View a Call List Entry 1. Press CALLS when the handset is not in use. 2. Scroll to browse through the Call list. Dial a Call List Entry • When the desired entry appears, press /HOME or to dial. Save a Call List Entry to the phonebook 1. When the desired Call list entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number if necessary, and then press SELECT. 4. Use the dialing keys to enter the name, and then press SELECT to save. Delete a Call List Entry • When the desired Call list entry displays, press DELETE. Delete all Call List Entries • Press MENU when the handset is not in use. Scroll to Call log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Using the
Delete
Command
1. Press and hold
b
g
for
two seconds.
2. Say
Delete.
3. Say the name tag you want to
delete.
Using the
Delete All Name Tags
Command
This command deletes all stored
name tags in the Hands
Free
Calling Directory and the OnStar
Turn
by
Turn Destinations Directory,
if equipped.
To delete all name tags:
1. Press and hold
b
g
for
two seconds.
2. Say
Delete all name tags.
Listing Stored Numbers
The list command will list all stored
numbers and name tags.
Using the
List
Command
1. Press and hold
b
g
for
two seconds.
2. Say
Directory.
3. Say
Hands
Free Calling.
4. Say
List
Go to your list URL for example twitter.com/username/list, then on the side bar at the top there wil be a button that says delete. This will delete the list completely.
Click on Account> Edit Friends Then click on "Friends" under "Lists" on the left side of the screen. It looks like your best bet is to just manually unfriend each of them by clicking on the "x" button to the right of their names, then click "remove" on the popup.
I don't think there's a way to delete all of them at once, unless you delete your account (Account> Account Settings> Deactivate account) and start over.
Rather the opposite, the engine is not getting hot enough to burn off the carbon deposits. If all plugs are fouling it is probably not enough air in the mix 1st check your air filter is clean 2nd check air screw settings are 1-5/8 turns out 3rd check that main jets are 105s
Hope this helps(if so please mark as very useful) Ride Safe Bike-Doc
To delete a contact, just go into your contact list and highlight the contact that you wish to delete. Press the button directly above the green send button and scroll down to "Delete Contact". Press the OK button and follow the prompt if there is one after that.
