Question about Vivotek IP Computers & Internet
Honeywell ip camera won't initialize. Power light just keeps blinking green
  • 693 Answers
You have to enter the IP address of camera and clear user and password before it will work.abit like routers. Try 192.168.0.1 if not that then 192.168.1.1 you might get a walk through on google.
Posted on Nov 27, 2014
  • Barry Wisler
    Barry Wisler Nov 27, 2014
    Where do I enter the IP address
  • john cordey
    john cordey Nov 28, 2014
    Sorry you need to go here http://www.ispyconnect.com/man.aspx?n=Ho...
    default user : administrator
    default pass : 1234
    you should use a program like VLC which is free to view the camera in real time. You need to set up a DNS server if you want to view remotely.most stuff you can google.
2 Suggested Answers
judesoul
  • 127 Answers
SOURCE: canon ip 3000 photoprinter not working
things to check.
1. check for any paper that may have jam inside the printer.
2. check for open covers, back, top covers and close them properly.
4. check your power adapter if its giving correct voltage to the printer.
3. Try to move the ink cartridge to the left gently and return back to the right most part.
please let us know if this works.
Posted on Feb 07, 2009
Honeywell ip cam won't initialize power light just keeps blinking green
please reset the printer by ejecting the power and data cable for a one miniute
Nov 27, 2014 | Office Equipment & Supplies
The infrared receiver light just keeps blinking red and TV won't power on. Tried unplugging for a little while but didn't help.
kindly count the blinking led to diagnose where the fault came from..
also try the initial check....open the back cover and inspect the power supply board for any bulged capacitors inside..
Jan 18, 2012 | Polaroid 4241-TLXB 42 in. LCD Television
I bought a power adapter for the camera, but it doesn't seem to work without batteries in the unit. If I use the batteries alone, I will eventually get a red blinking light at the back of the camera,...
Because the camera is what is technically known as 'Portable'and is designed to work purely from the internal battery. the Power Adapter merely charges the internal battery
May 08, 2017 | Kodak EasyShare C330 Digital Camera
I have an A. O. Smith Model FPSH 40-261 hot water heater. It won't heat water. there is a green light on the control flashing. What does it mean?
AO Smith uses the Honeywell ICON gas valve with green indicator light.
Some models use White Rodgers Intellivent with a row of indicator lights.
The gas control blinks the error code:
Open following links to identify gas control thermostat and read possible error codes:
http://waterheatertimer.org/pdf/Honeywell-Gas-Valve-LED-Codes-2000.pdf
http://waterheatertimer.org/BW.html#Temp
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#intelli
Jul 18, 2011 | Water Heaters
Hi i have a problem here IP 1300 canon printer it says that i don't install cartridge properly but i try to reset it and still desame..the orange light still blinking and also the green light please help...
fallow this procedure it will help.
  1. Turn off Canon Pixma iP1300 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the Canon Pixma iP1300 Printers should turn off, if not, press the Power button once more.
  8. Your Canon Pixma iP1300 Printers should respond as normal
Apr 20, 2011 | Canon PIXMA iP1300 Printer
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
When I turn my IP 3000 on the green light only blink 9 time no orange light at all I did try to reset no sucess as the green light keep blinking 9 time any help
9 flashes should only occur if you are trying to print directly from a non-compatible digital camera. Check where your USB cable is plugged into the printer. The cable coming from the computer should go into a 'square' port in the back of the printer -- not the rectangular port on the lower right side of the front of the printer.
Nov 09, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Green and orange lights flashing, saying service error 6000
read all first!
you didn't say how many blinking
and in what order so ...
First thing you need to do is print an EEPROM information page, step number 2 below.
Once you have an EEPROM print you can reset the waste ink counter, if needed, which is step number 4 below.
Service Mode: This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
Service Mode Operations
With the printer powered off, hold down the "Resume Button" and press the "Power Button".
While holding down the "Power Button", release the Resume Button" and press the "Resume Button" twice in succession. Now release the "Power Button".
The indicator will blink in green and remain lit in green.
Select one of the following service mode functions by pressing the “Resume Button” the specified number of times.
1 time = Service test print.
2 times = EEPROM information print.
3 times = EEPROM initialization
4 times = Waste ink counter resetting
5 times = Destination settings
6 times = Print head deep cleaning
Then press the “Power Button” one time to perform selected function.
If you press the "Power Button" two times it will take you out of service mode.
This information is listed above in this thread and many times in other Canon threads in this forum. I simplified Canons wording so I could remember the service mode functions easier.
PIXMA IP 3000 service error 5100
I got service error 5100 after a paper jam sometimes 5 times blinking orange. in my PIXMA IP 3000
to fix it
1. Turn off printer
7. Press the Power button and the printer should turn off, if not,
8. Your printer should respond as normal..
or: and Also;
Unplug unit, hold power and reset button down then plug it in while still holding both buttons down;
Then to step 3 above.
Feb 19, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Computers & Internet Logo
108 people viewed this question
Top Vivotek Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
justwinwin
Are you a Vivotek Computer and Internet Expert? Answer questions, earn points and help others
