Question about Tripp Lite APSX1250 - PowerVerter APS X Series 1250W Charger Inverter
How we can stabilize the frequency in output when we run on the batteries.On mine inverter it is going up to 500 -600 Hz.
I notice this week that the frequency is not stable and I`am worried that might cause a problem to the appliances.I did measure with a frequency meter and what I have seen it unbelievable (it goes up and down 400 ,550 606 and more up to 700Hz.
  • 3,368 Answers
It sounds like harmonics that your measuring not the actual frequency. I would contact the factory especially if it is in warranty to be sure.
Posted on Nov 27, 2014
Sukam 800VA inverter continuously beeping with 3 lights blinking. What could be wrong?
check batry voltage or 2nd problem in realay and capicitors or
3rd ic before that disconnect output line
May 05, 2014 | Computers & Internet
It says frequency response as 40 Hz to 170 Hz (Subwoofer) and 200 Hz to 20 KHz (Satellite speaker). How it will manage frequency from 170 Hz to 200 Hz. Will this be affected
The sub-woofer will handle a frequency of 40Hz to 170Hz of the sound spectrum, and the satellite will handle 200Hz to 20KHz. There is frequency hollow that is, 170Hz to 200Hz; and it is not quite audible and noticeable to human ear. Gopakumar Gopalan Google
Apr 22, 2014 | Audio Players & Recorders
What is the frame output ic
Hello
Frame output IC means nothing, but the VERTICAL OUTPUT IC. Every TV will have it, which will scan picture vertically at 50 or 60 Hz. [1 HZ means one frame per second. Normally TVs will have 50Hz, 60Hz and 100Hz vertical frequency]. As vertical frequency rat increases, the picture fliker wil decrease. High level high-cost TVs will have 100Hz or even more frequency will be used for vetical scanning.
In the case of computer monitors, the vertical frequency will vary from 60Hz to 120hz. You can see its picture stability, at this high frequency.
The IC [Integrated Circuit Chip], which generates the vertical frequency and outputs it called the vertical output [frame output] IC. OK
Wish you a Proseperous and Happy 2012.
Gopakumar G, Trivandrum City, Kerala State, South India.
Dec 29, 2011 | Televison & Video
I have a nexXTECH 75W mobile plug inverter and had lost the manual. I notice on the back under output it says 115 VAC, 60 Hz, 60 W cont and 75W for 5 minutes. Can you tell me what it means for 5 minutes?
This is your start up power. Like when a saw or something like that intially comes on it will surge pulling more power than it will once it is up and running. So this extra power is to accept the surge
Sep 17, 2010 | Electronics - Others
I am trying to find the output power, watts?
bad transformer. A $10 part at most electronic stores. U fried it when you dropped it. Happens all the time.
Jun 08, 2010 | Audio Players & Recorders
Different HZs problem (from 60Hz to 50Hz)
Yes there are frequency converters available but most are relatively over rated (industrial) for your requirement such as MDS Power or VisiComm Industries. What you need is a Low Power Solid State Frequency Converters lower than a
Electrocon Frequency Converters. However, I expect this devices to be rather expensive.
A few other options you may want to consider:
1. Contact the store where you bought if from; swap with an International version (Model SL-1210 Mark II; same price as SL-1200 Mark II); dual voltage switchable on rear of unit: 120 volts/60 Hz (U.S.) or 220 volts/50 Hz (Europe). You hopefully just spend for the cost of shipping + a restocking fee;
2. Contact 3rd party Technics TT specialist like TopDJGear, Quality Electronics, Planet DJ or DJHardware
and inquire if they would supply you the part(s) that you need to convert the 1200 to a 1210; or
3. Offer a swap on eBay.
Hope this be of some idea/help. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 13, 2007 | Technics SL-1200MK2 Turntable
50Hz to 60Hz conversion
Hi, Your idea is basically sound and should work as long as the UPS originally is designed to produce 240V 60Hz and has its own built in timebase. The reason is that the input as long as the voltage matches makes no difference (50 or 60 Hz). By design, the UPS converts the input voltage to DC to charge the internal battery. The battery then powers an electronic circuitry that produces the 240V 60Hz. The input is then isolated from the output in terms of frequency. This is a common design, however, there are some (not many) that uses for its local oscillation sampling from the source and therefore will replicate the input frequency to its output, but very rare; it's better that you know they exist. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards. P.S. The only problem with 50 and 60 Hz is heat buildup which is tolerable and still within safe parameters. The only time the 50/60 HZ makes a big difference is when motors are used, timers such as in the early designs of microwave ovens, washing machines, etc., pumps and other highly inductive consumers. Most electronic devices converts the AC input to DC and therefore the frequency has negligible effect. Of course others may see it differently.
Sep 15, 2007 | Liebert UPStation GXT2700RT-208...
Tripp Lite APSX1250 - PowerVerter APS X Series 1250W Charger Inverter Logo
Top Tripp Lite Electronics - Others Experts
Are you a Tripp Lite Electronics - Other Expert? Answer questions, earn points and help others
