Question about Dryers
Samsung dryer dries clothes but cooling light staying on all the time
    Problem Solver:
  • 6 Answers
In the back of UR dryer try left or back bottom should be a reset bottom there
Posted on Nov 27, 2014
  • 210 Answers
SOURCE: cooling light on?
The cooling light is always on, it flashes when it is in that part of the cycle, sounds like he put it in to a test mode. Was it a thermistor that he changed?
No heat, sounds to me like a thermostat might be blown. Call the guy back, if you haven't already.
Sgt 48
Posted on May 31, 2008
  • 4 Answers
SOURCE: DLE5955 Tromm Dryer. We have had
Sounds like your outside vent is plugging up. Go outside your house and check for lint build up and just pull it loose with your fingers or a shop vac.
If it's not obviously plugged from outside, feel the volume it should be significant. If it's very weak (while running of course) your ductwork may be plugged elsewhere, for example at an elbow, or the joint between a flex hose and the actual duct.
Posted on Jun 26, 2008
SOURCE: samsung dryer is not drying and its new
It ended up being a easy fix. Our old dryer was working fine and had been ran an hour before I hooked up the new Samsung dryer. Therefore I assumed when the new dryer did not work there had to be something wrong with it. There ended up being nothing wrong with it and it was my dryer vent. It was barley plugged which caused it to not heat up properly. I was told that the new dryers have a lot more sensors on them and its very sensitive about needing a clean vent to vent out the heat. My vent was not very dirty, but it had just enough build up of lent in it, it caused the dryer to not vent properly and it would keep shutting the flame off. Blew it out with my leaf blower and now it heats up and dry quick. I hope this helps
Posted on Feb 15, 2009
  • 118 Answers
SOURCE: Not drying completely
try cleaning real good. also the heating unit might be bad
Posted on Aug 05, 2009
isaiahpro
  • 35 Answers
SOURCE: Samsung Electric Dryer
This may be a problem with your moisture sensor or the control that read the sensor. If it is under warranty have Samsung fix it for free. Make sure the cycle settings are correct before tinkering. First make sure the electronics are not too dusty. You could blow them off or vacuum them. Dirt particles can conduct electricity and make it read wrong. Next check the electrical connection for the moisture sensor. See if its location is in the manual. If it doesn't work after some tinkering asked the service for the dryer about possibly replacing the sensor but first try hard to get it to work.
Posted on Sep 21, 2010
All else appears to be working except the dryness level selection button does not light up and will not allow selection
How do I read the digital display panel and controls on my ...
www.samsung.com/uk/support/skp/faq/1025253
Samsung ElectronicsAug 12, 2014 - The Drying light will illuminate and remain lit until the cycle is ... the indicators will light up until you press the Start/Pause button. ... When you turn on your dryer the Cotton Cupboard Dry cycle is selected by default. ... Drying Level button ... If you do not turn the Drum Light off within 5 minutes of turning it on it ...
Dryer Control Panel And Functions - Samsung
www.samsung.com/ca/support/skp/faq/230147
Samsung ElectronicsJan 7, 2015 - To set Dry Level in the Normal, Heavy Duty, or other Sensor Dry ... An indicator light illuminates next to the selection. ... Temp Selection Button ... When using Manual Dry, you can select the drying time by pressing the Time Selection Button. Important: Clothes may not dry completely if the drying time is not ...
MACHINE OPERATION
docs.whirlpool.eu/_doc/501930002795EN.pdf
Material thickness: whenever there is greater load than the dryer can handle, ... Do nottumble dry: nylon stockings, delicate embroidery, fabrics with metallic ... The indicator lamp above the relevant button lights up to confirm your selection. ... Wait at least 5 minutes, to allow the laundry to cool down, before you unload the ...
501930001546EN.pdfDOWNLOAD
Jan 01, 2016 | Dryers
Samsung model dv5451 cooling light stays on
I am assuming when you turn it on, after couple of minutes goes off.
If you are on sensor drying and have no load or too little, then clothing might not touch the sensor enough (to show it is wet), and therefore microprocessor shuts unit down "thinking" everything is dry already. Try time dry.
Alternative: defective main board, sensor, wire harness.Call for service.
Dec 22, 2014 | Samsung Dryers
Cooling light stays on during dry cycle. no heat is to dry clothes. I've switched the circut breaker numerous times and unplugged the unit many times also to "reset" . What's next..
Try a timed dry cycle instead of an automatic cycle. If that works, then you will need to clean off the moisture detection bars inside the dryer to get the auto cycle to work again. Look for two curved metal bars, about 3/16 inch wide and 4 inches long, about an inch apart, located just inside the front of the dryer, near the right side of the lint filter. (you'll have to stick your head in the dryer drum to see them) Often times, use of dryer sheets will result in a waxy coating forming on these bars, preventing the dryer from detecting the moisture in the clothes. The dryer sees no moisture, it goes into the cool down mode and then stops. Clean the bars off, and you should be back in the laundry business.
Feb 05, 2011 | LG DLE7177 Dryer
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
DRYER WILL NOT HEAT UP. "COOLING" LIGHT STAYS ON CONTINUOUSLY.
You dry by sensor???
Clean your sensor. The machine thinks the clothes are dry because the sensor is covered with who knows what???
Check your owner manual for the proper way to clean the sensor.
I hope this works for you
a
Sep 25, 2009 | LG DLE7177 Dryer
Aug 05, 2009 | LG DLE2514 Electric Dryer
Clothes are taking 3 cycles to dry and cooling light on front wont shut off
The vent is clogged.  To make sure, disconnect the vent from the dryer and run the dryer normally.  If your clothes dry normally, then have a professional vent cleaning company take care of the vent.
The cooling light will always stay on during the run.  When it is blinking, the heat has stopped and is in the cooling process.
If there is no heating, you have a problem with the high limit switch or something else electrical and needs to be addressed by a qualified LG technician.
Oct 22, 2007 | LG DLE2512W Electric Dryer
Dryers Logo
82 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
