Question about Dometic CF-050AC110 CF-50 Waeco CoolFreeze Portable Fridge Freezer AC/
I have a dometic fridge freezer in our motorhome, rapido 7099+ it works on all 3 modes but when on gas it ommits a very obnoxious smell into the van, I have had the fridge serviced when it was found t
Dometic 7655L fridge freezer serviced which lasted about 3 weeks, operates on electric no problem
  • Dometic Master
  • 3,382 Answers
It sounds like a exaust flu leak, do not use it in that mode until it is fixed, it will kill you.
Posted on Nov 27, 2014
  • 51 Answers
SOURCE: FRIDGE WILL NOT IGNITE IN GAS MODE
The part you are looking for is the thermo couple. It senses the heat from the flame and holds the gas valve open. The clicking will try three times and then go into lock out. You then will need to reset on the front of the fridge. When installing the thermo couple do not over tighten.
Posted on Sep 07, 2008
  • 68 Answers
SOURCE: Dometic Americana Freezer/Fridge not cooling
The recall has nothing to do with your fridge not working. Your cooling unit has gone bad. And yes you can get a new fridge for a few hundred more than a new cooling unit. And sooner or later PPL motorhomes will run out of their cheap stock. The fridges they have are out of production. I know I am a Dometic dealer.
Posted on Mar 19, 2009
  • 68 Answers
SOURCE: Dometic rm 2612. Shuts down on gas.
Ron;
Check the burner assembly. 1 screw, remove the sheet metal cover and clean it. The burner collects rust. This is the likely. Other issues would be the gas pressure usually checked with a manometer. Should 11" of water column. If your furnace works good then the gas pressure is probably ok. Also could have a faulty ignitor which sends a miliamp signal back to the circuit board. Check the burner first, after that leave the cover off and turn the fridge on. Watch the ingnitor attempt to lite the burner. Be sure the spark is going to the burner and not shorting out on the sheet metal it is mounted in. If it is shorting to the frame the ignitor needs replacing.
Thanks for using Fixya
Jerry
Posted on Mar 31, 2009
  • 3 Answers
SOURCE: Freezer working, fridge isn't.
It is possible that your cooling unit is failing due to a blockage. The solution used to cool starts at the top of the fridge and works its way to the bottom. If there is a blockage in the cooling unit it could produce the symptom you have explained.
Posted on Jul 06, 2009
VtToolMan
  • 704 Answers
SOURCE: Dometic rv fridge runs fine on elec, lights on gas
It is key that all control switches are in the correct position, depending on what power source you are using, gas, electric, etc. If the switches are not in the proper setting, the unit will not operate.
Here's the manual for your fridge that should be printed out for your use and reference (and reading enjoyment). It has all the info needed to operate and troubleshoot it.
Typically, when using any gas appliance with a pilot light, the sensor has to first be hot enough to trigger it to allow the safety gas shutoff to open and allow the gas to flow to the pilot/burner. Follow the instructions and you should be all set.
http://gasrefrigeration.net/dom_techdata/2707_2811SM.PDF
Hope you find this helpful and best regards!
Posted on Jul 30, 2009
Fridge not working on gas at night
You may need to put a heating blanket on the LP tank, the temperature determines the amount of pressure on the tank and when the temp drops you lose propane pressure thus no ignition and a lockout alarm.
Apr 21, 2014 | Refrigerators
My Dometic RM2652 fridge suddenly quit cooling. No amonia smell, no yellow residue around cooling unit. Gas ignites, lites work.
what is the yellow residue around heating element? my fridge just isnt working right and sometimes stops all together, the freezer worked until lastnight but fridge hasnt cooled right for a week or so.
Aug 03, 2012 | Dometic RM2652 Refrigerator
I have a dometic rm 4605 aes fridge in my motorhome priblem is wont work on gas can not hear auto ignition spark when turned to gas works ok on 12v & 240v
G'day I have a Dometic RM4605,184LT FRIDGE, AES what setting on gas would you have the fridge set. Settings are between 1 to 5 for max cold in the fridge I did run the fridge for two hours on number 4 setting but it was still 10 degrees in the fridge and -0 in the freezer.
Thanks
Jan 23, 2011 | Dometic Refrigerators
I just replaced the converter in my motorhome and everything works but the fridge won't work on house electricity, only gas ???
The old converter may have blown out the control board for your 'fridge. This is quite common if the voltage exceeds 15.5 volts, and when there is a ripple voltage (AC voltage component) riding on top of the DC voltage.
Gas / LP mode is the default for this fridge, a fail safe mode.
You can find the service manual for your fridge here.
Jul 08, 2010 | Dometic RM2652 Refrigerator
We have a 3 way Dometic fridge in our caravan. Have lived in the van for last 12 months ( grey nomads) have had no probs until trip home this week from Yulara to Victoria. Pulled up at night and freezer...
Temperature does play a big part in the efficiency of the fridge. The condenser at the back of the fridge needs cool air flow to allow gas vapour to be converted back into a liquid.again.
Nov 12, 2009 | Dometic RM2652 Refrigerator
I have a Dometic fridg in my 2005 motorhome and when I start my f
You need to unpush the gas button on the front control. If the gas button is pushed in, then it is trying to run on gas and with the tank empty, it is unable to light. That is why the check light is coming on. If you turn the gas side off and have it on auto, it should switch to the AC side and work fine.
Hope this helps,
Jeff
Jul 05, 2009 | Dometic RM2652 Refrigerator
Dometic RM2607
It sounds like the thermocouple is either faulty or incorrectly installed. In other words the sensor bulb may be very slightly to far away from the flame to get sufficient temperature to keep the gas flowing. This is a safety device to cut off gas supply should the flame blow out. But if you are parked at a bit of an angle, the flame will also angle away from the sensor, causing it to shut off gas supply. With regards the freezer being temperamental, this is a strange one, because on this model of fridge/freezer, the actual cooling starts from the freezer coil and ends in the fridge. Try to check the thermocouple first. Also be sure there is nothing obstructing the flame.
Apr 15, 2009 | Refrigerators
Jan 11, 2009 | Dometic RM2852 Refrigerator
Rv fridge problems
have a dometic rm2852 fridge . does not switch over from 110 volt to gas automaticlly. it will click but not ignite. can you help?
thanks
Jul 09, 2008 | Dometic RM2652 Refrigerator
Dometic CF-050AC110 CF-50 Waeco CoolFreeze Portable Fridge Freezer AC/ Logo
199 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
