Question about Sharp BR AR-M355N/455N - 1-DRUM
How do I fix the copier if it says call for service?
Nothing
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 884 Answers
Hi
You don't mention any error code that may shown and which would identify where the fault is. A full list of error codes can be found here:
Error Codes Sharp ARM355
and from here you can also get a pdf format service manual for this model which in combination with the error code explanation may enable you to fix your machine. On the error code page you can also change the model of your machine if you need to by using the drop down menu in the centre of the page.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Posted on Nov 27, 2014
My Sharp Ar 5620 sl is showing F2 or 2F Error what will i do to solve the problem
You call Sharp Service. There is no way you could fix the problem even if you were told what the codes mean.
You can find that out when the Technician calls to fix it and give you a either a "guesstimate" or a formal written quotation. Either way you will either have to pay a call-out fee, or if you transport it to them, an inspection and quote preparation fee.
Nothing for nothing in this world......sorry !
Poppa
May 19, 2014 | Sharp AR-5316 Advanced Digital Imager...
We have an imagerunner c2620 the fixing unit went bad and we just replaced it. Now it says there is a paper jam in that area and there isnt any paper where indicated
Did you replace worned out unit with new one?
If Yes, check the connectors of sensors and connectors from fixing unit to copier.
Did you remove all protective sheets from new fixing unit? Check that nothing is in paper path way or that sensor flapers arent broken.
Leave an email, and I can send you the service manual.
Sep 17, 2011 | Canon imageRUNNER C2620 Color Copier
Code E000001-0004 what is this code and how to fix.
this is error for abnormal rise of temperature, if it is not seriuos ( I mean nothing faulty ) you can reset it in service mode.
Procedure:
While the copier in copy ready or showing error:
1) Press the asterisk key " * " on the control panel.
2) Press the 2 and 8 keys of the keypad at the same time.
3) Press the asterisk key " * " on the control panel.
Choose:
COPIER
FUNCTION
CLEAR
ERR
Hope that helps!
Aug 23, 2011 | Canon imageRUNNER iR C4080 Color Copier
Error 000 switch power off and on again
This is error in the fixing assembly, the fixing assembly is not getting hot at all. First try resetting the copier error. You do this by pressing the additional function key, then press the 2 & 8 keys at the same time and then the additional function key again. Press copier, then function, then CLEAR, then ERR then OK. This will clear the error from the copier's memory. Be sure to do nothing else within the service mode, you could really mess up some settings and cause more problems than you have now. Power cycle the copier and if the error comes back up then further fixing assembly then further repairs of the fixing assembly will be needed.
Jun 23, 2011 | Canon CLC-700 Copier
I have a sharp 2025
Hello !
That error code indicates a drive problem with 4th/5th mirror assembly, motor, sensor, board. Your copier has a stepping motor failure and a sensor failure.
Needs to be serviced.
Hope this helps.
Oct 18, 2009 | Sharp Office Equipment & Supplies
Paper pulls to right and jams
The Paper feed roller needs to be cleaned/replaced. Take the printer to a service agent to have it serviced.
Aug 03, 2009 | Canon PIXMA® MP210 Printer
Service Code SC 542
That is fuser code and needs to be reset in the service mode, it will not go away by turning the off and back on.
May 29, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Canon ImageRunner 3300 G
The IR service manual says E602 means the harddrive is toast.A little tough to fix on an IR300 without the canon service tool on a laptop.It Fundamentally means you have to reimage the copiers hard drive with a new image.They don't call it imaging, they call it downloading a new OS, which must be downloaded from Canon.A trained IR service tech should be able to do it in about an hour.Good Luck
Apr 07, 2009 | Canon imageRUNNER 400S Copier
E00002-0000 error code
clear the error from the service mode
Oct 25, 2008 | Canon ImageRUNNER 3570 Copier/Printer
Sharp BR AR-M355N/455N - 1-DRUM Logo
152 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
