Question about Hotpoint Ovens
How do I take the knobs off a hotpoint stove
Pulling them off, twisting back and forth, looking to see if there are screws to release the panel
  • 3 Answers
I wrap a thin cotton cloth (like a handkerchief) fully around the underside of knob. Gather the cloth above the knob. Then pull firmly on the cloth. The knob, prviding it is not glued on, should come off
Posted on Nov 27, 2014
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 149 Answers
The knobs should pull off. You may need to use a screwdriver to pry them loose. Sometimes they melt and get mis-shaped.
My oven wont turn off from the knob it keeps turning
You didn't say whether you have a gas or electric oven, or oven & stove. I'll assume you have a stove, just to cover all bases.
First, you should shut down the oven: a gas stove will have a valve on the gas line behind the stove. The valve will either have a red handle or a flat stem that usually has a hole in it. Turn either valve 1/4 turn to shut off gas, use a wrench on the flat stem. An electric stove should be shut off by flipping off the double circuit breaker for it in your electric panel. Do not unplug an electric stove when it is on; this can damage the plug &/or electrocute you.
Most likely the inside of the knob has stripped out. Look at the knob for a hole that has a setscrew in it: a small allen wrench or screwdriver will loosen the setscrew, most knobs don't have them and will pull off. Be careful to use even pressure on two sides of the knob; if you can't pull it off, use two butter knives or flat screw drivers to pry it up enough to get a grip on it.
Look at the center stem on the back of the knob, it will likely be cracked or stripped. Some stems have a D-shaped metal insert that strips out inside the plastic stem. If you have one, pull off a burner knob and compare the stems in the back, if they are the same size, put the burner knob on the shaft for the oven control, and use that knob to turn the oven control off.
If the burner knob won't fit, use your fingers or a pair of pliers (gently) to turn off the oven control shaft. If the shaft stops normally, you can turn the stove back on using either the gas valve or the circuit breaker. If you have a gas stove that doesn't have electric ignition (a clicking noise when you turn on a burner) you may need to re-light the pilots for the burners. Lift the covers off the burners to re-light the pilots.
If you have succeeded in turning off the oven, you need a new knob -- you can get one at an appliance parts store or maybe a hardware store. If the oven control did not turn off normally, I would leave the oven/stove turned off: the control itself will need to be replaced by a qualified repair person.
Mar 03, 2013 | Ovens
My ariston oven won't turn on. The stove works and
check and see if the broil works in the oven ,2 if it turns on meaning the element in the top turns red then this generaly means both side of the switch are good. and you need to replace the element on the bottom of the stove.now turn off the stove .1st unplug the stove. 2nd there are 2 screws at the back of the stove on a metal plate which is attached to the element take them off.3rd gently pull out the element about 3 inches until you see 2 wires. there are 2 ways the wires could be connected either push on or by screws if you dont see a screw abviusly its push on. just grab the end of the wire ON the connecter and grab the elemnt at the connecter and wigglethe connector back and forth while pullin on the connecter. wala. now locate the model number and go to amazon.com or your local parts house and install in reverse
Aug 20, 2012 | Ovens
The glass panel behind the control knobs has shattered can I replace this model is stoves 720ef
The best bet is STOVES for a replacement - if they have one. It is relatively straightforward to replace. With all the buttons and knobs removed, there should be two screws underneath the panel , i.e. pointing upwards at either end of the panel,. The panel will also have two lugs along the top edge that locate into the top off the oven. The panels lugs should be first located into the oven before the screws are inserted. It may be a bit of a struggle but can be done.
Sep 11, 2011 | Stoves 720EF Electric Double Oven
Stoves E2H600- lighting behind fascia panel has gone off so cannot now see what temperature settings are! How do you remove the fascia panel to access and replace defective lighting unit/s? Many thanks,...
A bit involved but quite straightforward.
Open the grill door and you will see 4 screws on the underside of the hob - remove the inner 2.
You can now hinge up the entire hob.
On each side of the hob is a trim piece with 2 screws which retain the glass front panel. Remove these and the end trims.
Carefully pull the timer buttons away from the fascia - the simply click into position.
The glass panel can now be tilted up and removed - it is pocketed at the top.
Each of the control knob assembly can then be easily pulled away from the controls.
The fluorescent tube is situated below the controls in a recess.
Rotate the tube through 90° and lift the tube out.
Refitting is the reverse of the above procedure.
Jun 22, 2011 | Stoves Ovens
How do I fit a new switch to the grill of my Soves electroc oven model no. 059040414 Type 720EF? Have you a manual?
First, a handbook is available, but I will need an email address to send it to you.
TURN THE POWER OFF.
To replace the switch, you have to take the whole oven out of its kitchen furniture housing and then take the top off. ) It is held in place by normal wood screwes) All the knobs on the front panel are pull off/push on and you have to remove them. Once you have the knobs off you have to remove the glass control knob panel. On the lower edge of it at either end you will see two cross head screws going upwards. Remove these. Now the only thing holding this in place are I think three lugs on the top of the glass panel that go up and in to the top of the cooker. With a bit of fiddling, the panel should now come off, leaving you free to access the switch for replacement.
I think you will find that the thermostat pipe will link into the top back of the top oven so this has to be very carefully replaced as well, which additionally may require the back of the oven to be unscrewed.
Best of luck!
Nov 06, 2010 | Stoves 720EF Electric Double Oven
Timer shows F30
I had the same F30 error problem but fixed it. On my professional series Frigidaire, there are 2 resettable red button locations. I discovered that only one is in the rear of the oven. After going to the breaker box and shutting off the power, pull out the stove enough to work, unscrew the rear screws (I didn't unscrew all of them, just enough to work back there). The small red button is on a small black round piece with two purple wires feeding to it. That was not my problem. Mine was the other red button behind the control panel. Pull off all 4 knobs, unscrew by hand the large black rings that are underneath the knobs, pull out the whole panel. Look back and right (below where the right knobs were located) to find the 2nd red small button. Push to reset. Check this one first since it is easier to do.
Nov 04, 2010 | Kenmore Ovens
I would like to know how to adjust the stove so that it sits level ?
Most stoves of this type have both wheels and screw adjusted levellers (generally in the front only).
The lower drawer opens to reveal these in the corners or a loose clip-on front panel needs to be removed by gentle pulling. The knurled wheel like knobs are generally turned anti-clockwise (Right to Left as you face the stove) to screw out and thereby lift the stove front up to suit your requirements. Good Luck.
Sep 16, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Two scews have fallen out from behind the back right knob. Now the knob will not turn. What's the best way to get the screws back in place to make the knob work?
unplug or disengage power to machine,remove knob by pulling steadily towards you,practice first on a functional knob or switch to gauge the "feel" of removal and reinstallation.. if possible screws can be reinstalled by grasping the shaft of switch w/needlenose pliers to help line up screw holes if working from front.if cant line up holes that way,remove rear panel to line up screws by grasping switch by hand from behind console panel.knob must be removed to reinstall the screws
Nov 13, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Amana gas stove acf3325ac f2 code
HI The range timer is usually located in the control panel on top of the range. If you suspect the timer is faulty, don't try to fix it yourself. Remove it and take it to a professional service person for testing. Here's how to remove the timer:
Step 1: Remove the back service panel to the control panel and release the spring clips that hold it in position, or remove the retaining screws.
Step 2: Push the timer forward to release it.
Step 3: Remove the electrical lead wires from the timer housing. If, when disassembling the timer, you notice that the electrical wire terminals look burned, remove these leads and buff the leads and the terminal points with fine steel wool. Burned and/or dirty terminals can cause the timer to malfunction, but a good cleaning can solve this problem.
Step 4: Replace the old timer or install a new one of the same size and type, if this is necessary. Connect the new timer the same way the old one was connected.
PLEASE RATE IT............................
Nov 16, 2008 | Amana Ovens
Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Nov 23, 2007 | GE Profile JKP18 Electric Single Oven
Ovens Logo
138 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
ashburton
 Fix Your Board
Fix Your Board
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
