Los codigos de el control URC-SR3 - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 74,473 Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search this Blog" window, and press Enter.
Posted on Nov 27, 2014
mewms_14904
  • 1027 Answers
SOURCE: I need the codes to
Link to manual codes on page 18
Posted on Sep 02, 2008
SOURCE: necesito el codigo del control ge rc24912
i need the codes four tv philips
Posted on Sep 09, 2009
  • 65 Answers
SOURCE: QUIERO LOS CODIGOS PARA TV PHILIPS, SE ME PERDIO
en la mayoria de los remotos universales viene una tecla que dice "CODE" si es tu caso:
1.- enciende tu tv
2.- oprime CODE y manten oprimida hasta que led indicador quede encendido
3.- pulsa tecla "POWER" las veces que sea necesario apuntando hacia la tv hasta que se apague.
4.- cuando se apague no des mas pulsos a POWER y oprime tecla "ENTER"
si por alguna razon te pasas y das un pulso de mas a POWER, repite la accion.
suerte.
Posted on Feb 16, 2010
SOURCE: el codigo del control remoto de una tv mitsui
el control remoto del digitalizador motorola no trae codigo de acceso a la tv mitsui, cual sería el código de acceso; hablé a Megacable y no tienen registrada la marca de la tv así que no pudieron darme el codigo de acceso y me recomendaron que indaagara en internet
Posted on Nov 13, 2010
SOURCE: hola nesesito el codigo de
Hola sharkys_cybe para programar su control de DISH Network para su televisor Sanyo hay varias formas que se puede hacer. La primera forma es mantener pulsada la tecla TV hasta que todos los botones de modo de luz y luego los códigos de la TV Sanyo son: 590, 683, 090, 121, 500, 183, 111, 589, 542, 754, 621, 563 , 512 o 652 suguiente del codigo presione el signo de #. Yo también dejo el link para ayudar con una "exploración de energía". http://www.dishnetwork.com/SupportSection/power-scan-instructions
Posted on Feb 03, 2011
Codigos para control remoto
Hola Ralf, mi nombre es Kimberly y formo parte del departamento Social Media con DISH. para obtener los codigos de su control por favor siga este vinculo http://www.mydish.com/support/apps/remotecodes.aspx seleccione el modelo de control (este se encuentra en la parte de atras del control) Una vez usted haga esto, seleccione el tipo de aparato al cual necesita programarlo Y despues la marca del aparato. Una vez usted haga esto le aparecesaran los codigos que posiblemente funcionan con el aparato. El procedimiento a programar su control es el siguiente Oprima el boton de T.V localizado en la parte de arriba en su control por 5 segundos, despues cuando vea que los botones de arriba se iluminan ingrese un codigo seguido por el signo de numero por ejemplo: 585#. El boton de t.v debe de iluminarce 3 veces, despues de esto puede intentar apagar el televisor, deberia funcionar.Si necesita asistencia adicional sientase libre de contactarme directamente a: kimberly.escobar@dish.com
Jul 30, 2013 | Televison & Video
NECESITO EL CODIGO DE UN TELEVISOR SANYO CON UN CONTROL REMOTO DE JVC
These are the codes for Sanyo TV: 0049 0097 0110 0004 0268 0012 0108 0180
Aug 19, 2012 | RCA Universal Remote Control
Necesito codigo de tv daewo para control dish
Mi nombre es Kimberly Escobar trabajo con DISH Network servicio al cliente. Entiendo que necesita programar el control de DISH Network con su televisor Daewoo, seria un placer asisterle proveendole la informacion que necesita. Para programar el control con su T.V existen ciertos codigos que se integran al control en base a la marca de la television. Por ejemplo para la marca Daewoo unos de los codigos serian 531, 719, 727, y 654. El procedimiento es el siguiente: oprima el boton de T.V localizado en la parte de arriba hasta que los demas botones se prendan, luego ingrese uno de los codigos por ejemplo el 531 despues de ingresar el numero va a ingresar el signo de numero (#) el boton de T.V debe iluminarce 3 veces. Despues de esto puede intentar usar el control deberia de funcionar. Si tiene preguntas adicionales porfavor contacteme directamente a kimberly.escobar@dishnetwork.com o tambien puede visitar nuestro website http://www.dishnetwork.com/SupportSection/remote-setup aqui puede encontrar mas codigos e informacion adicional. Gracias espero esto le sea de ayuda.
Oct 24, 2011 | DISH Network IR Remote Control
Quisiera saber codigos para la tv vizio
Hola mi nombre es Kimberly Escobar con DISH Network, sera un placer ayudarle y proveerle la informacion que necesita. Ciertos codigos que pueden ser integrados a un control de DISH Network para que funcione con un televisor Vizio son los siguientes: 627, 505, y 520. el procedimiento a integrar uno de los codigos es el siguiente: oprima el boton de t.v localizado en la parte de arriba en el control por 5 segundos, una vez los botones se iluminen en rojo ingrese uno de los codigos seguido por el signo de numero. Por ejemplo 627#, el boton de t.v debera iluminarce 3 veces. Despues de este procedimiento puede intentar usar el control con la t.v. Tambien puede visitar este link, aqui puede encontrar mas codigos y los pasos a seguir para programar el control http://www.dishnetwork.com/SupportSection/remote-setup. Si necesita ayuda adicional me puede contactar directamente a kimberly.escobar@dishnetwork.com. Gracias y espero esto le sirva de ayuda.
DISH Network
Kimberly Escobar
Aug 26, 2011 | DISH Network IR Remote Control
Como puedo programar el control para tv panasonic
Hola mi nombre es Kimberly Escobar con DISH Network. Sera un placer ayudarle y proveerle la informacion que necesita para programar un control de DISH Network a su televisor Panasonic. Hay ciertos codigos que se pueden integrar al control que le permiten funcionar con la television, unos de los codigos serian los siguientes: 685, 512, 700, 765, y el 644. El procedimiento a integrarlos es el siguiente: Presione el boton de T.V localisado en la parte de arriba del control hasta que se prendan los demas en rojo una vez esto suceda ingrese uno de los codigos seguido por el signo de numero por ejemplo (700#). El boton de T.V debera ilumarce 3 veces en rojo si el codigo es compatible. Despues de esto puede intentar usar el control con su T.V. Espero esto le sirva de ayuda si tiene preguntas adicionales o necesita ayuda puede contactarme directamente a mi correo electronico kimberly.escobar@dishnetwork.com
Kimberly Escobar
DISH Network
Mar 17, 2011 | DISH Network IR Remote Control
Los pasos a seguir para progamar el ontrol dish al televisor? y los codogos para el tele RCA
Hola mi nombre es Kimberly Escobar con DISH Network. Sera un placer ayudarle y proveerle la informacion que necesita. Para programar el contol de DISH Network a su T.V el procedimiento es el siguiente: Oprima el boton de T.V localizado en la parte de arriba de su control hasta que los demas botones se enciendan en rojo, una vez encendidos ingrese el numero de codigo que tenga para la marca de su televisor seguido por el signo de numero (#) el boton de T.V debe de iluminarce 3 veces, despues usted puede intentar usar su control y deberia funccionar. Los codigos que puede programar a una television marca RCA serian los siguientes: 503, 020, 633, 805, 725 y el 627. Si tiene algun problema me puede contactar directamente a kimberly.escobar@dishnetwork.com este link tambien le puede servir de mucha ayuda http://www.dishnetwork.com/SupportSection/remote-setup aqui puede encontrar mas codigos y ayuda en como programar el control. Gracias y espero esto le sirva de ayuda.
Feb 17, 2011 | DISH Network IR Remote Control
Nesesito los codigos para controlar mi tv panasonic
Hola mi nombre es Kimberly Escobar con DISH Network. Sera un placer asisterle proveendole la informacion que necesita. Algunos codigos que pueden ser programados a un televisor Panasonic so los siguientes: 700, 734, 512, 644, and 685. El procedimiento a integrar uno de estos codigos al control para que funcione con la T.V es el siguiente: oprima el boton de T.V localisado en la parte de arriba del control hasta que los demas botones se prendan en rojo, una vez esto suceda ingrese uno de los codigos seguido por el signo de numero por ejemplo 700#, el boton de T.V deberia iluminarse 3 veces en rojo despues de esto puede tratar el control para verificar que funcione. Este link tambien le puede ser de mucha ayuda aqui encontrara mas codigos e informacion a programar el control http://www.dishnetwork.com/SupportSection/remote-setup. Si necesita informacion adicional o mas ayuda por favor contactenos directamente al 1800-333-DISH. Gracias y espero esto le ayude.
Feb 12, 2011 | DISH Network IR Remote Control
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
