Question about Russell Hobbs Irons
How do I remove the back plate on a Russell Hobbs Colour Contour iron to replace the wire
smilemaker
  • 790 Answers
SOURCE: Faulty Russell Hobbs Steam Iron
http://www.ehow.com/how_2067318_fix-nonelectric-steam-iron.html
Posted on Jan 01, 2008
SOURCE: Russell Hobbs Steam Glide 2200 won't produce steam.
I had a problem and tracked it down to the pump. If you take the iron apart, the pump sits towards the front of the iron and has 3 tubes connected to it. Remove the srew-down bracket and free the pump from the plastic clasps on the base. Disconnect tubes and wires (remembering where they go.
Remove the circular securing spring from the front of the pump and drop the metal barrel from the housing. Unscrew the rear plastic assembly and set aside. there is a joint inside where the plastic assembly was - this is has an o-ring and is simply a pull-apart. It deos not need screwing. Pull the metal barrel apart, taking care to note the sequence for reassembly. Inside the barel is a larger rubber washer. Pull on the metal tube that goes through the centre of the washer using a pair of pliers - it will come free.
You will then see the problem - the spring inside the metal barrel will have broken. Take care, because at the other end of the spring is a small plastic washer that must be retained. Find a pen that has a short spring inside and use this as a replacement. If necessary, you can trim the spring to make it the right lenght. Ensure you have removed all broken pieces of spring, and reassemble. Try it out before finally attaching the pump inside the iron. It took me 2-3 attempts to get the spring tension right. If you can find a 'PENAC RB-085B BA1002' pen, the spring is perfect.
Once you have got it right, reassemble.
I have to replace the spring approx every 6 months as the replacement is obviously not meant for the job and wears or rusts or breaks. However, I am getting extended use from my otherwise broken iron.
Take care - things inside get HOT!!
Hope this helps.
Posted on Dec 17, 2008
clyde2j2
  • 137 Answers
SOURCE: lost instructions on how to use self clean on my iron
It probably needs to be de-calicified, you can find the stuff to do it at most any hardware store.
Posted on Mar 28, 2009
bozcro
  • 867 Answers
SOURCE: Russell Hobbs Steamglide 2200.Iron and steam
is the water in your area heavy? it may have clogged your iron with stone. soak plate in something like clr .
Posted on Aug 10, 2009
SOURCE: I have a Russell Hobbs Steam Generator iron
My Russel Hobbs Steamglide iron has stopped pumping steam , iron itself heats up but no steam...has the pump gone and can it be reapired
Posted on Oct 11, 2009
My russell hobbs steam iron keeps blowing the electric
either take something off the circuit or upgrade your circuit breaker and wiring.
Jul 05, 2016 | Russell Hobbs 13153 Iron
Lights come on when plugged in, doesn't heat up and has a beeping sound , colour panel is red thankyou
Read the operator's instructions. They are available of the Russell Hobbs site or by contacting Russell Hobbs UK on-line through the "Contact" link. In most cases, steam irons tend to clog with hard water deposits and need to be de-scaled from time to time. If that doesn't help you, buy a new iron. Rowenta's seem to perform best.
Apr 09, 2015 | Russell Hobbs Irons
How do I replace a dangerous 18651
You should be able to take it back to place of purchase for a full refund!
Dec 12, 2014 | Russell Hobbs Irons
How do IO remove the sole plate because a screw has come loose inside at the front making the sole loose
you have to access the iron from the top or from the heal. the base is solid and can not be accessed from the bottom look on the heal plate of screws then the top should lift foward.
I hope this was useful
May 01, 2014 | Russell Hobbs 15129 Slipstream Iron
Instrution manual for russell hobbs 17880
i need an instruction booklet for a russell hobbs steamglide iron model number 17880 any helpers please .
Jan 20, 2012 | Russell Hobbs Irons
I have so far seen 3 other people with the problem i have with my russell hobbs steam glide iron 13153. I have tried what was suggested to me but nothing has worked. the iron gets hot but no steam coming...
I would write to russell hobbs and complain, my friend bought one of these 18 months ago and hers got hot but no steam through. She sent it back to them and they sent her a new one as a gesture of goodwill.
Aug 04, 2011 | Russell Hobbs 13153 Iron
I need manuel.
i want to change the flex with a more suitable cable/plastic, but i have difficultty inlocating the bottom fixtures on the back plate of the iron, its just to good of an iron to discard.
Jan 08, 2011 | Russell Hobbs 14084 Iron
Irons Logo
54 people viewed this question
Top Russell Hobbs Irons Experts
 Mikey
Mikey
ray gallant
Are you a Russell Hobbs Iron Expert? Answer questions, earn points and help others
