Question about MTX Thunder 801D Car Audio Amplifier
I bought amp and test it the green light came on it sound good.i get home and install it and all i get is red light andbnothing
  • MTX Master
  • 637 Answers
Mtx 801
i bought amp and test it the green light came on i - bought-amp-test-green-light-came-sound-t0vzops3md3qpqya0esvxfpx-5-0.jpg
Posted on Feb 05, 2015
    Habit-Forming:
  • 22 Answers
Red light means Protection mode....
some of the reasons a amp will go into protection mode is
1) overcurrent - the amps power wire is shorted or the amp is fried
2) thermal - will go off when the amp cools down
3) Short circuit - the load on the output is too low
4) you have your speakers off balance. exp: 3 speakers hooked up instead of 2 or 4 or larger to smaller speakers ratio
5) your power supply wire is to small of a gauge
To reset your amp or moving your speaker and subs wiring around to ensure balance.
Hope this Helps and Good Luck
Posted on Nov 28, 2014
2 Suggested Answers
  • 19 Answers
SOURCE: No sound from speakers, but there is power to amp
make sure the power wire and the remote wire have voltage. at least 12 volts. make sure the ground wire is good and has a good solid ground. after that make sure the rca cables are getting signal from the radio. if you have a small speaker or tweeter you can touch the wires from the speaker to the rca cables and it should play music very quietly. meter the subs and make sure theyre ok and not shorted or bad. if all that checks out good.... the amp is probably bad. start with all the simple stuff and work youre way up. if the amp has good power and signal and good speakers then the only thing thats left is the amp. good luck
Posted on Dec 30, 2009
I have a kenwood subwoofer, the red light comes on but I am getting no sound, help?!
red light is usually bad like protection mode unless it is supposed to be red. amps are always green and red is protection indicator normally. look it up for your amp and if you bought it used you got ripped off
Mar 14, 2015 | Kenwood Car Audio & Video
No picture or sound with a red flashing power light. Have replaced the convergence IC's but no change (do not have the chirpint sound). Removed main power board & green LED does not light up
On that model the conv IC is usually not the solution. I believe its the blown capacitor problem with is an easy fix. Check the site www.TvRepairKits.com for a repair kit.
Apr 11, 2012 | Hitachi 53UWX10B 53" Rear Projection...
Sound went completely dead on an 07 Crown Victoria. I checked all the fuses and all are good...plugged the original deck back in and still no sound...nothing..completely dead..all connections look good...
Be sure you checked all 3 fuses, F3 5amp, F9 7.5amp. F12 15amp. Test with test light the red and black wire in start, the dark blue and light green in accesory, and the violet hot at all times. These are all in the harness to the radio. Then test grounds by clamping the test light to battery positive, and check the black wire and the two black and light greens. If both units are good, there's gotta be a bad power or ground.
Aug 12, 2009 | 2008 Ford Crown Victoria
No sound from back surround speakers
We just hooked ours up and had the same problem, we switched around the s-air cards and that solved the sound problem immediatly.
Jan 11, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Sound
Make sure your volume is not on mute. If the speaker icon on your lower right has a red x means its on mute. To test go to control panel and double click sounds and test. If Windows sounds work without speakers then problem is with speakers. Make sure volume is up, make sure its properly connected to correct output jack (usually green or light green). Also make sure speaker power on. If those things are correct check your device manager ( right click my computer) select "manage", click on "device manager" and on right pane check to see if theres any yellow exclamation, question mark or red x on the sound device section. Yellow exclamation or question mark means to update or install correct drivers. Check your speaker box if it comes with a CD.
Jul 29, 2008 | Dell Inspiron 530s Desktop Computer...
A300HLX Amp + 600 Watt JL Audio Sub
Ill go for a better GROUND , sounds like its not grounded properly and thats why the RED LIGHT . DO A RE CHECK on the installation . hope this helps
Apr 29, 2008 | Jensen A300HLX Car Audio Amplifier
Sony XM-2200GTX...Power, Green Light, All OK, No Sound!
Sony generally drives their power light from a source that does not rely on the amplifier's switching power supply. This means that it's not a good indicator as to the health of the amplifier.
As long as you have B+ and remote voltage, it will light up. Since you've tested the speaker and the signal source, I think the amplifier is likely defective.
Oct 17, 2007 | Sony XM-2200GTX Car Audio Amplifier
Okay i have a problem hifonics brutus 1500 mono d class amp
well your amplifier is obviously going into protect mode,(i used to have this amp and it is awesome) anyway i would go through just to be sure and check all the power connections with a test light, remote wire, positive, and ground. and check the fuse to see if it is still good. you can buy a test light at wal-mart and any automotive store. if you stil have a problem then i would check to see if your running below 1 ohm on this amp. that would cause it to go into protect mode. if all this fails i would just go buy a new one.
Oct 07, 2007 | Hifonics Brutus BX 1505D Car Audio...
Powers on but no sound
Check the main amp fuse under the hood, even if it looks good just change it. Often times that light on the amp can come on just from the power amp tunon wire. Try a friends subwoofer box just to make sure the connectors on your box are good, and if that doesn't work then give me some more details....year/make/model of car, what kind of sub, what types of things do you see on the side of the amp....is there a green light as well as a red light?
Aug 18, 2007 | Xtant A3001 Car Audio Amplifier
MTX Thunder 801D Car Audio Amplifier Logo
153 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
