Question about Kenmore 49069 Electric Double Oven
What does this message mean on my stove: EO14 and beeping
I can't do anything; message is on and I cant do anything to fix it
  • Kenmore Master
  • 5,166 Answers
The E0 14 error probably means that the control panel (clock) is not able to communicate with the touch pad. Trip the circuit breaker to off for at least 60 seconds. If the error recurs, you need to check the wiring between the control panel and the touch pad. Make sure that the wiring harness is tightly connected on both side. Check for any breaks in the wires. If there is no obvious problem with the wires, replace the touch pad.
Check the full model number of the double oven. The parts may be available here: http://www.searspartsdirect.com/ .
I hope this helps.
Posted on Nov 28, 2014
Message on Control pad: EO14
EO= Electronic Oven Control on digital ovens...Oven key pad has problems...You will have to call the service people..It is not user servicable problem
Nov 27, 2014 | Ovens
-it gives a display message F5 (where normally the clock time is) and beeps; i can't see anything wrong with it though. what does the error message mean? it is a Maytag gas stove Model CRG9800BAB or BAE (I...
• The F5 error code indicates that the oven sensor has changed its resistance value and has failed to read the oven temperature correctly.
• If you choose the repair the range yourself it is fairly easy to do.
REMOVE POWER to the range and then open oven door and locate the pencil like probe protruding from the back of the oven cavity near the ceiling.
• Locate and remove the screws that are holding the sensor to the oven liner.
• Carefully remove the sensor and connecting wire harness to the point were you can get to the connector. Install new sensor and re-install into oven liner.
• Note!(some sensors have a harness plug and some have ceramic wire connectors).
Here is a link to the part you need.
Jan 31, 2011 | Maytag Ovens
My stove (Caloric) keeps making a clicking nose when all burners and the stove are turned off. I would appreciate any suggestions for how to fix this
This means that the oven has detected a condition it needs to check. Press "Cancel" to clear the display and to stop the clicking sound, then try turning the oven off and on again. If you still note the sound turn off the power to your oven and wait five minutes before turning it on again. If you hear the beep or see the any code when you try to bake or broil again,
then you will have to open the oven to solve the problem by checking on the panel carefully if there is any over flow of water on the panel or the element will need to be replace.
thanks.
Sep 29, 2010 | Stoves Ovens
Can you tell me what an F1 error Message means - 30 minutes into baking, I got beeping and an F1 error message. Canceling did not turn the oven off and the only thing I could do is turn it off at the...
"F1" code clearly indicates that main control board has failed. The possible fix for this kind of problem is you have to replace the faulty circuit board. This is the only solution and you cant repair anything else in this unit when F1 flashes.
Thank you !!
May 30, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
The stove just says F1 and beeps won't let me do
Hello with the limited information and no make or model I can only give a generic response to this one. Most manufacturers F1 code indicates a bad control board (EOC) and or a bad touch-pad. If you have any other questions please feel free to comment. Mike
Nov 03, 2009 | Ovens
F4 comes up on my stove, keeps beeping what to do
Sorry to say you will need an engineer to check the heat sensors as they may be faulty
Sep 21, 2009 | GE Ovens
F1 error message on kenmore gas range
The F1 usually means a problem with the touchpanel. It is also related to the F7 problem. I have developed a fix which may solve you problem. Please go to the following link for my fix.
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared my fix with over two thousand unhappy GE customers. Most report success. Please let me know if this works for you too. I am making a statistical study of this problem.
Regards,
Powerman
hutchipop@yahoo.com
Dec 05, 2008 | Kenmore Ovens
"F1" error code on Magic Chef gas range Model 3488XRA
the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
Jan 03, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Oven failed to work; F5 error message
please tell about the make & serial no. of oven.
Sep 30, 2007 | Ovens
Kenmore 49069 Electric Double Oven Logo
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
