Question about Echo Garden
I have a echo pb755h backpack blower that has excessive oil in the air cleaner
  • 755 Answers
Your main jets check valve may be damaged or crudded up so that the minor backflow from the engine pushed fuel out the carb into the air filter. The gasoline part evaporates and leaves the oil behind. Hence the oily air filter. This condition might be remedied by using a fuel system cleaner or it may need to have carb service. If the carb is a cheap enough unit you may consider just getting a replacement if the backpack was a decent high dollar unit.
Be safe and good luck!
Posted on Nov 28, 2014
Testimonial: "Thank you very much. You know your stuff now that makes sense i will give that a shot."
  • 603 Answers
SOURCE: Echo backpack blower stops after 20 minutes
Make sure the fuel tank cap inlet valve is working properly, this will allow a vapor lock if it is not. Then check the fuel line in tank to make sure the pickup filter is not hung up in tank thereby allowing the fuel to get below the pickup. Also check the fuel line for holes. You can also try toro.com customer care, manuals and parts, type in model no. then get owners manual and see if in troubleshooting section it list this problem.
Posted on Apr 06, 2009
SOURCE: Need to replace fuel filter
Fuel filter is located inside the fuel tank. You have to make a hook out of about 10" of stiff wire (wire coat hanger works perfect) Hook end should be about 1/2" wide. Remove the fuel cap, insert the wire hook and snag the fuel supply tube with the filter attached to the end. Pull it back through the fuel filler opening, replace the filter and reinsert.
Posted on Apr 15, 2009
wilsodfarm
  • 986 Answers
SOURCE: what is the gas;oil ratio for the echo 403T backpack leaf blower.
50 to 1
Posted on Nov 01, 2009
rwvanlue
  • 486 Answers
SOURCE: I have an Echo Backpack Blower PB46-LN that is
This senerio is an 'over-rich' condition, most often caused by an improper fuel/oil ratio mix, and the 'exhaust screen' or 'spark arrestor' on the outlet of the muffler is plugged. Cleaning the screen may be all that is needed to correct the problem. **Make sure this screen is clean, and operate engine for at least 5 minutes before making any of the suggested adjustments below.
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
Overfuel or 'rich' condition
Basics to check:
b) is there spark
3) Check Air filter for fuel saturation
4) Allow engine to run for 5 minutes to excess fuel from muffler
5) Fuel mixture ratio: Make sure the oil mix is per your manufactures recommendations
6) If after the above the engine is still smoking and blubbering:
Adjust carb mixture screws to a 'less rich' setting
*NOTE: only move mixture screws 1/8 of a turn at a time,
and try operation before any more adjustment
Posted on Nov 12, 2009
Testimonial: "Now I guess its starting fine (on second hard pull), but, white smoke comes out while running and doesnt stop, also it makes a clackering noise while its running, what might these 2 problems be from?"
  • 430 Answers
SOURCE: ho spark on a pb 403t backpack blower
Be sure you have no spark ( 90% of the units that come into my shop for repair with the complaint of no spark- have a fuel issue). Be sure the spark plug is good.
If no spark then remove the ground wire from the module and check for spark again. You must use the recoil starter- spinning by hand is not sufficient. If still no spark then replace module. If there is spark with the ground wire disconnected then there is a problem with the kill switch or a bad wire.
Posted on Nov 30, 2009
Why is my echo pb755h blower is blowing oil out the carburetor?
this is a 2 stroke engine so it must be spewing Gas/Oil mix out of the carb.
Nov 27, 2014 | Echo Garden
Where is the fuel air mixture screw on a shindaiwa backpack blower
Look on the side of the carb. they are there. You will probably need to remove the air cleaner form the carb to see them and then you may need a special tool to adjust them due to the EPA covers on the screws. Hope this helps.
Jun 27, 2014 | Echo Pb265l 25.4cc Gas Powered 158 Mph Low...
Poured in the wrong oil/gas ratio into my Craftsman leaf blower. Stupidly poured entire 2-cycle oil provided directly into the blower reservoir and filled balanced with gas (Should've read instructions...
it only means your spark plug is covered in oil. I do not expect any damage. try and remove and clean spark plug maybe use some gas to wash the excess off. maybe put a small drop of gas into the spark plug hole and replace. this may help start the engine. what you need to do this flush out all the oil so that the correct mix can get in. Also ensure no oil has got into the air filter ensure that is clearn before trying to start it again.
I hope this was useful
Oct 31, 2013 | Echo Inc. 25.4 CC Backpack Blower
Echo 770t misfiring
I have installed new carb kit, fuel lines, plug, and air filter. Blower continues to bogg down when opening up throttle. echo 770 blower any ideas?
Aug 13, 2013 | Echo Backpack Blower PB-770T
I have an echo pb400e backpack blower. it wont start. getting fire but wont crank.
is your spark plug getting wet from fuel? try take air snorkel off carb and give it a shot of carb cleaner if it fires you have a fuel problem if it doesent fire , and plug is wet pull plug and rollover and get excess fuel out of cylinder, and try carb cleaner again, if no luck check compression, then if good go to flywheel and see if loose
Apr 12, 2011 | Echo Gas Blower 135 MPH390 CFM Blower...
What is the correct oil to gas ratio for an echo?
3 to 1.....3 parts gas to 1 oil
Nov 28, 2009 | Garden
Garden Logo
106 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
