Question about ACT Heavy Duty Performance Street Clutch Kit Mitsubishi EVO VIII IX 03-07
My airconditiioner says "protect stop" and "I/U 000
Yamaha V-459 Receiver turns on & then turns off within 1 second. Where will I find the temperature sensor?
Thermal sensor is going to be a small 3-pin transistor-looking part that is attached to the power supply board and is pressed against the heatsink. Could be something as simple as bad solder connections on this sensor or the sensor might need to be replaced.
Jan 29, 2016 | Yamaha RX-V459 Receiver
How to change the timing chain for bmw 750 model 2007
Big job see me at www.autorepairhelp.us and will send info to you.
1131 052 - Replacing both timing chains (N62/N62TU)
1 Image ]
Special tools required:
-11 2 001 See: Toolsand Equipment/ll 2 000 Puller
-112 002 See: Toolsand Equipment/ll 2 000 Puller
-112 003 See: Toolsand Equipment/ll 2 000 Puller
-112 007 See: Toolsand Equipment/ll 2 000 Puller
1 Image ~j
Necessary preliminary tasks:
-Remove lower timing case cover See: Timing Cover/Service and Repair/Removing
and Installing Bottom Timing Case Cover (N62 / N62TU)
' Image [
Remove timing chain (1).
Remove timing chain (5).
Release screws (7).
Remove guide rails (3 and 6).
Remove tensioning rails (2 and 4).
Installation:
Maintain tension of timing chains when installing timing case cover.
Observe sparking protection on timing case cover.
Make sure timing chain (1) is correctly installed when placing it in guide rail (3).
1 Image ~j
Attach special tools 11 2 001 See: Tools and Equipment/ll 2 000 Puller and 11 2 002 See:
Tools and Equipment/ll 2 000 Puller to crankshaft.
Insert special tool 112 007 See: Tools and Equipment/ll 2 000 Puller and remove
sprocket wheel with special tool 112 003 See: Tools and Equipment/ll 2 000 Puller.
Installation:
Check sprocket wheels for wear, replace if necessary.
Heat sprocket wheel to 60 CC.
Warning!
Burning hazard! Wear gloves.
1 Image ~j
Assemble engine.
Sep 06, 2014 | 2007 BMW 750Li Sedan
Hi Yard Machines rear tiller looks like 216-430-000 but no numbers on mine. was running tilling fine when all of a sudden tines stopped spinning. When shifting to till feels like no positive engagement....
There is a SHEAR pin that could also be broken. It's there to protect the sprocket from breaking in the event of hitting a rock or something large while tilling. You will have to go to the MTD website who makes Yard Machines, to get the directions on changing the pin or the chain whatever the case may be.
Mar 06, 2011 | Yard Machines Tiller 208cc 18in Tilling...
Can I block 000-000-0000
REFRESH YOUR CELL SOFTWARE THIS IS A BINARY VIRUS TYPE PROB
Sep 21, 2009 | Cell Phones
I was watching my kp61v80 and the screen went black-can you give me the trouble codes for the flashing standby light
Diagnosis item
TIMER/STANDBY
Indicater
Number of blinks
Supposed malfunction Condition
Self-diagnosis
screen display,
Diagnosis item: Results
•Power not ON 0
[Standby Power Supply System]
F601 open.
R607 open.
Q601 short circuit
[Main Power Supply System]
IC601 and R612 are broken.
VDR601 short-circuit
Cannot turn on the power.
LED doesn't blink.
+B OCP detection 2times Short circuit of power supply system in each circuit.
Goes to the standby mode
Short circuit of +B line
2 : +B OCP 000
+B OVP detection 3 times
T603 pin 78 open.
R672 open.
Malfunction of power supply circuit
3 : +B OVP 000
Vertical deflection stop 4 times
IC1509(V out) is broken.
Q1505(V Pulse Buffer) is broken.
Raster goes to one line horizontally, Aand then video
signal is muted.
4 : V Stop 000
Video out abnormality detection 5 times
Video out, Q705, 732, 761 and others in C board
circuit.
Q218, 219, 220 (A board)
TIMER/STANDBY LED blinks approx. 30 seconds,
and then blinks for the self diagnosis.
5 : AKB 000
Horizontal deflection stop 6 times
C515, 516 open.
IC206(YC Jungle) is broken.
Raster doesn't appear. 6 : H Stop 000
Audio abnormality detection 8 times
IC406(Audio amp.) is broken.
PS401, 402 open.
The sound is not out.
8 : Audio 000
Jun 17, 2009 | Televison & Video
Nature 2 Model G pinhole leak in housing is misting a spray
turn off use plumbers putty or JB weld on inside let dry then try
Jun 11, 2009 | Zodiac Nature2 Professional G Model...
Error ##334 show up on display. what is it meant exectly ?
1. Press the "menu": Key
2. Press "Copy" Key
3. Press "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading or select (-) as a short-
cut to the last setting.
4a. Press “Set” and the display shows:
Test Mode [1] – [8]
CF-FH3 :WLD-11-02
4b. Press “8” and the display changes to:
Test Mode [1] – [8]
Please wait
***note*** you have to wait until the display changes
Then the display changes to:
8: PRINTER TEST
[2]---[8]
5. Then Press the "3" button and the display shows:
8 – 3 : EEPROM Clear
*** the display scrolls to [0] : INK COUNT
[1] : 2PURGE FLAG
6. Press "0" button – for INK COUNT
7. Press the "Stop" button
8. Press Off then On to set new changes.
9. Printer feeds a blank page after it is turned on again.
This should Reset the printer and remove the WRONG CARTRIDGE error and save you a few dollars.
Replace all the Ink Absorbers.
QA4-1012-000
QA4-1013-000
QA4-1014-000
QA4-1015-000
QA4-1055-000
Reset the counter to zero.
Replace the printhead. QY6-0042-000 (now QY6-0064-000)
Should cost you about $54 if in the US.
This will only work a few times. Eventually, it will fail to reset
and you will have to replace the Printhead. I hope this helps.
Nov 13, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Unwanted websites.
Download a good virus protection program and get a good pop-up blocker. Sites can't just access your pc. You probably have spyware or malware on your computer. A lot of times you will get this stuff from visiting those kinds of sites. I would recommend Nortons or Mcafee.
May 16, 2008 | Nokia Refurbished IP440 NETWORK SECURITY...
Speedlite 420EX lost a plastic part
Part number: CY2-1130-000 PANEL, AF LED
Check you local canon.com for spar part suppliers
Dec 10, 2006 | Canon Speedlite 420EX TTL Flash
ACT Heavy Duty Performance Street Clutch Kit Mitsubishi EVO VIII IX 03-07 Logo
54 people viewed this question
Top ACT Computers & Internet Experts
David Payne
David Payne
Thomas Perkins
Thomas Perkins
Are you an ACT Computer and Internet Expert? Answer questions, earn points and help others
