Question about Speed Queen AWS44NW Top Load Washer
Fabric softener won't drain into the spindle. It collects in the tray at the bottom of the dispenser. However, yesterday, a lot of it drained out of the spindle and collected at the bottom of the wa
Cleaned out the dispenser and tray thoroughly, including the drain hole in the center of the tray.
  • 52 Answers
Fabric softener is very sticky and if you use it often it will start to build up. I mix mine with hot water before adding to a load of laundry and I avoid using the dispenser if I can, simply adding it to the load after the tub fills.
Posted on Nov 27, 2014
    Problem Solver:
  • 30 Answers
You can also dilute the fabric softener with tap water which allows it to be more free flowing and distribute itself better.
I just moved into a condo that has the whirlpool #LHW0050PQ front load washer and when I arrived at the condo, I found that the fabric softener tray was clogged. It has fabric softener in it that...
The dispenser asm. has a tab in the rear of it,find it and push it and the dispenser tray will pull out to be soaked and cleaned in the kitchen sink. vinegar could soften it up before going at it with a soft scrub brush.
I hope this has helped you,
Gene
Aug 04, 2011 | Whirlpool LHW0050PQ Front Load Washer
F3 error on my whirlpool washer
The problem with the fabric softener not dispensing is not likely related to and F03 error code due to the washer not draining.
For the dispenser problem, I recommend that you pull the dispenser drawer out and clean it thoroughly.
The fabric softener dispenser works on a siphoning principle.
Make sure that the siphon hole in the dispenser is clear and not restricted or plugged.
You can fill the fabric softener compartment with water and make sure that it is siphoning properly while you are cleaning it.
Make sure that the cover is properly replaced on the fabric softener dispenser when the drawer is replaced in the washer.
You can use the diagnostic test described below to test the fabric softener dispenser.
If the softener dispenser does not fill and dispense properly, you could have a failed dispenser valve, a failed control board or a wiring failure between components.
You indicated that you tested the pump and that it is good. You could have a clogged drain hose or a clogged washer drain that would prevent the washer from draining.
You could also have a failed drain pump even though it runs. If the impeller is jammed or damaged, it will not pump out the water in the washer.
You will likely need to unplug the washer and drain the water out of the tub using a wet/dry shop vacuum.
To check the pump and drain hose at the bottom of the washer, remove the bottom front service panel and remove the drain pump. You may find a clog or restriction in the drain pump or connecting hoses. If the drain pump is damaged or will not work, it will need to be replaced.
Oct 11, 2010 | Whirlpool Washing Machines
Kenmore electric range gets a f1/f3 error code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 10, 2010 | Kenmore Slider/Casement Air Conditioner
Error code FO3 Kenmore washer #417.44072300
Oct 14, 2009 | Kenmore Washing Machines
Error message E3 on my Kenmore Elite Dryer
Oct 12, 2009 | Kenmore Elite 45986 Front Load Washer
I have a F 03 code.
Hotpoint aquarius wf 630 error code f-03 how do i fix
Aug 14, 2009 | Washing Machines
My Sears Kenmore washinging is getting an F03 code and will not drain - HELP
For the dispenser problem, I recommend that you pull the dispenser drawer out and clean it thoroughly. The fabric softener dispenser works on a siphoning principle. Make sure that the siphon hole in the dispenser is clear and not restricted or plugged. You can fill the fabric softener compartment with water and make sure that it is siphoning properly while you are cleaning it. Make sure that the cover is properly replaced on the fabric softener dispenser when the drawer is replaced in the washer. You can use the diagnostic test described below to test the fabric softener dispenser. If the softener dispenser does not fill and dispense properly, you could have a failed dispenser valve, a failed control board or a wiring failure between components.
You indicated that you tested the pump and that it is good. You could have a clogged drain hose or a clogged washer drain that would prevent the washer from draining. You could also have a failed drain pump even though it runs. If the impeller is jammed or damaged, it will not pump out the water in the washer. You will likely need to unplug the washer and drain the water out of the tub using a wet/dry shop vacuum. To check the pump and drain hose at the bottom of the washer, remove the bottom front service panel and remove the drain pump as shown in the second image below. You may find a clog or restriction in the drain pump or connecting hoses. If the drain pump is damaged or will not work, it will need to be replaced.
Jul 29, 2009 | Kenmore Washing Machines
Error code 03 what does this mean
Jul 09, 2009 | Washing Machines
Fault code
Apr 12, 2009 | Washing Machines
Speed Queen AWS44NW Top Load Washer Logo
168 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
