Question about Dell Computers & Internet
What is this stuff and could it be shorting out my board ?
Hello...I'm dis-assembling a Dell monitor and just examined the board, looking at the capacitors for damage. I found a hard semi-opaque substance in three separate areas: nearly covering two small capacitors, the power input, and touching another element hard to describe. It's as if they had been "spilled" from above when the stuff was warm. No ruptures observed yet in nearby capacitors and elements. I'm thinking of trying to remove the stuff by heating. Any ideas what this stuff is? (No mention of it in the tutorials that I've read.) Thanks.
  • Suman Ghosh
    Suman Ghosh Nov 23, 2015
    Hello Robert
    I am newbie on repairing my DELL ST2210B monitor. I want to check that if the bad caps have been given away; Could you please suggest, how to open the back cover of my DELL Monitor to check the capacitor problem?
    Thanks in advance.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Interesting; if it's not a substance from blown caps then is it perhaps something which oozed or dripped into the unit from the vented area from outside the unit?
Posted on Nov 27, 2014
Testimonial: "Thanks for your reply. Since the board is enclosed it is not likely that anything dripped through the vents. I now believe that the epoxy or whatever was spilled on the board at the factory. Don't know yet if this could have caused the problem, but I don't think so. Probably a blown cap hidden under the gunk..."
  • Robert Regner
    Robert Regner Dec 05, 2014
    I identified the gunk as silicone and gently got it off the power connectors. I reassembled the monitor and it now works again.( I did not touch the capacitors) .
My L194WT -SF WONT WORK NO POWER USED SAME POWER LEAD ON DIFFERENT MONITOR NO PROBLEM
Hello Steve,
The most common problem with the L194WT monitors is a failure of the power supply board. There are parts called capacitors that fail and can cause the issue you have. Sometimes the power light will just flash, sometimes it takes several minutes to display a picture or even a wavy picture, all of these issues indicate a failing power supply board. These boards can be repaired if you can do a little soldering. The L194WT uses the same power board as the L196WTQ and we have a step by step repair guide with dis-assembly instructions available at http://www.ccl-la.com/blog/index.php/lg-l196wtq-bf-lcd-monitor-repair/ Look over the guide and check your board to see if your capacitors have bulged and need to be replaced.
I hope this helps, if so please rate our solution.
BuddyMc
Aug 07, 2011 | LG L194WT 19" LCD Monitor
I have a SyncMaster 920N Samsung Monitor and today it stops working. The power light is slightly constantly blinking,but the monitor is not turning on,when I m pressing power button. I tried changed power...
A fast blinking power light is an indication that the power supply is in a shorted condition. Parts called capacitors that filter the output power on the power supply board can fail and the power supply will short out causing the fast blinking power light. If you can solder then you can repair the monitor. Here is a link to a repair guide that has pictures and videos showing how to dis-assemble the unit and what to look for and replace to do the repair.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-920n-920nw-monitors/
I hope this helps, if so please rate my solution.
BuddyMc
Jan 06, 2011 | Samsung SyncMaster 920N 19" LCD Monitor
My screen on my dell 15 laptop flickers but stops for a while after a little tap
paddymaher, This symptom could be no more than just one bad poorly soldered electronic component that has over the years of use has become "thermally-intermittant" and need to be resoldered to restore unit to "like-new" condition. Left as-is unit will only get worse as the solder joint becomes more oxidized from the gases permitted to now "enter" what should be a "gas-tight" electrical connection. May need to use large magnifing glass to examine the printed circuit boards inside of the unit for "frosty looking" solder joints of the components soldered to the boards. 12fixlouie
May 06, 2010 | Dell E173FP 17" LCD Monitor
While working the screen goes black. If you power
Try that monitor on another computer, if it does the same thing then you know the monitor is the issue. If the monitor works fine on another computer then you know that the video card on the original computer is faulty.
If the monitor is faulty, take it apart and look for capacitors that are puffy, if you see any puffy ones, replace them with capacitors of the same Uf rating and at least the same voltage or more.
Apr 22, 2010 | Dell UltraSharp 1707FP 17" LCD Monitor
The screen flashes on my Dell 1905FP Monitor, Is there a fix?
This is a common indication of bad filter capacitors on the power supply board. Below is a picture of the power supply board with the problem capacitors circled in yellow. The repair is easy, you just need to replace those capacitors and the unit should be as good as new. Below the picture is also a link to a full repair guide showing how to dis-assemble the monitor and what parts need to be replaced. the repair guide has a full parts list for the job.
The repair guide can be found here:http://www.ccl-la.com/blog/index.php/repairing-a-dell-1905fp-1907fp-lcd-monitor/
Mar 26, 2010 | Dell UltraSharp 1905FP 19" LCD Monitor
Dell LCD Monor light keeps blinking green, screen is black cannot stop blinking unless unplugged from power source but upon plugging back in monitor starts blinking green again
Your monitor has a bad power supply board. This happens often on LCD monitors because of the heat buildup in them. If you can solder them go to our web site at:
www.ccl-la.com/badcaps.htm We have a step by step dis-assembly and repair guide for your monitor. There are several versions of the E173FP some end in b , f, or c so be sure to check your monitor.
Buddy
Corporate Computer
www.ccl-la.com
Aug 27, 2009 | Dell E173FP 17" LCD Monitor
The monitor has a white screen when its turned on. nothing happened when its connected to a computer. What do you think the problem is?
You may have a problem with the power supply board. On many LCD monitors after a few years the power supplies start failing. The problem is parts called capacitors start failing. They get damaged because of the heat trapped in the small spaces of the monitor case. You can take a look at a few pictures on our site at: www.ccl-la.com/badcaps.htm We also have a section with dis-assembly and repair instructions. Check it out, if you have more questions just email me. If you don't want to do the repair yourself we offer a repair service.
Buddy
Corporate Computer
Over 21 years pf PC and printer support/repair.
Jul 29, 2009 | Dell E176FP 17" LCD Monitor
How to open a Flat Panel Monitor
We have a repair guide for the E173FPf posted on our web site. The dis-assembly is that same as your unit just the electronics are different. The repair guide for the E173FPb monitor will be posted tomorrow afternoon.
www.ccl-la.com/monitor_repair.htm
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
WWW.CCL-LA.COM
Over 21 years of PC and printer support/repair
Jul 18, 2009 | Dell E173FPb 17" TFT LCD Monitor
My dell 1905FP power button flashes green and will not turn off, the screen is black.
This is a common indication of a failure in the power supply. There are parts called capacitors that are used in the filter section of the power supply, when they go out the power supply can't properly turn on so you get no picture and a flashing power light. Here is a picture of the power supply board with the problem filter capacitors circled in yellow and below the picture in a link to a repair guide with details dis-assemble and repair instruction along with parts list for the Dell 1905FP and 1907FP models.
Mar 25, 2009 | Dell UltraSharp 1905FP LCD Monitor
Computers & Internet Logo
95 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
