My liton usb dvd player has broken his all 4 vcc grnd rx tx broken i solder it bt cant run so can u solder ya replace it circuit?? How much cost it
  • 52 Answers
Did it work before u try to fix the rx tx?Cost it much! When ya solder ya replace it circuit, get ya a friend who be literate and explain directions good. Like when Luke was wantin to learn the force find Yoda he must.
Posted on Nov 27, 2014
I got a HP compaq nx 7010 for 6 years now and I have been noticing that USB is not working on it. I tried fix it with the help of some technicians but to no avail. Can you please help me to solve this...
1.if your USB connector isn't working it is due to a broken ground point on the mother board or a cold solder joint. Cold solder joint are from improper solder flow and releasing the soldering iron to early > resulting in poor contact with the trace points on the component placement.
2. the connector itself could be defective and needs replacement > female USB port have 4 connectors that have fine tolerance and if one is not contacting then the computer will not be able to see the connection > therefore rendering an error.
3. there is a 5v supply to pin 1 called(vcc)
check this site out for more information:
http://pinouts.ru/SerialPortsCables/usb_cable_pinout.shtml
Feb 09, 2011 | HP Compaq nx7010 Notebook
I have a tti cb radio but the wires have come away from the mic but i dont know what colours go to what number can you help
one should be a ground. look at the board were the wire is.. and its obvious that its a ground pin 1. then should have 3 remaining. one will be tx.. touch the others to ground to see which one makes it tx.. theres your pin 3 tx.. on a galaxy pin 4 is not used. thats rx pin4 cobra radios would have a increase in rx audio when this is connected to grnd. the last would be audio. once you find grnd and tx. reconnect mic and put to pin 2 audio. the last 2 wires that gives it audio..
Nov 05, 2010 | Galaxy Radios Microsystems DX98VHP CB...
Jwin/iLuv i277 Bluepin i110 rx mode doesn't work
Hello,i ve a problem with bluepin rx mode,how can i fix this problem,thanks
May 04, 2010 | Jwin I1155 Portable DVD Player with Screen
My computer does not have a 9 point serial port so i had to use a usb adapter instead. I can't communicate to the plc though. any suggestions?
The 9 pin serial port, dosen;t always have all the "lines" that are in the 15 pin. (obviously) normally ya need Tx, RX RTS, CTS. You need to find out exactly what lines are needed. Make sure via metering that they are all there. Also it may need to cross-over ie: Tx goes to Rx and Rx goes to Tx. Try using a Null Modem. OR try a USB to 9 pin Din serial adapter.
Jan 25, 2010 | Computers & Internet
The mic doesnt work ...it use to but all the sudden it quit doesnt even key up so i can hear it my talk back
First, try another mic on the radio to be sure it's the mic and not the radio causing the problem. If it's the mic, check the wiring circuits for a bad switch or broken wire. Simply...the TX circuit is closed and the RX is open when the key is squeezed. The RX circuit is closed and the TX circuit is open when the key is released. Use a simple ohm meter to check for resistance between the pins on the mic (after removal from the radio of course). Open circuit will read 1, closed circuit should be very close to zero. You'll probably find the TX circuit never closes when the key is squeezed. Could be a broken wire or faulty switch in the handset.
Also check...If the mic "keys up"...you see the meter move normally, but no voice...it's either a faulty mic element (the little round thing you talk into) or the audio circuit of the radio has a defective component which a good CB shop can replace.
Jun 14, 2009 | Astatic 636L Noise Canceling Microphone...
Yaesu FT-26 I got a Yaesu FT-26 that is used. The Problem by it is that its frequence between 140.000 and 148.000, i cant get lower or higher than, I cant even send or recieve anything!!! even when i press...
Same problem for me also blocking on the tape amateur 144/148 MHz not of emission nor of green reception led does not ignite malgres the modifs. Have a solution thank you
Feb 23, 2009 | Vertex FNB-27SM,...
I need to rewire my roadking 56
Hi and welcome to FixYa,
Pinout and mic wiring as follows:
  • 1 - mic - white
  • 2 - RX - black
  • 3 - TX - blue
  • 4 - Ch Up/Down - NC
  • 5 - GND - bare/red
  • 6 - Vcc (+13.8VDC) - NC
Good luck and thank you for using FixYa.
Feb 11, 2009 | Magnum 257 CB Radio
Trying to set up front usb ports on asus p4p800se
Find usb pin in the boad " USB1 & USB 2" You can see five pins in the board composed of two lines. connect the cable in the line composed of four pins. from left. VCC, Data-2 , Data+2, grnd2. After connecting try a Usb mouse if the USB mouse function well then connection is correct.
Jan 06, 2008 | ASUS Intel 815E Chipset TUSL2 (TUSL2 SWA)...
Audio settings
default values of the secret E370 audio menu by inputing *#8999*8378*
Normal
MIC gain - 0
Tx PGA - 70
Side PGA - 0
Ear gain - 3
HFR gain - 9
Rx PGA - 128
Rx vol - Lv 1 - 10
Rx vol - Lv 2 - 28
Rx vol - Lv 3 - 40
Rx vol - Lv 4 - 50
Rx vol - Lv 5 - 96
Rx comp - Lv 1 - 11
Rx comp - Lv 2 - 11
Rx comp - Lv3 - 11
Rx comp - Lv 4 - 29
Rx comp - Lv 5 - 30
Key vol - Lv1 - 64
Key vol - Lv2 - 64
Key vol - Lv3 - 64
Key vol - Lv4 - 64
Key vol - Lv5 - 64
Headset
MIC gain - 0
Tx PGA - 64
Side PGA - 0
Ear gain - 13
HFR gain - 3
Rx PGA - 128
Rx vol - Lv 1 - 10
Rx vol - Lv 2 - 20
Rx vol - Lv 3 - 42
Rx vol - Lv 4 - 76
Rx vol - Lv 5 - 146
Rx comp - Lv 1 - 11
Rx comp - Lv 2 - 11
Rx comp - Lv 3 - 11
Rx comp - Lv 4 - 30
Rx comp - Lv 5 - 28
Key vol - Lv1 - 10
Key vol - Lv2 - 20
Key vol - Lv3 - 42
Key vol - Lv4 - 76
Key vol - Lv5 146
Loud SPK SUP
MIC gain - 0
Tx PGA - 160
Side PGA - 0
Ear gain - 12
HFR gain - 5
Rx PGA - 120
Rx vol - Lv 1 - 16
Rx vol - Lv 2 - 27
Rx vol - Lv 3 - 45
Rx vol - Lv 4 - 76
Rx vol - Lv 5 - 128
Key vol - Lv1 - 1
Key vol - Lv2 - 2
Key vol - Lv3 - 3
Key vol - Lv4 - 4
Key vol - Lv5 - 4
Loud SPK SDN
MIC gain - 0
Tx PGA - 160
Side PGA - 0
Ear gain - 12
HFR gain - 5
Rx PGA - 120
Rx vol - Lv 1 - 16
Rx vol - Lv 2 - 27
Rx vol - Lv 3 - 45
Rx vol - Lv 4 - 76
Rx vol - Lv 5 - 128
Key vol - Lv1 - 1
Key vol - Lv2 - 2
Key vol - Lv3 - 3
Key vol - Lv4 - 4
Key vol - Lv5 - 4
Loud SPK EXT
MIC gain - 1
Tx PGA - 226
Side PGA - 0
Ear gain - 12
HFR gain - 5
Rx PGA - 92
Rx vol - Lv 1 - 16
Rx vol - Lv 2 - 27
Rx vol - Lv 3 - 45
Rx vol - Lv 4 - 76
Rx vol - Lv 5 - 128
Key vol - Lv1 - 5
Key vol - Lv2 - 2
Key vol - Lv3 - 3
Key vol - Lv4 - 4
Key vol - Lv5 - 4
Loud SPK Out Only
Tx PGA - 160
Side PGA - 0
Ear gain - 12
HFR gain - 5
Rx PGA - 120
Rx vol - Lv 1 - 10
Rx vol - Lv 2 - 28
Rx vol - Lv 3 - 40
Rx vol - Lv 4 - 50
Rx vol - Lv 5 - 96
Key vol - Lv1 - 1
Key vol - Lv2 - 2
Key vol - Lv3 - 3
Key vol - Lv4 - 4
Key vol - Lv5 - 4
Yamaha AMP vol.
31
Yamaha MEL vol.
Normal
Lv 1 - 6
Lv 2 - 12
Lv 3 - 18
Lv 4 - 24
Lv 5 - 31
Melody key
Lv 1 - 2
Lv 2 - 4
Lv 3 - 11
Lv 4 - 18
Lv 5 - 25
Power on/off
Lv 1 - 1
Lv 2 - 10
Lv 3 - 14
Lv 4 - 18
Lv 5 - 22
ISS Normal
Ear gain - 12
HFR gain - 3
Rx vol - Lv 1 - 121
Rx vol - Lv 2 - 186
Rx vol - Lv 3 - 268
Rx vol - Lv 4 - 376
Rx vol - Lv 5 - 564
Rx vol - Lv 6 - 802
Rx vol - Lv 7 - 980
Rx vol - Lv 8 - 1560
Rx vol - Lv 9 - 2167
Rx vol - Lv 10 - 2863
ISS Headset
Ear gain - 10
HFR gain - 3
Rx vol - Lv 1 - 164
Rx vol - Lv 2 - 328
Rx vol - Lv 3 - 492
Rx vol - Lv 4 - 656
Rx vol - Lv 5 - 820
Rx vol - Lv 6 - 984
Rx vol - Lv 7 - 1148
Rx vol - Lv 8 - 1312
Rx vol - Lv 9 - 1476
Rx vol - Lv 10 - 1640
Bluetooth
Tx PGA - 255
Rx PGA - 12
Side PGA - 0
Oct 04, 2007 | Samsung SGH-E370 Cellular Phone
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
