Question about Woods Hardware & Accessories
What should be on display if I only want say program 1 to run on my woods to-1300-2 timer to run? Need a pic of it. Still have not figured how countdown really works either. I had it set last night an
I have reset and now only have program on. It says Auto and off right now and it should go on at 5 pm and end at 11 pm. Random and countdown buttons are off
3 Suggested Answers
SOURCE: ZILLA POWER CENTER
The yellow outlets are controlled for 12 hours, and you can determine when those hours occur when setting current time.
http://waterheatertimer.org/GE-timers-and-manuals.html#zilla
Absolutely feel obligated to upvote the help.
Or take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 05, 2011
  • 5245 Answers
SOURCE: Problem programming timer settings. Is it supposed to be random or continuous?
1) Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#50006
2) How to set analog timers by experimenting with features:
http://waterheatertimer.org/How-to-set-timers.html
3) 50001 timer is not random vacation timer like the 50003.
50000 series timers by Woods have 1 year limited warranty, and they are a new design released this year. However the analog timer design has been around for many years.
4) If timer is acting randomly, then
a) timer is defective,
b) the override switch is not fully positioned at 'timer on,'
c) segments are not lifted fully in position,
5) ... other more remote causes: outlet might not test 80% rated voltage?, outlet might have reversed polarity?
5) Try timer on different outlet with different light.
6) As the timer dial rotates, the segments push small lever, and the lever moves switch that turns lights on-off. I suppose if this lever was broken or switch was broken, then timer would act more randomly.
Posted on Dec 06, 2012
How do I program a Noma N1506 timer?
All Woods timers and manuals
N1506 manual:
http://waterheatertimer.org/pdf/Woods-49122-N1506-manual.pdf
N1506 is heavy duty outdoor timer with display screen.
Plug timer in and display flashes C.
Set current time: press Time button once and display shows 1 am
Keep pressing time button until current time with am pm displays.
Dot in lower right corner corresponds to pm hours.
To set timer program:
Press Mode button, display flashes P
Press Time button until desired ON time displays.
Press Mode button again and display flashes E
Press Time button until desired OFF time displays
When programming is finished, press Mode button and display shows current time.
To reset timer, unplug timer for 10 seconds and re-program timer.
Timer must be reset after power outage. Display will warn by flashing C.
Plug lights into timer.
If lights have a switch, switch must be on.
For manual override, press Mode button, and display shows O and lights will be ON until next program change.
To use timer function, press Mode button until current hour displays.
Dec 12, 2010 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
How to program a digital timer
You posted under a photo that looks like Woods 49063 or GE 28441
Link below shows this particular timer with manuals for each:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Oval
If your timer does not show on link above, add a comment with as much description as you have, with button locations and color and purpose of timer.
To program the GE timer:
1) Set current time
Press and hold Time button: and then push hour and MIN button to set current hour and current minute.
2) To program:
Press and hold PROG button for 1 second
Prog 1 ON will display
This is program1 ON
Press hour button and MIN button to set program1 ON hour and minute
Prog 1 OFF will display
This is program1 OFF
Press hour button and MIN to set program1 OFF hour and minute
Prog 2 ON will display
This is program1 ON
Press hour button and MIN to set program1 ON hour and minute
Repeat steps to program up to 6 different ON-OFF programs
When programming is finished, press TIME button to return to current time.
3) Set MODE
Press mode button once and ON displays, this means light is ON
Press mode button again and OFF displays, this means light is OFF
Press mode button once and nothing displays, this means timer programs will run as you set them
Dec 12, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
How do I program Woods digital timer 59203?
Link shows all Woods timers and manuals
If instructions below do not match your timer, look through timers on Woods page to identify, and then add a comment.
Manual for 59203
http://waterheatertimer.org/pdf/Woods-59203.pdf
Instructions below are for Woods 59203 & GE 59203 plug-in programmable timer with 2-prong polarized outlet:
Plug timer in until battery is charged.
If display will not show, then timer battery needs to be recharged, or timer may be busted, or electric circuit is tripped off, or electric circuit heeds to be tested with circuit analyzer.
Set current time:
Press and hold CLOCK button.
Press HOUR and MINUTE to set correct time with am and pm.
Press Day button to set current day.
Release clock button.
Program timer:
Press PROGRAM button until "1 ON" displays. This is program1 ON.
Press MINUTE and HOUR buttons to set ON time for program1
Press DAY button to choose day or group of days for program1 ON
Press PROGRAM button until "1 OFF" displays. This is program1 OFF
Press MINUTE and HOUR buttons to set OFF time for program1
Press DAY button to choose day or group of days for program1 OFF
Press PROGRAM button until "2 ON" displays. This is program2 ON.
Repeat steps above to set ON and OFF time for 5 programs.
When programming is completed, press CLOCK button to exit programming.
Press ON/AUTO/OFF button until Auto displays.
Make sure lamp is turned on.
Make sure bulb is good.
Dec 11, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
Have GE digital timer 15117. Can't figure out how to make the display show AM/PM so I can set it correctly. Clock hour/min just cycles through 12 hours without noting AM or PM setting. Can't program...
GE 15117 manual
http://waterheatertimer.org/pdf/GE-15117-Manual.pdf
You might try a new AA battery.
Some guy wrote in this week and said he bought 6 timers and all the batteries were bad except 1.
Some timers, like Woods TD1300, and others have the 12 hour or 24 hour option.
You press and hold Time button to choose 12 hour or 24 hour
But GE 15117 manual says nothing about this option.
GE 15117 timer is same timer as Woods 59403
Several folks have written in past couple weeks about the Woods 59403 timer skipping over functions.
The best I can guess is your timer is malfunctioning like the other people's timers.
Woods 59403 manual is identical to GE manual, and says nothing about 12 hour 24 hour option either
http://waterheatertimer.org/pdf/Woods-59403.pdf
I test timers for programming and wiring difficulties.
Yesterday 3 timers arrived here, and 1 didn't work.
I took it apart and tested the electronics, and something went bad.
When these timers don't work, you get your money back or throw them away.
Dec 04, 2010 | GE Hardware & Accessories
I need instruction for the timer
You posted under Woods 59403 timer
If this is not your timer, add a comment.
59403 timer manual:
If you have different Woods timer, look at images at link below to identify timer.
Add a comment if you need help.
59403 programming Instructions:
Plug timer into indoor or outdoor wall outlet.
Set clock:
Hold down clock button.
Press day button until current day displays.
Press Hour button until current hour displays.
Press min button until current minute shows.
Program timer:
Press PROG button until 1 ON displays
This is Event1 ON
Press Day button until selected day or days displays for event1 ON
Press Hour button until selected hour displays for event1 ON
Press Min button until selected minute displays for event1 ON
Press PROG button until 1 OFF displays
This is Event1 ON
Press Day button until selected day or days displays for event1 OFF
Press Hour button until selected hour displays for event1 OFF
Press Min button until selected minute displays for event1 OFF
Press PROG button until 2 ON displays
This is Event2 ON
Repeat steps above to set up to seven events.
Recommended you make chart of your on-off times before starting to avoid conflicts in programming.
When programming is finished, press MODE button until automatic displays.
To override programming, press MODE button until lights come on.
For random operation, press MODE button until RDM displays
Dec 02, 2010 | Woods Outdoor 7 Day Digital Two Outlet...
I would like to have the instructions for operation of the Timer.
Add a comment at any time
59403 timer manual:
Set clock:
Program timer:
This is Event1 ON
This is Event1 ON
This is Event2 ON
How do I set the Woods N1506 timer?
N1505 timer manual:
Dec 01, 2010 | Woods Outdoor Lighting Timer
Model N1506, I need Operation instructions for this Woods Light Timer?
N1505 timer manual:
Dec 01, 2010 | Hardware & Accessories
I caNT SEEM TO PROGRAM OR CHANGE THE TIME . HOW DO I DO IT
Page showing Woods timers and models:
Add a comment with specific model number and I will help.
Instructions below are for Woods 59203 24-hour digital timer:
Plug timer in until battery is recharged.
If display will not show, then timer battery is dead and needs to be recharged, or timer may be broken.
Set current time:
Program timer:
Nov 27, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
I need a manual to know how to program
Woods 59337 plug-in timer with internal rechargeable battery
Plug in timer for 1 hour to charge battery.
Display will show when timer is charged
After battery is charged, you can remove timer from wall plug for programming
http://waterheatertimer.org/pdf/Woods-59377.pdf
Oct 22, 2010 | Woods Industries 59377 Indoor Digital...
Hardware & Accessories Logo
62 people viewed this question
Top Woods Hardware & Accessories Experts
Gene Haynes
Colin Stickland
Colin Stickland
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
