Question about Cell Phones
How do i change fork seal of kmx 125 a12
Hav'nt tried anything yet i'm afraid to touch it without an instruction
  • 77 Answers
Well put on engine stand remove front wheel then mark yokes and fork alignment with marker pen undo retaining clamps on yokes if your forks are upside down ones then undo top cover s then there should be a bolt that holds the inner leg to the fork sleeve once u have removed fork leg remove inner leg from sleeve then you will be able to see the retaining clip inside the sleeve remove this then using a large flat screwdriver get under rubber seal and prize out they are not always easy once done replace with new seal reassemble refill FORK OIL !!! THEN reassemble forks to bike job done
Posted on Nov 27, 2014
Kmx 125
You need to clarify the problem, unsure what you mean by changing the mix.
Jun 07, 2013 | Motorcycles
Oil front fork beta evo 125
Hi Anonymous, I am sorry you can't find the first and best tool you ever bought for your Beta but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
How to Change Dirt Bike Fork Seals Part 1 of 3
Honda CRF Fork Seal NO SPECIAL TOOLS Change your fork seal
How to replace motocross fork seals without fork seal driver and bul
http://www.lewisportusa.com/manuals.htm
http://www.betamotor.com/en/suhttp://www.lewisportusa.com/manuals.htmpport/manuals
Apr 29, 2013 | Beta Motorcycles
Ccm tl 125 fork seals
normally if you remove the seals carefully there are numbers printed on them and also you can measure the outside diameter and measure the fork slider to get any info required ! if you google ccm uk there should be someone with spares ! if you struggle let me know and im sure i get anything you want !! P...
May 24, 2012 | 2009 CCM TL 125
How to remove the fork oil for kawasaki kmx 125
you cannot remove the oil ,these units are sealed for life and never need changing ,to remove the unit to fit new seals where available you remove the fork then put it in the vice and use a allen key down the middle to seperate the unit ,this is not for the novice as its quite complicated and requires a long 1/4 drive extension with the appropiate allen key socket on the end hence the vice to hold it still .You should not need to change the oil ever in this sort of unit
Feb 08, 2012 | 2001 kawasaki KMX 125
What is the standard fork oil weight and capacity for a kawasaki kmx 125 2000 model?
Total capacity is 615-623cc (1/2 for each Fork leg.)
OEM Fork Oil is type Kayaba 01
This is a 5 weight fork oil
Oct 19, 2011 | 2000 kawasaki KMX 125
How do you change the fork seals on a ybr 125 as im trying but ive undone the top cap n bottom bolt but cant get the shaft out to get the seal out
Remove fork spring, prise up dust seal, you will then see a clip holding in the main seal, remove this clip, with the spring removed you will then use the fork stancion to remove the seal, holding the fork lower in one hand and the stancion in the other push down on the stancion untill it stops then pull it up sharply, and repeate this hammer action until the fork is sepparated and the seal will then be removed
Aug 17, 2011 | Yamaha FS 570 Motorcycles
Trying too change fork seals on rx 125 now have undone from bottom of forks but cannot get the split ring out
remove the bottom split ring first then the smaller one.
if they are damaged, replace them too.
If you can't get it out without damaging it, go ahead and damage it and buy new ones.
they are not expensive.
Dec 03, 2010 | 2000 Aprilia RX 125
I would like to have complete wiring diagram for kawasaki kmx 125
http://bikeforum.comxa.com/Forum/motorcycle-owners-manuals/kawasaki-kmx-125-service-manual/
appreciate it if you sign up
Sep 24, 2009 | 2001 kawasaki KMX 125
Front fork oil seal replacement
General intructions for most bikes:
Remove front wheel. Loosen fork tube clamps at top and bottom of triple clamps. Slide fork tubes out and remove. Access to seals is from top of tube. Remove cover and unscrew cap. Shop manual for specific bike is $24-$30. Will show detailed instructions.
Good luck;
Techjoel
May 14, 2009 | 2001 kawasaki KDX 125
Kawasaki KMX 125 losing power
hi man,
I had a similar problem, so maybe I can help you. it can be connected with air filter. under your seat there should be some kind of cover on the air filter. just remove it. I've noticed this problem when I unrestricted my KMX 125. the hole on the cover on the air filter is too small.
Apr 04, 2009 | 2001 kawasaki KMX 125
Cell Phones Logo
47 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
