Question about Dryers
Hi I have a Beko dcu 8230 dryer the drum spins but the heater doesn't get hot so changed that same problem changed the PCB board still the same cleAned the sensors still not getting hot any advice thanks
    New Friend:
  • 31 Answers
Check the braker it lost a leg
Posted on Nov 27, 2014
    New Friend:
    Problem Solver:
  • 5 Answers
You hav to press the on button four 20 seconts
look at this
video it may help
AlmostBob
  • 550 Answers
SOURCE: Very hot at back, making humming noise, but drum isn't spinning.
the drive belt is likely broken
belt replacements for most models are simple and cheap
have no experience of bendix cannot give exact instructions
Posted on Nov 03, 2008
SOURCE: Beko tumble dryer not drying.
is there a reset button on a beko tumble dryer drvs 62 w pls
Posted on May 14, 2009
erpaalai
  • 999 Answers
SOURCE: kenmore dryer will not tumble
Can you hear the motor running? It could be a broken belt or something else if the motor is not running. Would need more info to go further.
Eric
Posted on Jun 20, 2009
  • 3074 Answers
SOURCE: hi i've got a hotpoint condenser dryer it's
the belt may be off/broken, motor bad, or idler assemblage.
Here is a website with the routing of the belt the Hotpoint is( General Electric (GE) - Large Capacity Models 1970-1990):
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
how to replace the belt:
http://www.ehow.com/how_6100255_replace-hotpoint-dryer-belt.html
Posted on May 08, 2011
oldTech2332
  • 2341 Answers
SOURCE: When i tried to turn
Those symptons (humming/buzzing ¬ starting) are 99 out of a 100 times a sign of a motor that has locked up.
Gene
Posted on Aug 07, 2011
Testimonial: "nice"
Beko dcu 7230w no heat
thermostats...........
cheers
Jul 24, 2017 | Dryers
My beko condenser sensor dcu 8230 doesn't dry my reset button won't click
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or
overheating.
The heating elements are located inside the heater ducts. If you think a heating element is faulty, test it with avolt-ohm-multimeter (VOM)set to the RX1 scale. Disconnect the leads from the power terminals and clip one probe of the VOM to each terminal. The meter should read about 12 ohms. If the reading is higher ohms, the heater is faulty and should be replaced. Replace a faulty heater with a new one of the same type and electrical rating. A heater connected to a 115-volt line usually has an 8.4-ohm resistance; a heater connected to a 220-volt line usually has 11 ohms resistance.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
OR you may have a broken centrifugal switch in the motor because this switch activates the motor and the heater as well. supposed to be if the motor does not run , the heater should not heat in order not to create fire but if the motor is not running, and the heater is still heating, then there could be a problem with the motor centrifugal switch that is connected to this interlock switch that should trigger the heater.
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum 9 this is why in some cases the dryer will operate at lower cycles like gentle or low heat but not at higher settings?)
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :
http://www.ehow.com/info_12203962_check-dryer-thermistor.
GOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
How to Check Dryer Thermistor eHow
Dec 10, 2016 | Dryers
Beko sensordry 6kg gets hot on sensordry programs but won,t get hot on timed programs and keeps stopping and starting, any ideas please?
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!!
Feb 13, 2015 | Dryers
How do I replace the small belt in a beko dcu 8230 condenser dryer
I'm not familiar with this one specifically but typically you just need to loosen the tensioner, pry from the under side of it with a large screw driver.
Feb 02, 2015 | Dryers
Tumble dryer drum making a noise spinning
hi take top off hold back of drum see if u can pull it up if you can feel play its more than liklely the bearing wot dryer is it
Feb 13, 2014 | Beko Dryers
My beko washing machine wont spin ive replaced pcb board but to no avail if anyone can help much appriciated
Hi christophe if your beko wma10w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Oct 30, 2012 | Washing Machines
Dryers Logo
229 people viewed this question
Top Dryers Experts
