Question about Cajun Injector Double-Door Xl Electric Smoker
Cajun injector electric smoker stopped working
Won't turn on
  • 52 Answers
Check for power at your outlet; a tripped GFI or a tripped breaker in your panel box may be the cause if the outlet is dead. If the outlet is good then you know it is the electric smoker.
Posted on Nov 27, 2014
Why has our oven stopped working whilst cooking - nothing electrical seems to be working?
Did you check your electrical breakers? Maybe it tripped. Reset it by first switching it fully to the off position, then switch it to on.
Feb 29, 2016 | Ovens
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Nov 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Ge oven jtp18 elements won't heat
The limit switch in a Ge oven usually works or is blown. I would look at the oven sensor located at the back of the oven. It should read approximately 1k ohm at room temperature.
http://www.on-timeappliance.com/ovenrepair.html
Mar 26, 2012 | GE Profile JTP18 Electric Single Oven
My frigidaire oven wont stop beeping and it has a f9 code
Hi
F9 is a door lock error and to solve this issue you can hold the light switch for 15 seconds, this will reset the control. If it won't work then hold the light switch in and set the unit to clean and after a minute press cancel to cancel the clean cycle. If still it won't work then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 24, 2011 | Frigidaire FEB27S5A Electric Single Oven
My oven stopped heating, and the range element won't turn red when you turn it on but it does have some heat coming from it. What's wrong with it?
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101 [
Aug 08, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
The display reads OFF on both ovens, I have never seen this before and the ovens won' work
This means you have turned the oven OFF The solution is to hold down both of the Cancel buttons for about 10 seconds and the oven should turn back ON.
Nov 21, 2010 | Dacor ECD230 Epicure Electric Double Oven
Frigidaire won't stop beeping f1 style
HI, this is a electronic oven control board failure code.
Replace this damaged electronic oven control (also called EOC or clock). It has failed.
Aug 13, 2009 | Frigidaire FEB27S5A Electric Single Oven
Ge Electric Double oVen
This may be related to a problem I have helped others solve. The solution is available free at my website. I have at last count helped over 1000 oven owners with a similar problem. http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf Hope it works for you too.
Aug 09, 2007 | GE JKP45 Electric Double Oven
Cajun Injector Double-Door Xl Electric Smoker Logo
297 people viewed this question
Top Cajun Injector Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a Cajun Injector Oven Expert? Answer questions, earn points and help others
