Question about Kenmore Elite Oasis 27052 Top Load Washer
My machine does not have a error code issue but i just change then board because it would not turn on but my is that it will not agitate when it is on wash but fills up then it empty.s right after and
Nothing but replacd the bord because it did not work the machine does drain and spins and fills up but does not wash thank you
  • Kenmore Master
  • 3,368 Answers
You might get a service tech or a new unit, you will have more in it then what it is worth.
Posted on Nov 27, 2014
3 Suggested Answers
duby1990
  • 367 Answers
SOURCE: washing machine will fill,agitate,but not rinse or spin
Check to make sure your lid switch is working.
Posted on Nov 17, 2008
  • 1937 Answers
SOURCE: washing Machine does not agitate
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Following is the Whirlpool installation and maintenance PDF on how top load, direct drive washers work with a troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Following is the Whirlpool parts list for commercial top load, direct drive washers although the consumer washers are basically the same.
The problem seems to point to the Agitate Cams in the transmission that raise and lower the Agitate gear on the main transmission shaft. These are relatively inexpensive to replace.
I'd also check the splines on the main agitator shaft and the two pronged "washer" on top of it.
Posted on Oct 03, 2009
My Equator Advanced Appliances EZ 4000EZ Super Combo Washer Dryer will not spin or agitate. Error Code 5 appears on the display and I have have replaced motor 3 times. what should I do?
the problem is that you are installing what may not be faulty
get a service technician out to check the problem as it could be a program board or other sensor that is faulty and you are replacing the symptom and not fixing the fault
Nov 29, 2016 | Equator Washing Machines
Fisher Paykel GWL 15 Rotor Position Sensor
Does It just shake bowl left & right, it will soon give you fault code 56.
Well its a board problem you will need to get technician to fix this board, three resistors(R129,R130,R131) need to be changed for a 1MegOhm resistor.
Jul 08, 2012 | Fisher and Paykel GWL11 Top Load Washer
Eroor e000423-0002
Search online for "error code e423 canon ir5065". Get plenty of hits - best one looks to be 'copytechnet. com'
Mar 02, 2012 | Office Equipment & Supplies
Whirlpool cabrio WTW6700TW1 only fills little bit, won't turn or agitate, buzz sound/humming noise,code F51 flashes??
The F51 error is a RPS (rotary position sensor) board failure where the control board looses contact with the RPS during the machines operation. The RPS uses hall effect sensors to determine the speed and direction of the drive motor, allowing the control board to constantly monitor the motors operation. Because this error is a communication error and not a mechanical error with the motor itself (that would be and F52 error) we can limit our trouble shooting to the three items that make up the RPS circuit, the control board, the wiring harness, and the RPS itself.
Jan 16, 2011 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
Gives an error code lr
The “Lr” = Locked Rotor: The machine has repeatedly tried to turn the motor.
I have seen this issue caused by a failed motor. I have seen a bad Control Board cause this issue and a bad Motor Controller cause this issue.
If the Lr error code happened in the Spin Cycle of the wash cycle it could be caused by seized Outer Tub bearings.
Without a known good Control Board and Motor Control board this could be difficult to troubleshoot.
Here is a link for the FAV6800A/FAV9800A Service Manual
May 31, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Lr code, top locked
If your machine is a FAV6800A or FAV9800A you can use this info to release the top of the washer to remove you wash load.
The Service Manual for reference. Sears Parts Direct for reference.
Raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. See page 33 of the SM for putty knife insertion point.
The Lr code can be generated by and Motor can't turn in Agitate/Wash or Spin cycle due to drive system binding in Agitate/Wash cycle or Outer Tub bearings seized in which would lock up the Motor in Spin cycle . This issue could be caused by a failed Motor Controller, a Failed Control Board. An issue of this type requires some troubleshooting with built in machine diagnostics
But you need to confirm your Model number. There to many post in this forum with non FAV6800A or FAV9800A machine types. Unfortunately this forum board does not ask for the basic info of model number and serial number.
Mar 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Canon ir 2018 ERROR CODE E246
check print controller pcb connection, ram & EEPROM
Feb 26, 2009 | Canon iR 2016i Black and White Copier
Neptune 6800 is stuck in a loop
I’m owner of the FAV6800A and a novice also but this is how we learn by becoming self educated and involved as a DIY’er. Good for you that you are willing to roll up your sleeves. To get into Service Mode and read Diag codes you will need the Service Manual. The SM can be found at this site PDF format, in “Tips & Tricks” located here FOUND “”FOUND: Service Manual Neptune Top Load Washer FAV6800AW.”” Also the Troubleshooting guide in the console of your machine is a handy document it has the schematic for your machine, there are soft copies of the schematic out on the WWW. There is no master reset for the microprocessor on the Control Board other then pulling the 120VAC power to the machine, that will dump any error codes in the machine stored in RAM on the controller board. Don’t pull the power just yet, first see if you can get into Service Mode “see page 14 Enter/Exit Service Mode” and check for any errors that may be stored in the Control Board memory. See page 17 of the SM, I would be interested in any error response for Diag.Code 11. I’m concerned you may have a failure issue with the controller board. Also I want to make sure I understand the problem as described. In Quick Wash my machine starts at 28 your’s counts down to 24 and no further in the wash cycle, you never make it to Spin cycle is that correct? Also how did you drain the machine? It can be done in Service Mode by turning on the drain pump. The grinding noise issue…did you find anything (coins) under the tumblers causing the grinding noise? Do you have the original Motor Controller Board?
Feb 22, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Water fill problem
did you clean the screens in back of water valve? normally a fault code appears if it's a fill issue also the tub will spin at beginning of fill to soak clothes first before beginning to agitate
Jul 17, 2008 | Whirlpool WTW6600SW Top Load
Calypso Washer, seems unable to turn drum or agitate
I haven't had the problem with the washer tearing up my clothes as of yet but I have with the c1 error code. According the the manual there are three possibilities. 1- Bad drive motor 2- Bad thermal protector ( solution to fix replace the drive motor) 3- Bad motor control board. The last one was what needed to be replaced in mine.
Feb 08, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
