Question about Dell Computers & Internet
Dell Optiplex GX280 has very high processor fan noise.
My Dell Optiplex GX280 P4 SFF Desktop Computer has very high processor fan noise. Is this mother board issue or fan only issue? If it is curable, how?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Dell Master
  • 884 Answers
Hi
Generally Dells run very quietly, so there are three possible problems here.
The first is that excessive noise can be caused by the fans having to run faster than usual to keep the temperature down. In this case you need to check and make sure that all the airways and interior of the computer are clean and clear of dust, which can build up in such a way as to seriously obstruct airflow. If this doesn't help there are normally at least 2 fans in the computer, one for the CPU chip and the other in the Power Supply. If it definitely one of these the only real way to cure it is to replace whichever is causing the problem.
You can download a very comprehensive manual for the GX280 here:
Product Support Dell US
by clicking on the "Users' Guide" link. This will download a pdf file which can be saved to your drive for future reference. The manual contains detailed instructions for these types of things, easily accessed by an interactive menu system.
Since this is quite an elderly system, you may find, that after pricing any replacements necessary to cure the noise, it makes more economic sense to put the cash towards a more up-to-date system.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Posted on Nov 27, 2014
pgh_pa_guy
  • 2992 Answers
SOURCE: Dell Optiplex GX280 boot problem
I just repaired two Gateway systems with similar behavior (turn on power, fan runs at full speed, no boot), and both needed replacement system boards. (These were a different model, but the symptoms are typical of a dead system board.) I got the boards from a company called Blue Raven Technology (www.blueraven.com).
Before deciding the main board is bad, try another power supply to make sure that's not the problem. Also you might try clearing the CMOS memory on the system board (either by moving a jumper usually found near the backup battery, or by removing the battery itself). Sometimes corrupted CMOS data will keep the system from booting.
Posted on Nov 16, 2008
  • 5 Answers
SOURCE: Dell GX280 High Speed Fan and No Display.
i had same problem today and i tested my machine and solved the problem at last.
the problem is the thermal value that your mainboard sets for your cpu.
please replace the mb.
ps: before this process,i tried almost everything . cpu fan , memory , cpu , cables ,case ... everything. but the problem is on your mb.
Posted on Feb 12, 2009
proton77
  • 1183 Answers
SOURCE: dell gx280 sff show orange
Kindly follow the troubleshooting link below
http://tinyurl.com/c6uq8w
Thanks
Proton
Posted on Mar 12, 2009
SOURCE: No Display in dell optiplex gx280 & Fan speed is veyy high
GM from pakistan fsd problem in motherboard chepset......you should repare u r gx 280 or heat the chepset with heat gun ........
Posted on May 21, 2010
SOURCE: problem withe dell gx280 fan and display
I had exactly this problem on an Optiplex GX 280.
I replaced 1 stick of ram, and everything was happy.
Posted on Jun 03, 2010
Dose not boost and fan is high speed
The Thermal Paste in-between the Processor, and finned Heatsink that sits on it; has dried up.
THOROUGHLY clean top of Processor, and bottom of Heatsink.
PROPERLY apply fresh, new Thermal Paste.
FOLLOW Anti-Static Procedures.
(Not 'shouting', emphasizing)
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3071621&CatId=503
http://www.hardwaresecrets.com/article/274
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_optiplex_desktop/optiplex-gx280_user%27s%20guide_en-us.pdf
Click on the style of Optiplex GX280 that you have. In the list click on Processor.
Yes, I listed that twice.
Regards,
joecoolvette
Mar 25, 2013 | Dell OptiPlex GX280 PC Desktop
Dell optiplex GX280 PC when power on system no noise with fan after one hour making loud noise . I changed the CPU fan , also same noise, and applied heat sink paste to CPU and heat sink same noise....
There probably is another fan, located inside the power-supply, that is making all the noise.
Borrow a stethoscope from a nurse or doctor, and listen to the noise, to pinpoint "where" on the computer that is the origin of the noise.
Jul 16, 2011 | Dell OptiPlex GX280 PC Desktop
My optiplex gx280 desktop fan rotate at a really high speed, but won't turn on. There are no visible bad caps. What else should i check for?
I have that same problem and what usually works for me is to remove the ram and reinstall it also to move a little the heatsink of the processor, just nudge it a little then try again.
Also try not to move too much your computer
Jun 21, 2011 | Dell OptiPlex GX280 PC Desktop
What is the most memory l can put in my dell optiplex gx 280 desktop ,l have 512 in it now
For mini-tower and Desktop
You should have 4 slots.
4GB is the max if you replace all the sticks.
For gx280 SFF (Small Form Factor)
You should have 2 slots.
2GB is the max if you replace all the sticks.
Nov 17, 2010 | Famous Brand Dell Optiplex GX280 Intel...
My pc gx280 is not display fan and pclight on fan is high noise
Could be a possible videocard issue.
Try connecting a working videocard in one of the expansion ports.
A high fan noise could also mean a failing power supply. If you have a spare power supply I would also suggest installing the spare one
Oct 21, 2010 | Dell GX280 Optiplex 2.8GHz Desktop...
Aug 16, 2009 | Dell OptiPlex GX280 PC Desktop
What cpu will it except
The M9475 board came on the GX280 amongst other Dell models. This is socket LGA775
Apr 13, 2009 | Dell Computer Refurbished SYSTEM BOARD -...
Updrading power supply of Dell Optiplex GX280 Small Desktop.
Hi there.
No, 400Watts will not affect your computers performance, it just means that you will be able to add more peripheral devices to your PC, for example, an external or internal hard drive or more USB devices.
Make sure you get the power supply from Dell themselves as you will find it difficult to install a standard PSU (power supply unit).
Good luck and thanks for using Fixya!!!
Mar 01, 2009 | Dell OptiPlex GX280 PC Desktop
Computers & Internet Logo
56 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
