Question about Vacuums
I have jcbd hd3 drill and it wont turn off when trigger released , how do i fix it
Taken handle apart and cleaned it out and made sure everything connected
  • 35 Answers
New trigger switch. It's sticking. Can of electrical cleaner may take care of problem. Slide between forward and reverse may be in question. Had that problem also and a generous cleaning with a spray took care of.
Posted on Nov 27, 2014
SOURCE: Dirt Devil Easy Steamer Deluxe
Follow the plastic extension that runs from the trigger through the length of the handle. This requires more disassembly that at just the trigger. At the end of the plastic extension you will find a triangular-shaped "ramp" that pushes against a "button" plunger that opens the valve that releases solution. When you release the trigger, the triangular ramp retreats and the plunger is supposed to be pushed back out by an internal spring in the valve. This plunger sticks because of accumulated soap from evaporated solution. Try cleaning that valve and plunger by running clean, hot water through the system OR replace the valve. In the future ALWAYS thoroughly flush the system with hot, clean water after using the machine.
Posted on Jan 24, 2008
  • 55 Answers
SOURCE: canister will not release
I've done that.
There is a stem that runs down the center of the cyclone that releases the bottom. You didn't get that stem back in place. The only thing you can do is pry it open, hope is doesn't break, and put that cyclone back together correctly.
I've never broke one, but I had to pull pretty hard. Thought I was going to.
Good Luck
Posted on Nov 26, 2008
  • 8 Answers
SOURCE: Water leaks where the hose connects to the trigger handle.
Be sure to get a good washer on with the connection. They're easy to buy at any hardware store. You can also put white plumbing tape around the threads before screwing them in to make it really fit.
Posted on Feb 21, 2009
SOURCE: vax carpet shampooer wont release shampoo
if you unscrew a bit on the base that allows you to take off the brush, you will see a black plastic strip with very small holes in it. These are where your shampoo comes out of. Take a needle and re-pierce these holes and it should work again. I have just sorted mine out. good luck .
Posted on Mar 08, 2009
  • 164 Answers
SOURCE: Water will not come out when i push on trigger
order the part from bissel see if that fixes sound like you know what wrong just need get part number from bissell.
Could be some kinda pump also thats bad not pushing out the water.
I got bissle heated one black it only problem the seals rot out the soap dispencer. if you want be cheeper on washing things you can water down dish soap ore laudry deterget on there unit and cost allot less 17 bucks for bottle soap water
Posted on Jul 25, 2009
I have a jcbd hd3 drill that wont switch off , how do i fix this
It needs a new switch if everything else appears to be working correctly.
Nov 27, 2014 | Vacuums
Vax rapide
I brought a rapide ultra carpet washer today , cleaned half of my front room brilliant then stopped spraying water using the trigger on the handle, as the handle comes off for easy storage I took it off, and what\'s happing is when you pull the trigger to release water a piece of plastic pushes on another piece ov plastic to release water and it was not working only by me pushing my finger on the other piece of plastic in side the handle bit, so mines going back ,
Aug 14, 2013 | Vacuums
My Hoover upright U5472-900 runs but there is no suction at all. I have taken it apart and thoroughly cleaned it.
Turn it on. Detatch the cleaning tools handle from it's mount. If it still has no suction, you have a plugged hose. Everything your vacuum does goes through that long hose. Take the 2 screws off where it attacvhes to the unit, then gently push a broom handle through it to release/loosen the clog. You should be able to see through the hose from end to end. Toys, tissue and pine needles are big culprets of clogged hoses.
Aug 31, 2011 | Hoover U5472-900 Upright Vacuum
Water will not come out when i push on trigger button. So water does not come out. I have taken it apart and cleaned it. The problem seems to be in the triggerI push on the handle to release the water.
Jul 24, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a Bissell Powersteamer & it won't throw out the water.
You can test the trigger to see if that is the problem. Take the two handle bolts out, gently pull back on the tool rack and slide the handle up off the unit. If you look down inside of the unit where the handle was you can see the valve that the handle used to actuate. You can turn on the unit and manually activate the valve with a long screwdriver. If it starts working then you know it was the upper handle.
Does it spray out the tools? If it does then you have a clogged heater. It is located in the lower handle and can be taken apart and cleaned out.
Good Luck
Nov 25, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Brush Bars won't turn
I borrowed a bissell 9500. It was filthy with the previous user's debris, including long and short black hairs, black goo from the swamps of hell, cat hair and dirt. I cleaned the whole machine (as mentioned in the online user's manual), pre-spotted my carpets, filled the appropriate fluid containers, and confidently turned power on to the 9500. The BRUSHES DIDN'T WORK ! After checking all belts, and other things mentioned in other solutions here on Fixya, I decided to check the trigger setup on the handle part of the cleaner. I unscrewed all the screws from the top of the handle down to the attachment holder ( there were seven screws). After that, I gently pried open the top portion of the handle in order to see down to the trigger. I gently pulled the trigger and, at the same time, repositioned it and the spring attached to it. Then, I put the screws back in, attached the power cord, turned on the power, released the handle's upright lock. When I did that, the brushes turned like they are supposed to. At that point, I felt like I'd awoken from a nightmare and, at the same time, been blessed by an unseen cosmic power. The rest is history. My carpets and upholstery are now as clean as when they were new. I hope this helps one or more of you out there with the "dead brushes" problem.
A solution submitted by:
Pierre Kunde
peter.kunde@gmail.com
Sep 15, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vax carpet shampooer wont release shampoo
Jun 01, 2008 | VAX Appliances Vacuums
No water spray
Does water shot from the hose when you depress the trigger? If it does, then the heater in the handle may be clogged and will have to cleaned out or replaced. If no water squirts out the hose, then check the bottom of the bucket, make sure the gasket or seal is on the auto-load on the bottom of the bucket and not in the hole. The red flow indicator cap may be loose or leaking air. Could have a clogged or pinched water line under the top housing.
Jan 31, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Hoover will not release water/solution
Maybe the reservior asm(#24). isn't working, when you push the trigger, it pushes a rod inside the handle to hit the reservior asm. so the water will release. Could be the rod isn't hitting the reservior asm. Maybe these pictures will help.
Dec 02, 2007 | Hoover H2800 Stick Wet/Dry Vacuum
Jul 15, 2007 | Dirt Devil Easy Steamer Upright Wet/Dry...
Vacuums Logo
46 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
