or simply a poor connection. You say that the battery voltage has dropped from 12.5 volts to 9.1 volts with the charger connected. If this is the case, the battery is badly discharged and the charger is not charging the battery for some reason. The charger may be bad but check the connections to make certain they are correct and good. If they are, I'd replace the charger.
Good luck
Steve
Aug 10, 2010 | Harley Davidson FXR Super Glide...
How long does it take to fully charge Companion II batteries?
Hi. Always charge your batteries overnight after each use. Do not charge your batteries for days or weeks at a time unless you have a good quality automatic charger.
Most 4 amp chargers, charge the batteries up to approx 28.5 volts, and will maintain this voltage forever if left on. This will eventually shorten the life of the batteries.
The Invacare 8 amp charger is a fully automatic charger. It will take the batteries up to about 28.5 volts, it will hold this voltage for a few hours, and then drop the voltage to 27.6 volts ( 13.8 volts across each battery ). These chargers can be left on for weeks at a time.
Good luck. Neil.
Jun 08, 2010 | Golden Technologies Companion II Travel...
Where can I find a replacement charger for the allegheny ciw114 impact wrench?
If the battery is not damaged or totally dead, you can attempt to charge it with any
24-Volt DC charger. The charging voltage rises to about 28 Volts when nothing is
connected to the charger. You must first connect (with jumper leads) the positive
charger output to the positive battery terminal. Use a test meter to determine the
polarity of the battery. Also test the charger output to determine the polarity. Be
sure to connect positive to positive and negative to negative. Do this before turning
on the power to the charger. If the battery is a "smart" battery; that is with built-in
electronic control circuit, the ordinary charger may not work. Normally, a battery
will accept a charge until it is nearly completely charged and then the battery
voltage will slowly "buck" the charging voltage. When the battery voltage and the
charging voltage are equal, no more charging current will flow. Amperes, that is
coulombs of current, charge the battery; when the battery is at (approximately) 24
volts and the charger is putting out 24 volts, NO current flows. The battery is then
fully charged.
Dec 28, 2009 | Impact Allegheny 1/2'' Drive 24v Cordless ...
Batteries not charging - just replaced with new -amp meter dosent move while plugged in. Old batteries were dead and owners manual says charger will cease to work when batteries die and to contact pride...
1st Check the 25amp inline fuse located behind the volt meter. 2nd Check the 50 amp fuse located behind the foot rest. A pin located under the foot rest when pulled out will open the front to access the fuse.
May 07, 2009 | Jet 3 Ultra Power Chair
Battery seam like it is not charging
Some automatic battery chargers will not charge a REALLY low battery. You really need a volt/ohmmeter to check charging rate.
Should be 13.5--14.4 volts while charging, 12.5 volts for fully charged battery.
Apr 05, 2009 | Craftsman Garden
Tools & Hardware - Others Logo
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
