Question about Oster Health & Beauty
<!-- from fixya rte -->How to adjust oster adjustable - Oster Health & Beauty
Oster microwave starts when door is closed but no buttons pressed
This is usually caused by a door switch that has come loose or out of adjustment.
Jul 19, 2014 | Oster 0.7 Cu. Ft. Countertop Microwave -...
Just bought dog hair clippers model 184-01 series B how do I adust the blades
Screw on the side adjusts the cutter position by moving the motor inside if its working ok leave this alone. The adjuster should be in form of a leaver on the side but no, no markings.
Mar 12, 2014 | Oster Health & Beauty
Have Oster model 23-51f fast feed trimmer. Took the blade off havinv trouble putting parts back together namely small copper plate approx. 1-cm long, also having trouble getting the blades to fit together...
We also have these model clippers and have found out that the modelo number has been updated to 76023-510 type in Oster professional products for more info....hope this helps
Sep 22, 2010 | Oster 76915016002 Hair Trimmer
My oster 76 number 2 blade pulls. i have lubed, used blade wash etc. no luck. its fairly new and no visable damage.
The teeth of the blade are not set correctly; look at the top blade and you will see where the bottom blade's teeth are supposed to match up. You can adjust the blade by unscrewing the two screws on the front of the blade and moving that bottom blade back into position.
Feb 25, 2010 | Oster 76076-010 Hair Trimmer
Oster A5 clippers blades stop moving when put into the horses hair. checked without the blades, everything moves fine. Put new blades on, cleaned the silicone off with blade washed and have lubricated with...
How old is your clipper, Oster clippers need to be adjusted for more power and speed, also what clipper blade are you using to cut the horse hair and how long is the horse hair, Also the blade may not be sharp, some new blade are sharp maybe defective.
Feb 25, 2010 | Oster Golden A5 2-Speed Universal Motor...
How to replace adjustable lever on oster clippers
remove two screws securing the name plate, the lever will pull up and off before replacing ensure the felt seals are in place (located next to a metal post). Grease and slide the new oster part into place, refit name plate.
Aug 26, 2009 | Oster 76076-010 Hair Trimmer
Just bought oster proffessional hair clippers, and they won't cut hair, think it may be that blades need adjusting but don't know how to do this help
We usually ask people to leave the adjustment to us as it is critical blades are not over tightened and are perfectly in line. if your blades are clipping on ok and appear to move correctly they may just need sharpening, just remember to use oil.
Feb 20, 2009 | Oster 76076-010 Hair Trimmer
Health & Beauty Logo
43 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
