Question about Samsonite Photography
How do get the zipper on my large Samsonite suitcase fixed?
Googled "Samsonite luggage" and came up with this site.
    Problem Solver:
  • 12 Answers
There are a few things to go wrong, you did not mention what's wrong. I suggest going to You Tube and type - ZIPPER REPAIR - there is lots of good step by step videos.
My 1st choice if you can't do it yourself is try a local Luggage only store at the Mall . They all should have repair contractors if they do not do it themselves. They may also be able to return it to Samsonite for repair.
My 2nd choice would be to try a local Automotive or Marine Trim Shop. They should be able to fix or replace any zipper. If it can't be fixed they will tell you so. Good luck.
Posted on Nov 27, 2014
SOURCE: change luggage key combination
Email from Samsonite in response to my plea for help:
Dear Sir/Madam:
The following are the lock picking instructions you requested from Samsonite Consumer Relations.
1. Position the luggage so that the numbers on the wheel are
right-side-up as they face you and set all three wheels to “0′.
2. Starting with the wheel on the left, to the right of the wheel,
look into the narrow space between the right side of the wheel and
the body of the lock. Look down into the shaft. (If you have a
safety pin, straight pin, or thin nail file, place that in the
narrow space.)
3. While looking down into the shaft, rotate the wheel slowly. You
are looking for an indentation (a square notch). When you find
the indentation, stop and write the number down. (If you are using
a tool, the tool will fall into the indentation.)
4. Follow the process for the remaining two wheels.
5. Try to open the piece of luggage.
6. If the luggage still will not open, please try the following:
a) If the number on the wheel is over 5, subtract 5 from the
number showing. For example, if the number showing is 8 turn
the wheel to 3 because 8-5=3.
b) If the number is under 5, add 5 to the number showing. For
example if the number showing is 2 turn the wheel to 7
because 2+5=7. The numbers showing on the wheels will be
your combination.
If you still have a problem with the combination lock, contact the nearest authorized repair center to your zip code for repair assistance. Our warranty and repair information can be viewed at http://www.samsonite.com under the heading “Customer Service Repair Centers” for your reference.
We appreciate your loyalty and will continue to design products that are reliable business or travel companions.
Posted on May 05, 2009
  • 3 Answers
SOURCE: my combination for samsonite suitcase no longer works what to do?
Is it locked shut?
Posted on Jun 22, 2009
gemmy23
  • 346 Answers
SOURCE: I can't open my samsonite luggage...the combo is stuck but I can
Turn your suitcase upside down. At this position all your numbers look upside down. Now with the help of a torch light you should see a small gap above the rotating thing (the one with which you change your number) Take the first rotating thing and rotate from 0 to 9, at some particular number you can see a small hole inside the small gap which I have mentioned before. Do the same for the next 2 rotating thing.
When you are done you can see the small hole(a tiny spring like material is seen in the hole) in all the three small gaps.
Now you can open the number lock.
Posted on Jul 11, 2009
SOURCE: my samsonite hardcase luggage's centre no.lock not able to close
problem sloved
Posted on Oct 21, 2009
SOURCE: Problems to open a Samsonite TSA 007 lock on suitcase
Hi I have a problem to aopen my luggage I think my niece has change my security code accidentally , but now I cannot open my luggage can you please chelp me out?
Posted on Dec 04, 2009
My samsonite luggage with a four digit lock was opened by US customs and since then the case can be opened by pushing the open button whatever digits appear on the lock. Can this be fixed?
Most likely they pried it open and snapped the locking mechanism inside. Definitely not repairable, but you might be able to replace the entire combination lock. If you think the luggage is worth the expense, you could send it back to the manufacturer for repair.
It is usually unwise to lock suitcases these days when traveling by air. Especially on international flights. It's better to just use a zip tie, which can be cut off easily without damaging your luggage. That way you can tell that your suitcase has been tampered with (Cusoms & TSA will usually tag it anyway), so you can make sure nothing is missing, but avoid damage to your luggage or locks. Those locks don't really provide any security anyway.
So, if the latch still works, leave it alone and use the zip ties (through the zipper pulls) the next time you travel.
Aug 28, 2017 | Samsonite Photography
Samsonsite suitcase wheel needs repairing South Brisbane
you can go in a Samsonite store and ansew if they can repaire it.
or you can search the site for contact they
May 22, 2017 | Luggage & Travel
How to reset a combination lock for samsonite luggage?
if the suitcase is open, look for a little red tab on the inside. Move it to the other side of the little window, then change the combination. If the suitcase is locked, you will have to try from the outside to find the correct combination
Mar 11, 2015 | Samsonite Photography
I have forgotten combination tomy suitcase and it is locked how can i get it unlocked
Start at 000 and go up one number at a time until it opens or reachest 999.. it will take some time. .. good luck.
Dec 01, 2014 | Samsonite Silhouette 11 Hardside Spinner
HOW TO CHANGE LOCK COMBINATION IN A SAMSONITE LUGGAGE OYSTER GL
I forgot my locker combination and my luggage is locked.How can I open it??
Nov 13, 2010 | Samsonite Silhouette 11 Hardside Spinner
I have a somesonite 30in hardshell , uprite about 20 yrs old. has 2 key locks, as well as combanation center lock. question how can i set these locks so that, they are TSA excessable locks??? PLS. Help ...
You can have the locks changed but, that will cost almost as much as new luggage. They will have to be kept unlocked and a TSA strap will be needed around the suitcase.
Oct 07, 2010 | Samsonite Silhouette 11 Hardside Spinner
Please tell me how to set teh lock code for my samsonite silhouette 11 HS....no instructions were included! help!!
Sure... here're the instructions - open the suitcase, then open the zipper in the modesty pouch (it is mounted on the backside of the suitcase, along its entire length), and then from in there, take out the plastic packet. In the plastic packet are labels, warranty information, AND voila - the instructions to set the combination lock... :-)
I would tell you here too:
1. Open the suitcase
2. Look at the inside back of the lock - you would see a red color tab, and two markings - A
Aug 30, 2010 | Samsonite Silhouette 11 SoftSide 22"...
Photography Logo
402 people viewed this question
Top Samsonite Photography Experts
ittco
Level 1 Expert
Are you a Samsonite Photography Expert? Answer questions, earn points and help others
