Question about Acer Aspire Computers & Internet
In my wifi dashboard wifi direct option is not working
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 115 Answers
Try this: Go to control panel, open Device Manager, look for Network Adapters & click the little arrow to open to show your adapters. Then right click the wireless adapter & uninstall it. If asked do not delete the driver. then restart your computer. It will automatically reinstall the drivers. PS if you recently did an update from Microsoft, that also could be the problem, you can try to do a system restore back prior to the time you started having problems & that will also fix if the other doesn't.
Posted on Nov 27, 2014
Testimonial: "by uninstall it my lappy may cause any disturbance how can i handle it"
How do you use WiFi direct on a Plt7100G?&
NOT a two way radio question. Please move to Tablets.
Jul 23, 2016 | Radio Communications
Wifi direct on my dell laptop
Is your dell laptop wifi direct capable?
Aug 29, 2013 | Dell Inspiron 1464 Notebook
WIRELESS OUT OF RANGE
Move closer. That's not always an option though. Here are some tips to improve the range of wireless routers:
1) Locate the router higher in the building rather than lower (1st or second floor is better than a basement location).
2) Place the router in a location that will offer the least resistance to the signals - it is easier to pass wifi signals through gypsum board than it is for concrete / brick or walls with aluminum siding on them.
3) Change the antenna(s) on the router to a type that offers more gain. Typical router omni directional antennas offer 3dB to 5dB or gain - there are others that offer 7 dB or more of omnidirectional gain for reasonable prices. The antenna gain works for both transmit from and receive to the router.
4) if the device you wirsh to connect to the router is in one place, consider a directional Yagi antenna. These antennas concentrate the entire wifi signal in a direction that is 30 degrees wide and can allow the signal to be seen 5, 6 or even more times further in one direction - instead of being spread out over 360 degrees. These antennas cost a little more, but can solve the problem quickly.
5) Replace the manufacturer's stock firmware of selected routers with a 3rd party type such as DD-WRT or Tomato. Either of these will work with your Linksys WRT54G router. One of the benefits is the ability to boost output power of the wifi radio in the new settings the firmware offers. Read about both and decide if either is something you're comfortable doing.
6) Add additional wifi routers configured as a bridge or an access point to extend the wifi signal into an underserved area. DD-WRT supports bridging as shown here.
I hope this helps & good luck!
Jan 30, 2013 | Linksys Wireless-G WRT54G Router
How to connect rtb10223 to wifi ?
http://www.manualowl.com/m/RCA/RTB1023/Manual/194353
According to the manual above it only has Ethernet capabilities, meaning you need to wire it directly, if it is possible at all to go WiFi you would need to get an adapter to do so.
May 16, 2012 | RCA Audio Players & Recorders
How to play radio on BB bold 9700
if you have wifi at home and you use a laptop to surf, then you can do the same with your berry. it should automatically connect to your router when you run a scan. se the wifi forum for more help
to main wifi setting do it though options/advanced/browser as it doesn't always save when you do it through options directly in the browser.
3g/2g - browsing only a real reason to need if you are at work and don't have net access or you are out and about and want to check something on the net quickly
Feb 24, 2012 | Cell Phones
How do i switch on wireless on an acer 6935G please
Dear user,
normally there is a switch on the front or at the side that needs to to pulled in one direction to put WIFI on, at the same time you will see the logo of wifi on screen indicating status as ON/OFF.
this will work provided you have not disabled WIFI from the networks and settings options
May 12, 2011 | Acer Computers & Internet
How to reupdate my psp
if you have wifi: turn on your psp, on the xmb (main dashboard) go to the far left option (settings) scroll up twice and click network update, it will take you through the update process. if you don't have wifi: you need to download the official firmware package, then put it on your memory stick in a folder you create called UPDATES (in all caps!!!), then turn on your psp and the update will be under games in your xmb.
Feb 20, 2011 | Sony PlayStation Portable (PSP) Slim...
How do i hook up the netgear to my laptop
you'll have to first connect the computer to the dsl/cable modem via ethernet cable, then connect the modem to your computer directly, then access the configuration page of the router and set the wifi settings including security option (WPA, WPA2, WEP, Shared), then open the wifi adapter settings on your laptop and make sure the security option and security key are entered correctly. disconnect the ethernet cable from the laptop to the modem and test the connection.
Sep 27, 2010 | Lenovo 3000 G530 Notebook
Excellent signal low speed transfer
You can boost the signal range of a WiFi computer network in several ways: Answer:
  • reposition your router (or access point) to avoid obstructions and radio interference. Both reduce the range of WiFi network equipment. Common sources of interference in residences include brick or plaster walls, microwave ovens, and cordless phones. Additionally, consider changing the WiFi channel number on your equipment to avoid interference.
  • upgrade the antenna on your router (or access point). WiFi antennas on most wireless base stations can be removed and replaced with more powerful ones.
  • add another access point (or router). Large residences typically require no more than two APs, whereas businesses may employ dozens of APs. In a home, this option requires connecting your primary wireless router (access point) to the second one with Ethernet cable; home wireless routers and/or APs don't normally communicate with each other directly.
  • add a bi-directional WiFi signal amplifier to wireless devices as needed. A WiFi signal amplifier (sometimes called "signal booster") attaches to a router, access point or Wi-Fi client at the place where the antenna connects. Bi-directional antennas amplify the wireless signal in both transmit and receive directions. These should be used as WiFi transmissions are two-way radio communications.
  • add a WiFi repeater. A wireless repeater is a stand-alone unit positioned within range of a wireless router (access point). Repeaters (sometimes called "range expanders") serve as a two-way relay station for WiFi signals. Clients too far away from the original router / AP can instead associate with the WLAN through the repeater.
Nov 19, 2009 | Sony Computers & Internet
Not english
Note If the current language setting of the Dashboard is in a language other than English, the following steps will still work but you may not be able to read the menu options. If this is the case, you must follow the directional pad instructions exactly to make sure that you select the correct option.
  1. Start your Xbox console with no disc in the disc tray. The Xbox Dashboard appears.
  2. On the Main Menu screen, press the directional pad (D-pad) down two times to select Settings, and then press the A button.
  3. On the Settings screen, press the D-pad down one time to select Language, and then press the A button.
  4. On the Language screen, press the D-pad up or down to select the language you want, and then press the A button.
  5. Press the B button to return to the Main Menu screen.
Jan 17, 2009 | Microsoft Xbox Console
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
