Question about Wingscapes WSCA02 Digital Camera
How do i read the display
What does 0000/2009 indicate
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Wingscapes Master
  • 884 Answers
Hi
I have had a look at the manual, which can be seen here:-
http://www.naturecounters.com/catalog/birdcams_userguide_lo.pdf
and downloaded if required.
I also assume that the screen you quote 0000/2009 from looks like this: how do i read the display - 25298386-zaroub1mziznni4k1xdwqerx-3-0.jpg and although not clearly explained in the manual (at least during my quick perusal) my previous experience of other cameras makes me think that this is related to the photographs taken by the camera and stored on the SD card, and the number of photographs can still be stored on the SD card according to the resolution the camera has been set to.
In your case I would say you had no photos on your SD card with space available for 2,009 more at the resolution set.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Posted on Nov 27, 2014
DVD loaded. Display indicates 'reading' but then why does it indicate 'no disk'?
The DVD could be for a different region or the player may simply be unable to read it.
Sep 19, 2015 | Sansui VRDVD4005 DVD Player/VCR
The display indicates "brew unit
Remove brew unit and check lever for microswitch at the top back of the machine, the lever might be broken or the micro switch is damaged and cannot read the brew unit when it is inserted.
Apr 18, 2011 | Saeco Incanto Classic Espresso Machine
Air temp indicator only reads temps below 50 degrees
Ambient air temp sensor could be the cause. Normally located in front grille area.
Oct 06, 2017 | 2002 Chevrolet TrailBlazer
My washer display read 'sud'. I turned off the ma...
Hello,This typically indicates slow drain condition. Check for any clogs or kinks in the drain line. Also check that the pump is not clogged and that no pump impeller blades are missing/broken and that the impeller moves freely. Any broken/missing blades or if the impeller won't turn freely will indicate a faulty pump. Hard objects can sometimes make it to the pump and cause damage.
Thanks
May 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Speedometer error?
Many cars have an error on the speed indicated. 10% sounds quite high, next time you buy tyres go for one size bigger or the next profile up, eg, if you are using 70 series go to 75 or 80. That will sort your problem out and you will get better fuel consumption. You can have the speedo calibrated but I would thing that the cost or effort wonuldn't justify the result.
Feb 27, 2010 | 2002 Toyota Camry
1998 Nissan maxima ABS light is on
0) url = inUrl tWindow = window.open(url, '_notes', 'toolbar=no,location=no,status=no,menubar=no, scrollbars=yes,resizable=yes,width=650,height=400') setTimeout('toolbarFocus()',500) } // --> ence blnk_spc.gif g_angle.gif blnk_spc.gif blnk_spc.gif "); msg.document.writeln("" + Title + ""); msg.document.writeln(""); if (ImgMap == "NONE") { msg.document.writeln(""); } else { msg.document.writeln(MapVar); msg.document.writeln(""); } msg.document.writeln(""); msg.document.close(); setTimeout("msgFocus()",250); } function SizedForPrint(ImgName, ZoomPct, W, H, Target, Title, ImgMap, MapVar) { msg=window.open("",Target, "toolbar=yes,directories=no,scrollbars=yes,status=no,resizable=yes,menu=no"); msg.document.writeln(""); msg.document.writeln("" + Title + ""); msg.document.writeln(""); if (ImgMap == "NONE") { msg.document.writeln(""); } else { msg.document.writeln(MapVar); msg.document.writeln(""); } msg.document.writeln(""); msg.document.close(); setTimeout("msgFocus()",250); } function SplitImagePiece(ImgName, ZoomPct, W, H, Target, Title, ImgMap, MapVar) { W = Math.floor(W * ZoomPct); H = Math.floor(H * ZoomPct); msg=window.open("",Target, "toolbar=yes,directories=no,scrollbars=yes,status=yes,resizable=yes,menubar=yes,location=yes"); msg.document.writeln(""); msg.document.writeln("" + Title + ""); msg.document.writeln(""); if (ImgMap == "NONE") { msg.document.writeln(""); } else { msg.document.writeln(MapVar); msg.document.writeln(""); } msg.document.writeln(""); msg.document.close(); setTimeout("msgFocus()",250); } // --> blnk_spc.gif
  1. Connect diagnostic read-out tool to SMEC connector, then disconnect the speed sensor connector and ensure there are no pushed out or damaged terminals. Repair damaged terminals, then proceed to Test 38.
  2. If there are no damaged terminals, set diagnostic read-out tool to ``Read Sensor Values,'' and select ``Vehicle Speed.'' Connect a jumper wire at between black/light blue and white/orange wires of speed sensor connector. While reading diagnostic read-out tool, make and break jumper wire. If display reads any speed above 0 mph, replace speed sensor, then proceed to Test 38.
  3. If display reads 0 mph, turn ignition switch Off and disconnect 60-way connector from SMEC. Ensure there are no pushed out or damaged terminals. Repair damaged terminals, then proceed to Test 38. If there are no damaged terminals, proceed to step 4.
  4. With sensor disconnected, connect ohmmeter between 60-way connector terminal No. 67 and ground. If ohmmeter shows continuity, proceed to step 6. If ohmmeter does not show continuity, move meter lead from ground to white/orange wire of speed sensor connector.
  5. If ohmmeter indicates continuity, proceed to step 7. If ohmmeter does not indicate continuity, repair white/orange wire of 60-way connector for open circuit, then proceed to Test 38.
  6. Disconnect bulk head connector to instrument panel. If ohmmeter still indicates continuity, repair white/orange wire for a short to ground in harness, then proceed to Test 38. If ohmmeter does not indicate continuity, repair white/orange wire for a short to ground in instrument cluster area.
  7. Disconnect ohmmeter leads and connect ohmmeter between 60-way connector terminal No. 4 and sensor connector black/light blue wire. If ohmmeter does not indicate continuity, proceed to step 8. If ohmmeter indicates continuity, replace SMEC, then proceed to Test 38.
  8. If ohmmeter did not indicate continuity, repair black/light blue wire of speed sensor harness for an open circuit, then proceed to Test 38.
blnk_spc.gif _uacct = "UA-1870158-7"; urchinTracker();
Sep 24, 2009 | 2002 Nissan Maxima
Reset the oil indicator on a 2000 Toyota Rav4?
while you have the odometer reading current total mileage turn the key on while holding down the black button that switches from trip odometer to total mileage and you will see dashes where the odometer numbers are displayed. hold down the button until all the dashes disappear. then the display will read zeros when complete
Apr 22, 2009 | Toyota RAV4 Cars & Trucks
2003 F-250 instrument cluster...
it sounds like you are getting a surge of voltage from your alternator/generator. Very strange.
the dealer can run a diagnostic test & pull fault codes or you can try this. If this helps, please report back & rate as fixya. Thanks. I am curious what you find as root cause. Good luck.
Instrument Cluster Self-Diagnostic Mode
To enter the instrument cluster self diagnostic mode with the engine off, depress and hold the odometer reset button. Turn the ignition switch to the RUN position and hold until the gauges sweep (within five to eight seconds). Depress the reset button once to advance to each stage of the self-test.
Turn the ignition to the OFF position to exit the instrument cluster self-diagnostic mode. If no DTCs related to the concern are retrieved, proceed to the Symptom Chart to continue diagnostics.
Instrument Cluster Self-Diagnostic Mode Odometer display Description GAGE Carries out gauge sweep of all gauges, then displays the present gauge values. Also carries out the check sum test on ROM and EEPROM. All segments illuminated. Illuminates all odometer segments. bulb Illuminates all micro-controlled lamps and LEDs. r #### Returns to normal operation of all micro-controlled lamps and LEDs and displays hexadecimal value for ROM level (used when requesting assistance from the hotline). nr#### Displays hexidecimal ROM level and type as stored in non-volatile memory (NVM). EE ## Displays hexadecimal value for EE level (used when requesting assistance from the hotline). dt #### Displays hexadecimal code for the final manufacturing date. ###C Gas engines display last temperature gauge input value from SCP, temperature gauge will indicate present temperature. Diesel engine displays present temperature analog/digital input in decimal as a ratio, temperature gauge will indicate present temperature. dtc #### Displays a 16 bit DTC in hexidecimal format. DTCs displayed are those detected in continuous operation not during self-test. EnG Displays English speed value being input, speedometer will indicate present speed. m Displays metric speed value being input, speedometer will indicate present speed. tAc Displays the tachometer value being input to the instrument cluster. Tachometer will indicate present rpm. FUEL Displays the present analog/digital fuel level being input to the instrument cluster as a ratio. OIL Displays the last analog/digital reading of the oil pressure switch contact resistance, oil gauge will indicate present level. br Displays the brake fluid level in an analog/digital ratio value. bAt ##.# Displays present battery analog/digital voltage. rhEo Displays present hexadecimal pulse width modulation (PWM) dimming input. rhi, rhS, rho Alternating 1 second display of pulse width modulation (PWM) input duty cycle, SCP hexidecimal dimming step, output driver counts in hexadecimal. Cr RUN/START sense circuit check. PA, Pb, PC, and Pd Displays 8-bit hexadecimal value for the Port A, B, C, and D readings (used when requesting information from the hotline). PE0-PE7 Displays 8-bit hexadecimal value for the Port E0-Port E7 in analog/digital readings
Jan 26, 2009 | 2003 Ford F250 Super Duty Crew Cab
DVD display indicates "no disc"
Try a lens cleaner cd, as when the lens gets misaligned or if it's quite old, it will find it harder to read a DVD as the tracks are much closer together than that of a VCD as they are cd's and their tracks are wider apart and easier to read.
Jan 11, 2007 | Sony Multi-System Mini Hi-Fi system /DVD...
Wingscapes WSCA02 Digital Camera Logo
35 people viewed this question
Top Wingscapes Cameras Experts
Are you a Wingscapes Camera Expert? Answer questions, earn points and help others
