How can i reset my passwoord? i need to change the vat % of my register. thanks in advance
Due change of the tax in the netherlands, i need to change the vat %. when i want to do this, it gets an error E009. this means i need a password. thing is, i bought the register secondhand. and i dont know the password. anyway to bypass/reset? Thanks in advance. Jorden
  • Eugene Rounds Nov 27, 2014
    Hi jorden Hopp, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Please the make and of your register. It may be very well still have the default password which I would try first. As the other options will probably delete a lot of the other programming just depends on the register setup.
  • jorden Hopp
    jorden Hopp Nov 27, 2014
    thanks! its the casio ce-T300. i have tried searching the internet, for a defualt password. but i found none. i hope you can help me.
  • 1,169 Answers
Don't if you got of the Owners manual but it looks like you can reprogram the password in the general control file. Page 55.
Casio-CET-300.pdf
Good luck as it has been a time since worked on cash registers.
Posted on Nov 27, 2014
  • 55 Answers
SOURCE: I need to change the sales tax rate for my cash register.
Please find below the solution:
Non-printing models (also applies to HR-8TE printing calculator):
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds
3. Press [TAX+]
4. Input the tax rate
5. Press [SET/%]
Printing models (except HR-8TE):
1. Have calculator in "print" mode
2. Press [CA]
3. Hold [SET/%] key for about 3 seconds
5. Press [TAX+]
6. Press [SET/%]
Posted on Mar 19, 2009
SOURCE: need to change tax rate on a Casio tk-6000/6500 register
turn key to PGM
1 CLK# 3 SUBTOTAL 0125 SUBTOTAL 8.75 CASH 0 CASH 5002 CASH SUBTOTAL
turn key to REG1
8.75 is my tax enter your tax instead. make sure to put the decimal point.
Posted on Apr 21, 2009
greg_margo
  • 1959 Answers
SOURCE: Tax rate on sharp xe-a102
To change/program the tax rate, use the following procedure:
  1. Turn key to Z/PGM position
  2. Press 8
  3. Press #/ST
  4. Press A
  5. Press #/ST
  6. Press 2 (Auto Tax)
  7. Press #/ST
  8. Press 097500 (9.75%)
  9. Press #/ST
  10. Return key to normal mode
This procedure should program your tax rate at 9.75%
  1. Press #/ST
Posted on Jul 28, 2009
  • 22 Answers
SOURCE: how do I change the tax amount for Sharp XE-A101 cash register
9 => SBTL => Tax Number (1-4**) => @/TM => R => @/TM => Q => CA/AT/NS
"R": TAX RATE (0.0000% to 99.9999%) x10000
(Enter the rate in 6 digits. Leading Zeros may be ommited)
"Q": MINIMUM TAXABLE AMOUNT (0.01 to 99.99) x100
(Smallest amount for which tax must be collected)
**Up to 4 types of tax are programmable
Hope this helps!
Posted on Sep 10, 2009
SOURCE: Casio PCR-T2000A Cash Register
i have a casio cash register pcr-t2000a and i keep getting an error code e 026 enter condiment then preperation plu no matter what i do i cant seem to get it fixed it wont let me use the register with this code
Posted on May 26, 2010
Wan to canche vat from 18 to 19 percent
You need to follow the table for tax rate programming. If you use multiple taxes, set the rate for tax1, tax2, or tax3 etc. Most VAT is done via tax1 only. If you have lost your manual, most cash register manuals are here http://the-checkout-tech.com/
Jan 10, 2014 | Casio Parts Cash Register PC Desktop
Where do I go to find an on-line manual for TI 5045 Sv Texas Instruments calculator?
TI-5045 SV
ii
English.............................................................. 1
Fran?ais ............................................................ 6
Espa?ol ............................................................. 11
Portugu?s ........................................................... 16
Examples, exemples, ejemplos, exemplos .............................. 21
ILLUSTRATIONS ¦ FIGURES ¦ ILUSTRACIONES¦ ILUSTRA??ES
Removable tab
Languette
Leng?eta extracci?n
Alavanca usada para o rolo
Ink roller
Rouleau encreur
Tamp?n de tinta
Cartucho de tinta
English
Your Texas Instruments calculator has a built-in printer for producing a permanent record printout of
your calculations with negative numbers printed in red. A big, easy-to-read display also enables you to
check entries or perform quick calculations without printing.
GETTING STARTED
OFF ON PRT IC GT
POWER
1. Connect the calculator to a proper power outlet (110-120V or 220-240V
where available).
2. The calculator is turned on by setting the POWER switch to the PRT
position.
Inserting the paper (see illustrations 1, 2, 3, and 4 on page ii).
1. Turn on the calculator.
2. Open the printer compartment cover by pressing down on its front edge and sliding it back in the
direction of the arrow.
3. Fit the roll of paper on the holder so that it unrolls from the bottom, with the loose end toward the
calculator.
4. Cut the end of the paper squarely and insert it firmly into the printer slot on the back of the
calculator.
5. Press & until the paper is in the printing position.
Replacing the ink roller (see illustrations 5 and 6 on page ii)
1. Turn the calculator off and tear off the excess paper.
2. Remove the printer cover by pressing down on both sides of the front edge and sliding back in the
3. Remove the old ink roller by lifting it with the removal tab.
4. Insert the new ink roller into the compartment and press down gently until it snaps into place. Close
the printer compartment.
Note: The old ink rollers should not be refilled. Replacement rollers can be obtained from your local
retailer. The warranty does not cover ink roller replacement.
SELECTION SWITCH SETTINGS
OFF ON PRT IC GT
POWER ROUND
: 5/4 9 + F 0 2 3
DECIMAL
TAX
SET CALC
Set the POWER, ROUND, DECIMAL and TAX switches as required.
Note: The TAX switch is spring-loaded to return to CALC when it is moved to SET and released.
The switch settings are summarized in the following table:
SWITCH SETTING FUNCTION
POWER ON
PRT
IC
GT
No printout is provided; however, the display can be printed by pressing
4.
The printer provides a printout of your calculations but does not count them.
The printer is on and an item count of additions and subtractions to or from
the register is printed when sub-totaled or totaled.
The GT position controls whether or not the totals from the independent add
register are accumulated in the grand total register.
ROUND Rounds the result of a calculation to the selected number of decimal places.
5/4
9
Truncates the result to the selected number of decimal places.
Rounds the result up or down according to its value. For example, when the
DECIMAL switch is set to 2, the result is rounded up if the third decimal
position is 5 or more and rounded down if it is 4 or less.
Rounds the result up to the selected number of decimal places.
Ex. 220 P 6
Setup: PRINTER: PRT, ROUND: :
DECIMAL: 2, TAX: CALC
Ex. 220 P 6
Setup: PRINTER: PRT, ROUND: 5/4
Press Display Printout Press Display Printout
2 0. 0¦ C
220 ' 220. 220¦ P
6 3 36.66 6¦ =
36¦66 ?
2 0. 0¦ C
220 ' 220. 220¦ P
6 3 36.67 6¦ =
36¦67 ?
DECIMAL + Add mode: All results are given with two decimal places. For addition and
subtraction only, a decimal point is automatically placed to the left of the last
two digits entered, unless the number already includes a decimal point.
F Floating mode: Any results are displayed and printed with the maximum
0 2 3 4 Fixed decimal mode: Sets the number of decimals to 0, 2, 3, or 4.
TAX SET
CALC
Lets you enter a tax rate to perform tax calculations.
Stores the tax rate. Pressing ! or " after a tax rate has been entered,
adds/subtracts the stored tax rate to/from the value in the display.
Ex. VAT = 17.5 %
100 + VAT
Ex. VAT = 17.5 %
235 - VAT
Setup: PRINTER: PRT, DECIMAL: F, ROUND: 5/4, TAX: CALC
Move and hold the TAX switch to SET. Press 217 L 5 and release the TAX switch. It
automatically returns to CALC. 17.5% is printed.
2 0. 0¦ C
100! 117.5 100¦
17¦5 @
117¦5 ?
2 0. 0¦ C
235" 200. 235¦
N35¦ @
200¦ ?
Note: The most common setup is POWER: PRT, ROUND: 5/4, DECIMAL: 2, TAX: CALC. Use these
positions for the examples unless other settings are given.
KEY DESCRIPTIONS
Basic keys
I Clear Entry: Clears an entry, enabling you to enter another number in its place. Note
that this key does not clear the add register.
2 Clear Key: Clears the add register, any pending operations, and the display. 0.C is
printed. Does not clear the memory.
( Right Shift: Deletes the right-most digit entered from an entry before an operation key is
pressed. Shifts the remaining digits one place to the right.
L Decimal Point: Enters a decimal point.
4 Date/Non-Add: Prints a date (such as 12¦10¦96) or a number for reference purposes.
Does not affect calculations. This entry is printed on the left side of the printout, the date
or number preceded by the # sign.
& Paper Advance: Advances the printing paper.
Addition and subtraction keys
9 Add: Adds a number to the add register. Displays the cumulated result.
: Subtotal: Gives the intermediate total from the add register. Using this key does not
affect the contents of the add register.
. Subtract: Subtracts a number from the add register. Displays the cumulated result.
E Total: Gives the total from the add register, and then clears the register.
Multiplication, division, percent and margin keys
? Multiply: Multiplies the number in the display by the next value entered.
' Divide: Divides the number in the display by the next value entered.
3 Equals: Completes any pending multiplication or division operation.
> Percent: Calculates percentages, ratios, add-ons (e.g. of VAT), or discounts.
# Gross Profit Margin: Calculates the selling price of an item when its cost and gross
profit (or loss) margin are known; also used to obtain a price excluding VAT.
Ex.
Cost: 594
Profit margin: 40%
Press:2 594 # 40 3
Answer:
Selling price: 990
Gross profit: 396
Ex.
Selling price including VAT: 252
VAT %: 20%
Press: 252 # 20 . 3
Answer:
Selling price excluding VAT: 210
VAT: 42
/ Grand Total: Gives the grand total of the operations previously performed and stored in the
Grand Total register. Every time a total is obtained with E it is cumulated into this register
(printout shows G+) which is only cleared when / is pressed twice. During long
calculations, if / is not used, this re
Jan 16, 2011 | Office Equipment & Supplies
I can't find any instructions in the operator's manuel on how to reprogram VAT from 17.5 to 20% on my casio CE4000. Can anyone provide easy instructions?
It depends upon a few things. Does your country use add on (tax added at the end) or add in (tax included in price). Which tax number is the machine using (1 to 4) for VAT?
Dec 30, 2010 | Casio Parts Cash Register PC Desktop
Change tax on casio pcr-360 cash register
Bingo!! that's right. The steps are :-
KEY PGM
3 SUB-TOTAL
0125 SUB-TOTAL
( New Tax ) CASH
5002 CASH
SUB-TOTAL
KEY REG
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jul 11, 2010 | Casio Parts Cash Register PC Desktop
Setting the VAT calculation function
Press and hold SET button untill set appeares.
Presa TAX RATE batton, enter requred tax. Press set button.
Job done!
Dec 22, 2008 | Office Equipment & Supplies
Casio TE-2000
VAT is value added tax which is straight percentage. program tax one or two for the percentage and make sure your departments are set up taxable or non taxible. prgm 2 is vat probably and program 1 will be for dept. generally with casio.
Dec 08, 2008 | Casio Parts Cash Register PC Desktop
CANNOT PROGRAMME THE VAT AMOUNT INTO CASIO TE 2000
Hi.
Has it had the system options set for tax? Was it calculating previously? Usually you just need to change the rate when you have a tax increase.
Mark
Nov 27, 2008 | Casio Parts Cash Register PC Desktop
Casio MS-120TE tax rate
How do I program tax rate into my calculator?
1. Press [AC]
3. Press [TAX+]
5. Press [SET/%]
Nov 26, 2008 | Office Equipment & Supplies
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
