My icraig slimbook clp289 wont play music or record my voice it shows its playing and sound is on volume is full no sound
    Sergeant:
  • 399 Answers
Try listening using headphones; maybe the speaker is damaged or defective.
Posted on Dec 21, 2014
  • 317 Answers
SOURCE: apple ipod nano wont play the full song
First make sure your hold switch isn't on. It's on the top or bottom and slides back and forth. It needs to be switched to the left. Once it is to the left, here's how you reset:
You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
Posted on Jan 09, 2008
  • 476 Answers
SOURCE: wont play music
Although the connections are very similar, the iHome is probably only for and iPod, and not compatible with Philips MP3 players.
The only dock I know of that is compatible is the AJ300D
Posted on Feb 08, 2008
SOURCE: DISK ERROR WHEN I TRY TO USE MP3
I had the same issue and just connected the device to my computer USB connection and performed a quick format on the drive and it now works. You will be warned that reformatting the drive will erase all the data, which will happen. But you can simply reload your music and be back in business... Rod
Posted on Apr 19, 2008
ThaMp3Doctor
  • 8596 Answers
Double check p. 17 of the manual for a firmware upgrade, in case this message is caused by a db corruption, but the error may also be caused if your player is in the "lock" or "hold" position.
Link to the only manual on Centon's low-budget website:
http://www.centon.com/documents/mp3guide.pdf
-Tha Mp3 Doctor
Posted on May 29, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: redgroove digital mp3 player voice recorder
PC does not recognize player - sure you used the right driver?
Code 41Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)Recommended resolution
A driver was loaded but Windows cannot find the device. This error occurs when Windows does not detect a non-Plug and Play device.
If the device was removed, uninstall the driver, install the device, and then click Scan for hardware changes to reinstall the driver. If the hardware was not removed, obtain a new or updated driver for the device.
If the device is a non-Plug and Play device, a newer version of the driver might be needed. To install non-Plug and Play devices, use the Add Hardware wizard. Click Performance and Maintenance on Control Panel, click System, and on the Hardware tab, click Add Hardware Wizard.
On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard.
Posted on Jun 26, 2008
Still having problems with the clp289 still freezing and skipping programmes.Tried resetting and hard reset still have the same problems
hard reset wont help too much in this case .. you need to check the services, firmware and drivers .. if that does not help, then you need a technician.
Call 1-877-805-1027 for Toll Free expert help.
Nov 15, 2015 | Computers & Internet
WHY WONT IT RECORD OR REPLAY - THE MACHINE RECORDS TIME BUT THERE IS NO SOUND
try plugging in an external microphone, if that works and it records then the microphone element in your machine is bad or a wire has broken off of the microphone
Apr 13, 2015 | Philips Pocket Memo LFH9370 Handheld...
When I hook up my computer to the receiver and play music it is hard to find a point on the master volume where the music plays clearly. The music skips and i have to be very careful with the master...
Master volume control pot is dirty and needs to be cleaned out. You can do this by unplugging the receiver and turning the master volume control back and forth from zero volume to full blast a couple of hundred times to clean the surfaces and restore normal operation.
Aug 24, 2017 | Pioneer VSX-509 Receiver
Not playing full recording
Maybe it's the preview play option of the player that you are using. It only plays a part of the recording for you to identify if it is the right recording that you are trying to find because the recorded allows you to record more than one file.
Sep 30, 2008 | RCA RP5010 Digital Voice Recorder
No sound,no working mic...not even showing on my voice tab in control panel
Just a couple of questions that might help you solve your problem..
- Have you already installed the sound driver of your motherboard/sound card?
- Have you properly inserted the right color/jack of your headset to the computer?
- Have you check the volume control of the headset whether it is in mute or full volume?
If you have tried the above questions then you might have a defective headset.
To test if it is working, try playing some music & the sound recorder for you mic.
benson
Jan 29, 2008 | Logitech (980158) Headset
Sometimes voices are low on playing of music/films
hello Mike
Well, it sound to (recording ) on each songs, depending on how it record, if happen only with some , it is no problem but if all songs you play happend then its a problem with the drivers, or program to control your music, try to down a notch on control panel the hardware acceleration. it solve a lot problems of this kind, or reinstall the drivers for the sound card.
Good Luck
Nov 20, 2007 | Logitech X-530 Computer Speakers
89 people viewed this question
 Grubhead
Grubhead
