Question about Makita Saws
How to remove turn base from base on a Makita LS1011 Slide Compound Saw?
I have dismantled the saw and the turn base is still connected to the base but I can't see how to separate them. I have removed the screw which goes through the turn base into the base. Swivel point in base turns with turn base.
    Sergeant:
  • 206 Answers
If you have removed the kerf boards and the center bolt the saw will lift straight off the turn base. It is possible the aluminum is deformed a little, but it will pull straight up and off if that bolt is out
Posted on Jan 05, 2015
joboo1
  • 257 Answers
SOURCE: Makita LS1011- when power is turned off there is a
Hi, Thanks for getting back to me, sorry for not making it clear but it was a 2 part question. I have a LS1011N and assumed it would have an electric blade brake like mine. When the bearings are bad it doesn't take long to also wear out the brushes so the electric brake not working full time is a symptom of that failure. Since yours doesn't have a brake then you are right in half of your guess of the gears the other half would be bearings. The only way I know to tell with the thing still assembled is to hold a screwdriver to the rear of the motor case and put your ear on the handle and run the saw and listen for the sand like sound of a bad bearing. If you don't hear anything like that it has to be worn gears and for that you have to look. Good Luck, this should Fixya!
Posted on Mar 18, 2009
rowdy45176
  • 2176 Answers
SOURCE: Compound Mitre Saw Motor turning, spindle isnt.
I have went to 3 different sites and cannot find the model number listed on them, I did look at a Ryobi saw and they indicate it is an assembly. but before I did that I would try and removing the gear from the spindle. It is possible that when it spun it put a burr in the parts and you would have to use a little extra effort to remove them I would suggest going to a repair shop and having them press them apart and see what you canfind that way. Sorry I couldn't find more for you
Posted on Aug 21, 2009
rowdy45176
  • 2176 Answers
SOURCE: I just acquired an LS1011 Makita saw. How does
unscrew the handle in the front to change, also I would recommend going to Makitatools.com and typing on your model number to download a users manual for this tool, it would be helpful to get the most out of it.
Posted on Oct 25, 2009
rowdy45176
  • 2176 Answers
SOURCE: How do I remove the threaded rod from beneath the
if you removed the handle from the rod you would need to put a pair of pliers on it gently and remove it. or if you turn it upside down and remove the tube from sliding mechanism you can grip the rod from there and unscrew
Posted on Mar 26, 2010
SOURCE: makita LS1013 compound saw wont slide,instruction
You may find, you have a lock, button, that needs to be held in, before you can drop the saw to cut.
Posted on Apr 28, 2010
Makita L1011 compound sliding saw with sticky miter table
The LS1011 doesn't have a table angle release lever like the newer models so it's harder too swing the table from angle to angle, this also causes the plastic swing body to crack. Have you loosened the locking screw for the table? The table may have to be removed and the pivet shaft greased. I had this problem with an old Makita Table Saw 10" 2600.
Feb 01, 2013 | Saws
Change blade Makita LS1030 10-Inch Compound Miter saw
There is an 8mm bolt on the front of the guard. Loosen/remove this and the central guard mount will drop slightly. Behind the metal guard is a slide lock for the blade spindle. Push the lock bar and turn the blade untill it catches and is held solid. Then remove the blade fixing bolt and bobs your uncle. Alternativly, with all mitre saws, you can just pop an old bit of wood on the work base and then use the spannrer/allen key supplied to turn the blade so it bites into the wood as if you are trying to cut it. This will hold the blade steady and you will also be turning the bolt in the right direction.
Jul 23, 2012 | Makita 10" Miter Saw LS1030N
My saw is really stiff when you try to change the angle .I oiled it but this didn't help. I would like to know how to take it apart but I am un sure how to do it and what is in the boxed off area...
Exploded diagram with parts list for LS1016 10" Dual Slide Compound miter saw is here.
Owner's manual is here. If these aren't quite what you need, you can view other models of Makita miter saws, here.
One thing to bear in mind. There's a miter angle lock and a slide lock on the bottom front of the saw. If you don't have the miter angle lock loose enough, it will be difficult to turn the saw.
If this answer was useful, please vote for it. Thanks!
Apr 14, 2010 | Makita 10" Dual Bevel Sliding Compound...
How do I remove the threaded rod from beneath the turn table of a Mikita LS1013 Slide Compound Mitre Saw ? I have removed the two black turning/tightning handles but cannot see how the rod is removed.
Mar 25, 2010 | Makita 10" Dual Slide Compound Miter Saw...
Oct 25, 2009 | Makita 10" Miter Saw LS1030N
Saws Logo
170 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
