Question about Ricoh MPC3500
I have moved my ricoh mpc3500. Now the paper will not go into the finishing unit. can you tell me what to look for?
  • Ricoh Expert
  • 398 Answers
Unplugged finisher? does it cycle when turned on?
Posted on Nov 30, 2014
    New Friend:
  • 79 Answers
Try to disconnect all the paper trays, clean the rollers that pick up paper and reassemble the unit
Posted on Nov 27, 2014
5 Suggested Answers
M2Tech1
  • 313 Answers
SOURCE: I need to change the waste container on a RICoH
look at the front of the machine pull out the first tray and then to the left is a smalll panel the screw for this is located at the top if you take out the screw the panel will open and the bottle is in there you can empty this and put it back in our replcae with new
Posted on Jun 12, 2009
  • 990 Answers
SOURCE: detach RICOH SR790 Finisher
Hello sir; Open the finisher door on the mid of right hand side ther have a cross bar fasten by one screw, loose the screw pull out the cross bar, it will detach from the machine.
Posted on Aug 14, 2009
Testimonial: "Thank you very much for your assistance. Simple when you know how ! WOuld be nice if Ricoh supplied this type of information direct to people."
  • 161 Answers
SOURCE: error codes SC548 ricoh mpc3500, how can you
The error means - Fusing unit rotation error.
Check if the fusing unit(right door{hot unit}) ,if it is rotating properly.
There could also be a sensor on the frame or the machine which senses the fusing unit rotation,(the sensor sometimes comes off)(remove the fusing unit and check where the fusing unit is seated).
Also try cleaning the sensor with a blower or brush.
Posted on Feb 16, 2010
  • 161 Answers
SOURCE: error codes SC580 ricoh mpc3500, how can you
Is the supply voltage ok?
The problem is to do with the IH inverter (it is part of the fusing unit).
Any cables loose?
Posted on Mar 16, 2010
Ricoh mpc3500 fuser unit setting error
Most common problem is the electrical connector on the fusing unit or the connector that the fusing unit connects to inside the machine is broken. So when you push the Fusing Unit in to the machine the connector moves out of position and doesn't connect properly.
Aug 01, 2016 | Ricoh MPC3500
Why is our ricoh mpc4500 printing blotchy pictures?
Hi Jennifer;
just find out which color make the blotchy, go to replace that color drum cleaning blade, it should take care your problem.
Jun 18, 2014 | Ricoh Aficio Mpc4500 Mpc3500 Yellow...
Add toner black stays on
Sensor needs to be replaced or toner was spilled inside the unit covering the sensor.
Feb 21, 2014 | Ricoh MPC3500
Service code sc520
Paper tray error.Try reset by open/close the front door,if not reseting enter in the service mode :press mode(yellow)key-107-Clear/Stop(red)key (keep pressed more 3 seconds) enter in SP mode,open the front door and turn OFF the copier.Wait 1 minutes and turn ON.
Mar 27, 2013 | Ricoh MPC3500
Error code J001 shows up after a jam
ricoh mpc3500 paper jam j001 which sensor ,no have inside paper
Jul 06, 2011 | Ricoh Aficio 250 Copier
Ricoh error code 741
Hi
SC741 means 1,000-sheet Finisher Error in Saddle. You'll need to check the Stitching Area, Optional Paper Tray Unit. If the tray unit is fine then check the stitching area as well for any paper stuck or bits of paper If there is no paper then it is due to LCT Main Motor Error. You'll need to check the LCT motor whether it is jammed or not. Hope this helps...
Daniel
Sep 30, 2010 | Ricoh Office Equipment & Supplies
Error codes SC580 ricoh mpc3500, how can you solve?
Any cables loose?
Feb 16, 2010 | Ricoh Office Equipment & Supplies
Error codes SC548 ricoh mpc3500, how can you solve?
Feb 13, 2010 | Ricoh Office Equipment & Supplies
I have a AFICIO MPC3500, AND A AFICIO MP3500, I
Hello sir; You needto pull out belt unit,replace cleaning blade in the cleaning unit.
Jun 23, 2009 | Ricoh Office Equipment & Supplies
Ricoh MPC3500 Logo
42 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
