Question about Watches
I cannot measure heart rate during or after the exercise as it shows locked.
None
  • 3,368 Answers
A bit more information is needed like make and model. I just measure mine for 10 seconds and multiply by 6. That way I only need the second hand or equivlant.
Posted on Nov 27, 2014
escapement
  • 2334 Answers
SOURCE: I have a mio euorfit heart monitor watch. During my workout I
Yes, you definetely need battery replacement.
As the hart rate monitoring is most sophisticated part of the device, it has more IC (Integrated Circuits) than any other features.
More IC's means more power is needed, so, if the heart rate monitor is starting to malfunction, that's the very first sign of underpowered battery.
Find your nearest watch repair shop and ask for battery replacement.
Do not forget to rate, please.
Posted on Jan 23, 2009
  • 2976 Answers
SOURCE: Timex heart rate monitor does not keep correct BPM. I changed the battery, now the heart rate hovers in the 30' and 40's, never getting to the correct BPM
Make sure the back of the watch is spotless and your skin isn't too dry.
Posted on Apr 23, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Inaccurate Measurements of heart rate
Replace the battery. Then make sure that it is placed on the proper artery that it is supposed to be on. If your heart rate was 210 you would be in the hospital with a heart attack. And also the only person I know with a heart rate of 90 when running is Lance Armstrong. Your heart rate should be about 120 to 135 and it will just around in those areas but should never go higher
Posted on May 22, 2009
escapement
  • 2334 Answers
SOURCE: Polar F6 - Heart Rate zeroing out during workouts
Use this link and reset your Polar F6 completely:
http://www.polar.fi/en/support/downloads?product=&category=User+manuals
Rate me, please.
Posted on Jul 31, 2009
escapement
  • 2334 Answers
SOURCE: Ive just had a new battery in the watch and went
You have to sync your watch. Browse through my tips and you will find link for manual for your POLAR watch.
Posted on Aug 04, 2010
How do I use the gear fit
You go to the Samsung Fit app and you should find many options for running, heart-rate...etc.
Nov 06, 2014 | Samsung Gear Fit
Tip
Trouble with heart rate monitor reading heart rate.
Can't get a heart rate to show on your heart rate monitor? If there are no other issues with the watch, then most likely what you are experiencing is an issue with the Heart Rate Strap.
It is very common for all brands of heart rate monitors to have issues with measurement.
The #1 reason is poor contact with the strap and your skin. - Make sure the contacts are wet and touching the skin with good contact.
#2 reason - Weak battery, may need to replace.
#3 reason - Sensors on strap have salt build up from sweat - Clean the strap and contacts with soap and water, if deep cleaning is neccessary use a q-tip and some rubbing alcohol.
#4 reason - Strap is too low on the body, raise as high on the chest as possible to just under the breasts. Strap too low will cause a weak signal.
If none of these seem to help, then you should contact an authorized repair center or the customer service for your brand, and see about possible repair or exchange/ return.
on Dec 06, 2010 | Watches
It appears my F6 monitor is not keeping accurant time on calories and heart rate. I like the watch but while checking my sitting heart rate is very low. When checking the heart rate on a blood pressure...
First you need to understand that the Polar system is a medical grade device and it is calculating calories based on specific information that you have inputed and heart rate data from your heart.
Most treadmills and other exercise machines use a much simpler counter that is height and weight based to calculate calories and are generally over generous with their numbers.
Depending on the blood pressure machine you are using, the pulse (not heart rate) is coming through the brachial artery, again not quite as accurate as measuring r-r variance from your heart. There is a ton of literature you can read if you are into the accurateness of the system, but I will sum up with saying that you actual calorie expenditure will be closer on the Polar than on most other devices outside of a hospital. As too the heart rate this is also true, so more likely you are getting inaccurate numbers from the other devices.
If you want pinpoint accuracy then you will need to use the Polar RS800 or S810 devices that measure and display true R-R.
Jan 12, 2011 | Polar F6 Wrist Watch
I have Sportline S7 Heart Rate watch with no manual. This model is not listed as an option at www.sportline.com I need to know how to set the time. I also need to know if it has the capability to of sound...
In checking out information about my new S7 ECG Heart Rate Watch, I noticed your posting. There is a Sportline website that enables you to down the product manual.... although I'm not sure it pertains to the S7. If this doesn't work, I'm sure there is a manual included with the watch I just received, and I'd be happy to email to you. I'll check back to see if you've posted a response here to see if the below website worked for you first. Posted 7/11/2010 by Mary G.
download product manual - HEART RATE WATCH 7. HELPFUL HINTS IN MEASURING HEART RATE. 8. SETTING THE WATCH FUNCTIONS ... stylish LED Heart Rate Watch measures ECG accurate heart rate with the simple ..... HEART RATE WATCH. Sportline® is a trademark of SPORTLINE, a division ...
http://www.cbs.sportline.com/manuals/SP4421IS01SPO1.pdf
May 18, 2010 | Watches
Sportline S7 HRM watch users guide?
To get a manual for your monitor, go to "sportline.com",
Select "products" and then "see products" in heart rate monitors.
Go through the list of models to find yours and then click on "learn more".
Details of the monitor will be shown and you then click on the tab marked "manual".
Download your manual.
Jan 27, 2010 | Watches
Wrist watch- at times the watch isn't showing
Manger de la marde vous êtes des crosseurs!
Vous mériteriez d'être poursuivis pour faire perdre tant de temps aux gens, pour vous approprier les solutions que les bonnes gens trouvent et ensuite faire de l'argent avec.
Oct 26, 2009 | Polar A5 Wrist Watch
Do I have to wear my transmitter to review calories burned?
Without knowing how hard you have exercised (heart rate) it wont be able to calculate how many calories you have burned.
Andy
Sep 10, 2009 | Polar F4 Heart Rate Monitor Watch
Rate me, please.
Jul 30, 2009 | Polar F6 Wrist Watch
Jan 23, 2009 | Mitac Mio Fit Heart Rate Watch
Polar F6
It sounds like most of you have the heart rate set to display in % of max heart rate. Most Polar products have the option of heart rate in BPM(beats per minute) or percentage of max.
If you look at the display during the exercise, you will see a % icon. You can turn it off in by hitting the back button and go down to HR view settings.
Hope this helps.
Chris @ Polar USA
Aug 02, 2008 | Polar F6 Wrist Watch
Watches Logo
19 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
