Question about Vacuums
I have a jcbd hd3 drill that wont switch off , how do i fix this
Taken apart cleaned it and checked everything connected
  • 52 Answers
It needs a new switch if everything else appears to be working correctly.
Posted on Nov 27, 2014
I have a DC25 it works fine, my problem is when I switch It off it makes a horrendous noise like an airplane taking off. I have taken everything apart and cleaned everything but yet still makes funny...
It may be air whistling past the exhaust filter, which may need replaced. Try removing the filter to see if that could be where the noise is coming from.
Feb 12, 2015 | Vacuums
I have jcbd hd3 drill and it wont turn off when trigger released , how do i fix it
New trigger switch. It's sticking. Can of electrical cleaner may take care of problem. Slide between forward and reverse may be in question. Had that problem also and a generous cleaning with a spray took care of.
Nov 27, 2014 | Vacuums
I have a dyson animal d17 i have taken apart completly and cleaned all filters and clogs and i still have little to no suction and wont turn on in the upright position
With no suction you should check the venturis. They can become clogged if you suck up wet dust, wet cat litter, etc. You\'ll need a Torx Screwdriver to get it apart. See where that gets you.
Jan 07, 2014 | Dyson DC14 All Floors Upright Vacuum...
My Bissell powersteam powerbrush carpet cleaner wont spray water from the floor jets or the hose. Checked the belt, its doesn't look damaged, also took it apart and cleaned the floor jets, still nothing.
Check any related mechanical and/or electrical parts, including switched, levers, buttons, valves and all water-ways. Make sure all electrical connections are clean, functioning with a multi-meter, and all pieces are NOT broken or malfunctioning and clean. replace any broken or malfunctioning parts that you can't clean or repair.
Oct 15, 2013 | Bissell 1697W Powersteamer Pro Upright...
My foot pedal appears to not be working. I have taken it apart but cannot seem to see what needs to be done. How can I fix this?
It sounds like you are talking about the pedal that you step on-- On your Vacuum--- That turns it 'on' and 'off'-- am I guessing right?
You say you have taken it apart-- so what did you find?
Did you find the switch that turns the vacuum on and off?
There must be some linkage connecting the pedal with the switch-- does it all operate correctly?-- can you feel the switch action-- positively snap-snap?
Possibly the switch, (or a wire or limit device?) is not allowing the circuit to be complete all the way to the vacuum motor?
Please do some more trouble-shooting, and let us know what yo find-- maybe we can help you locate the problem-- but we need more input from what you are seeing, feeling, and hearing as you try to turn it on.
Let us know-- OK?
Mack B
Jan 23, 2011 | Vacuums
Reset button or Fuse on my Infinity?
Ok, I took it apart, cleared the clog out, and put it back together. It wouldn't switch to "carpet". Got no answer on my question. Took it apart again, only I went further. Took apart the bottom - brush out, all inside bottom parts out, cleaned all that part of vac. No clogs down there. Ran the carpet/bare floor switch back and forth several times while I had it apart. Put it all back together and it worked fine. Still didn't find a fuse or reset button...
Jan 09, 2010 | Vacuums
Dyson slim upright has lost suction via the power head , floor wand is working normal
its either the power head is clogged up with debree or the belt is broken. if the belt is broken it wont wisp everything up. Take it to a shop to fix. DONT TRY TO FIX IT YOURSELF~!!! dysons are very expensive and arent made to just be taken apart
Sep 11, 2009 | Dyson Vacuums
Reset button for Eureka 431 bagless upright???Where is it?!
If the red light is one the says "check brushroll" then you have to take it apart to find out what the problem is. It might be that the roll has too much stuff rapped around it so you have to take it out and clean. It could also be the rubber belt is not properly in place. Once you take the bottom off the belt should go on the far right side. Those are the only things i can think of. I have had mine for 3 years and have never seen a reset switch. Usually when my light comes on it is because there is a lot of hair rapped around my brush roll.
Jan 17, 2009 | Eureka 431A Optima Bagless Upright Vacuum
Bissell 1699 ProHeat Cleaner
If it is completely dead, then either a bad cord, switch, motor, or a broken connection, it will have to be taken apart to find the problem.
Aug 30, 2008 | Bissell 1699 ProHeat Clear View Upright...
Vacuums Logo
42 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
