My dvd player keeps blowing the T1.6 AL fuse (internal fuse), when i push the Power ON switch, any solutions? Thanks.
Replaced the fuse twice, turned on the power at mains, pushed the power switch in and it has blown the fuse each time.
  • 3,368 Answers
There are millions of DVD players out there. Before somebody can help you you need to give us the make and model number. You have the unit and know what it is, we don't.
Posted on Nov 27, 2014
Testimonial: "Gil, sorry thought i had include make and model, Make:Cambridge Audio. Model:DVD55"
kimberleykid
  • 5 Answers
SOURCE: Channel short
Hi there, sounds like you may have a short to ground on the output transistors. Does it have transistors or an IC output. It is most likely that you have not replaced a mica washer or insulator. Check to ground with a meter from the case of the output devices.
Posted on Aug 28, 2007
Thumbsmagee
SOURCE: peavey classic 50/50 keeps blowing fuses.
Rob,
I have a classic 50/50 as well and re-tubed it with JJ el84s, vintage teslas and mullard 12at7s. As long as you replaced it with EL84s, I can't imagine that the output would be increased enough to damage the OT. When I got my 6505 Combo, one of the 6L6s was bad, and it kept blowing fuses and howling like a banshee. I would think that an OT problem would result in a significant loss of output...or none at all. I've gotten DOA tubes from a few places. I would suggest swapping each tube out 1 by 1, until you find it...if that is indeed the problem...before you pay the cash to have it worked on.
Posted on Oct 29, 2007
SOURCE: NAD C350
Take a ohm meter and measure resistance from emiter to collector should have a few kilo ohm on output transistor.
If no ohm meter available , remove output transistors from circuit.
note position of transistor . you have a NPN and a PNP for each channel.
Replace fuse and power up. If fuse blows check bridge in the power supply.
80% of the time output transistor burn and blow the fuse.
before replacing output transistors check driver transistors they probably burnt also
Posted on May 04, 2008
  • 4 Answers
SOURCE: my old mission cyrus amplifier has blown both
It is common for manufactuers to label the fuses on the circuit board as to their values. If they are not labeled there you can try contacting the manufactuer or looking in your manual. You can tell if they are slow or fast blow by the internal wire, if its thin and straight its a fast blow, if its thicker and spiraled its slow blow.
Posted on Jun 06, 2009
  • 226 Answers
SOURCE: Peavey valveking 212 - no pilot light on power on
Hi, are you saying , the sound is very low?
Are the valves ok and do you have the correct voltage going to the heaters?
Looking at the diagram, are the valve mounted directly to the PCB's, if so go over the solder joints and make good any dry joints.Very common in all valve amps.
Check for any leaking or bulging capacitors, a capacitor checker will come in handy here, just measuring them with a meter is not really good enough..
I am still looking at the schematic, so bare with me as i'n not really a valve person, but i'm gonna help.
Regards - Anthony
Regards - Anthony
Posted on Mar 03, 2010
My 5.2t Horizon Treadmill turns on, but as soon as I push the start button it blows the fuse to the outlet. I tried re-setting the breaker about 6 times and then I started smelling smoke. I opened the
First of all, never reset a breaker more the once. If it trips twice it's not going to magically, "heal " if you keep resetting it.
Two possibilities. Bad breaker or internal short in the machine.
Replace the breaker with one not tripping and then check out the machine for shorts.
Just switching out parts is a less specific and more costly solution.
Aug 10, 2014 | Horizon Exercise & Fitness
Clock fuse radio ele mirrors dvd player keeps blowing kia sedona
Same thing happened to me. My DVD player stopped working and the 15A fuse for Power 1 kept blowing. Turns out that there was a little metal ring that had fallen into my powerpoint connection on the dash. It was shorting out my DVD player. Removed the ring, installed a new fuse and DVD player is back up and running.
Feb 21, 2013 | 2006 Kia Sedona 2.9
JD-VD502 DVD player blew a fuse. I replaced it with a 1-amp 250 volt from radio shack but as soon as I powered on, the fuse flashed and blew again. I tried twice, same result. Is there a reason this keeps...
Hello
Never put any fuse in it and switch ON. It has some short with internal circuit, and should be repaired before installing a new fuse. The fuse use is as a protection device to protect the other circuit parts from further damage. If you will put an other fuse, and switch it ON again, you are making things more worse than present. Find out the reason for buring out fuse. If you can do it by yourself. Otherwise get it repaired by any experienced service personal. Never make it irreparable. OK.
May 07, 2011 | Jwin JD-VD502 DVD Player
When I plug the unit in and try to turn it on, nothing happens. toshiba sd-3980 dvd player
The internal fuse is blown.
It may be a replaceble glass cartridge fuse, or a fuse soldered to the power board.
Unplug, remove top cover, check and replace fuse. Radio Shack has reasonable coverage of fuses.
But - fuses usually blow for a reason. It could have been a power surge; it could be an internal failure. If the new fuse blows, it needs professional replair. Many of these are so cheap to make that it doesn't pay to repair them - replace it if the repair estimate is over 1/2 the replacement cost.
Nov 01, 2009 | Toshiba SD-3980 DVD Player
BLOWN FUSES IN THE POWER CORDS ON MY PVS72901
you can get fuses from almost any electrical shop, just take the blown fuse with you, give it to the shopkeeper and ask for a new one. The fuse might be blowing because,
-if you have a fan it might be blocked,
-the DVD Player gets switched on and off,
-The device its connected to might be malfuctioning.
HOPE THIS HELPS!
Jul 13, 2009 | Audiovox PVS72901 Portable DVD Player
Removed and replaced internal fuse - unit is now dead
Hi
The chances are that you bridged the printed track with a splash of solder when you replaced the regulator. A short circuit like this will cause the fuse to blow. You can get replacement 20mm slow blow 2amp fuses quite easily. But before you fit a new one, pull the board out again and have a very careful look under a magnifying glass at your solder joints. Get a small stiff bristle brush and carefully brush across the joints in case there is a tiny ball of solder across two points. When you reassemble the unit, ensure that the ribbon connectors are central and fully pushed into the sockets. I'm sure you can recover your DMR E55 reasonably easily. Best wishes
Dec 21, 2008 | Panasonic DMR-E55 DVD Recorder
LG DVD PLAYER THE FUSE IN SIDE KEEPS BLOWING I WENT OUT AND BOUGHT THE SAME FUSES BUT STILL HAVE THE SAME PROBLEM
Depending on the model most LG dvd players use SMPS Power Supply (Switch Mode) when a fuse pops it could be a regulator causing the reburst of replacement fuses better off buying the SMPS as a whole from the Vendor
Nov 25, 2008 | Televison & Video
Problem
If the AC power source (outlet) is ok and the line cord and fuse are ok but the unit is completely dead, you may have a problem with the internal switching power supply.
Locate the switching power supply and see if there is a fuse on its circuit board.
Completely dead units are typically caused by a failure in the power supply section.
Please let me know if I can be of further assistance to you.
- Jim
Mar 06, 2008 | Sony SLV-D360P DVD Player/VCR
Nexxtech DVD Slimline model DP3222
Could be an open internal fuse or power supply failure
Jun 04, 2017 | NexxTech DP3222 DVD Player
 Grubhead
Grubhead
