HOW TO FIX COLD WATER NOT ON LIGHT WHICH IS COMING "ON"
TURNED COLD WATER TAP ON
Check the hose isnt kinked
also at the valve input on the rear is a small plastic filter inserpt
you can bull it out carfully with pliers
if this cant help then the solinoid valve has probably failed
of the switched supply to it on the controller board
Posted on Nov 28, 2014
beltronic205
  • 1467 Answers
SOURCE: Whirlpool WFE1070BD washing machine. The water tap
Could be dirt in the inlet valve remove the hoses and check/clean filters @this section.
Posted on Apr 05, 2010
  • 11800 Answers
SOURCE: cold water not flowing into machine.But ok coming
Check the intake valve, most likely it was blocked by concretions.
Posted on Jan 03, 2010
  • 1028 Answers
SOURCE: Maytag Front Load Intellisense 6.5kg
washer may not be detecting water temp but water flow ..if you never use hot water may try hooking cold water to a Y-connector and then hooking to both hot and cold inlet valves ..however it is also possible washer is detecting inlet temps in which case you're out of luck ..i suspect the latter
Posted on Sep 01, 2008
  • 713 Answers
SOURCE: Cold Water extremely slow to fill. Had same
sounds like both valves r faulty .try cleaning inlet hose filters and if that doest work must b valves. buy and change cold first to save u money,if u dont use warm often.please reply 4 more help.p/s turn off power b4 working on unit dont want any acciedents.
Posted on Apr 09, 2010
marka19
  • 1430 Answers
SOURCE: Hi there, I just bought a second hand hot point
no problem at all using only cold. Most washers only will fill with hot water after that all other cycles use cold.
Posted on Jul 21, 2010
Testimonial: "great. thankyou"
Why is there water coming from base of cold tap in bathroom when turned on. When turned off it's dry.
Possibly coming from neck of tap, slyly creeping its way down via the body, then appearing to trickle off the base.
Ifthe O-ring at the top end of the tap is worn, or the shaft-wot-the-handle-fits-onto is worn, then water flow can cause some water to be pushed upward, via the top section.
Try tightening the top nut clockwise.
Jul 29, 2017 | Water Water Heaters
WI815 Intuitive Eco - no cold water
IW Intuitive Eco.
Water valves have a rubber diaphragm that wares out
after some time,
So yes you are right water valves need replacing.
Apr 21, 2014 | Fisher and Paykel Washing Machines
I just installed a new Monsoon mixer tap with a single lever that lifts backwards for water pressure and swivels from side to side for temperature control. While the hot water side of the tap works 100%...
Start with the pipe that extends out from the wall where you hooked up your cold water connection.
Get your self a large container and many rags or towels.
Gently loosen the connection to see if there is any water coming out of the wall pipe.
If not, there is your problem.
If so, you have something plugged up or wrong with the hose or the faucet.
Remember, normally a person will turn off the water at both valves under the sink when the replace a faucet.
Those valves are where most of your connection hoses go.
A valve can be broken or stripped, so that it will not turn on after you have turned it off.
God bless your efforts.
May 26, 2017 | Home
I have a Fisher Paykel washer that was leaking water into tub; repair people changed cold water valve but it is still leaking; although not as much. Could it be the nozzle spray holding droplets of...
Hi just read your posting.1st try turning the hot water tap off and see if the water continues to come into the tub.If the water continues to come into the tub then turn the cold tap off.If the water stops coming into the tub after the hot water tap is turned off then you need a hot water valve.If the water stops after the cold tap is turned off then the cold water valve is still faulty.Please reply on how you got on and I will help you further.Looking forward to your reply.
May 16, 2011 | Fisher and Paykel Washing Machines
Whirlpool AWO/D4305 Washing Machine. The "Water
Providing that the tap is turned fully on AND the hoses are not kinked or squashed at the back, this is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs a service call ;-0(
Good luck,
John C
Mar 27, 2011 | Washing Machines
When water is turned on hot is okay but cold barely come on
Hi it sounds like the head inside the tap has worn, if it's a single tap then turn of the water supply, open the tap to ensure no water coming through then remove the head with a adjustable spanner turning anti-clockwise. take to a plumbers merchant and they will give you a replacement. There cheap enough. Put the new head back in and re-instate water supply. Turn on that tap to clear any air then your done. Thanks Paul.
Aug 31, 2010 | Delta Faucet Plumbing
Whirlpool washer duet
The FH means water tap closed. If you were happy with using cold only you could get a Y-piece connector and join both the red and blue inlet hose to the cold tap.
Apr 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
No stop tap. cold water coming through cold taps in caravan but no hot water the carver cascade water heater is getting the water hot but it just wont come through the taps in the shower room or kitchen in...
your pipes are clogged, what if you were to not turn on the cold and turn on the hot does any water come out at all, with just the hot side turned on,, if not there could be a valve that has been turned off, or the pipes are clogged
Jun 17, 2009 | Reliance & 40 Gal Mobile Home Water Heater...
Whirlpool Duet washing machine - no cold water comes in when I put it on cold cycle
Check the tap is turned on
if not fix
turn off taps, check the lint screen inside the hose end (tap connector end) is not blocked
if not fix
check cable connections on cold water solenoid valve inside rear of case
if not fix
replace cold water solenoid.
cold water solenoid valve fails more often than hot, is used on every cycle so bnurns out first.
unplug washer and turn off water before checking cables or replacing solenoid.
solenoid is cheap, common to many washers local parts guy will have one that fits even if it is labelled ge frigidaire kenmore
Sep 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Sep 01, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
