My monitor s19a100n displays slowly when the command is already givento to Pc. What might be the solution for this problem?
  • 36 Answers
That your PC is busy, the display has an offset of somewhere aroung 5 ms for your display. You won't even see more than just a slight blur even in quick movements. Anything above that orgiginates in the computer.
You might have set a bigger resolution for a new monitor, thus increasing the workload for your graphics adapter.
Example:
For a 1024 x 768 resolution, the PC must compute 786,432 pixels. Your display (1366 x 768 pixels) has about 30% more pixels to compute. (for an HD display that number increases to two and a half times as many)
Test:
(presuming, you run windows) start the task manager (right klick the status bar, usually on the bottom of the screen), select task manager and then the tab "performance", where you can see how busy your CPU is and whatamount of ram / swap is used.
Resolution:
Reduce your resolution, get a better graphics adapter, upgrade CPU / ram, decrease background programmes.
Posted on Nov 27, 2014
My Samsung led s19a100n monitor sometimes doesn't power up !! What to do?? When it powers up i mean it starts then it works perfectly!
Exercise does Max Synapse/ benefit your brain cells. The blood vessel system within your brain will dilate and improve circulation of blood when you engage in regular exercises. Exercise helps get the toxins or other offending agents and lets oxygen and nutrients flow in and also speed settings brain make use of them.
http://www.expertskinsolutions.com/max-synapse/ Max Synapse Enhance The Power Of Your Brain Max Synapse Enhance The Power Of Your Brain
Feb 16, 2016 | Samsung Computers & Internet
My samsung led S19A100N screen automatically switched to the left. as it does not have adjust bottons. how to solve this problem
Dear kindly note below producer for rectification of screen automatically switched to the left. As it does not have adjusted button. First adjust your display resolution 1366 X 768 and then Press on/off button till 6 sec. adjustment option will be appeared. Then again press on/off button till 6 sec, screen will set automatically.
Oct 11, 2011 | Samsung Televison & Video
The screen says no signal
If you have already verified the connection between your computer and the monitor you can try these steps to attempt to get an image on your monitor.
First, check your monitor for a button that says "source" or a button that has a square with an arrow pointing to the center. This will switch where your monitor looks for the signal.
A good rule to follow is if your monitor is connected to the computer by a cable with white ends, you should select "Digital", and if it is connected with a cable with blue ends, you should select "Analog" or "VGA". It is possible, but unlikely that your monitor is connected in any other way.
If these steps still do not work, follow these steps exactly:
  1. Press the windows logo key 220px-ctl_wndws_alt.jpg and "R" (This opens the "Run" window.
  2. Type this command: "shutdown /s /t 0" without the quotes. The shutdown command with the "/r" and "/t 0" switches tell shutdown to restart the computer at "time 0" which is immediately
  3. Wait for the computer to restart and it should automatically detect the correct display to use.
  4. If all else fails and you cannot get the display to connect, restart the computer and press "F8" until the computer comes up into safe mode. From there you can verify whether or not the monitor is actually functional, as driver incompatibility issues are not a problem when running in safe mode.
Nov 25, 2010 | Gateway FPD1975W 19" LCD Monitor
Whenever the computer gets shut off randomly, the monitor does wacky things. One time it made it extremely bright and this time the color of the screen is bluish. It also wont pop up the menu when i press...
hayleyvivian, When Very strange things start to occur with ANY brand of LCD display the first place a technician will look is at the SMPS/inverter power supply for the monitor. One thing you could do is try to swap your display to a fully booted KNOWN GOOD pc with the desktop window showing. If display still does weird stuff, then you will know that it's not your pc screwing up. If you have already swapped-in a different display to your pc to logon the web, you already know it's the monitor that has the problem. Just FYI visit YOUTUBE for video clips of "LCD monitor disassembly" and "LCD repair". You my also want to check out your warranty to see if your covered or if Magnavox will do a swapout+cash for a REFURBISHED unit. Bye. 12fixlouie
Oct 23, 2009 | Mag Innovision InnoVision LT765 17" Flat...
My samsung monitor syncmaster 743nx is not turning on..plss help me...tnx
How to troubleshoot a Samsung SyncMaster 743NX LCD Monitor? My Samsung SyncMaster 743NX monitor turns on slowly. I mean,last week when I started up my pc,it took 5-10 mins before my monitor displayed anything. I know the pc is already turned on because I've already heard the Windows Vista start up tune play. The problem is now getting worse as it now takes 20-30 mins before my monitor displays anything. Please help.
Mar 11, 2009 | Computers & Internet
Monitor displays slowly after the computer starts.
try to turn off you screen saver just turn off power monitor to see monitor easy wake up after long time.if ok means windows screen saver have problem if still same look like is you monitor something wrong need to check
Jan 03, 2009 | Dell Dimension 2400 PC Desktop
Tha display screen is dark, shows very faintly.
Can you be more specific ?
The first step is to isolate the system at fault:
1) Monitor hardware ?
Test it on another PC or
Try a different monitor on the same PC
Check monitor adjustments.
Check the video cable, try another one.
2) What kind of a monitor is it?
CRT (like and old TV) or an LCD flat screen
3) Video card problem, possible but not as likely
4) Video driver or operating software settings issue
wrong video mode, video settings the monitor can't handle,
incorrect device driver
lots of possibilities here.
MJS
Apr 18, 2008 | Computers & Internet
Monitor blank
try to start your pc in safemode with vga mode with thjis faulty monitor
hope you know how to do it
start pc (powerr on)
then continuously press F8 key then it will show you boot menu
select safemode with command prompt
then if it show desktop on screen this means your monitor is having problem with resolution try to downgrade your monitor's resolution
rightclik on desktopgo to properties
select settings
here you can find screen resolution make it to 800X 600 just for one time
then restart your pc it will auto select proper screen resolution
Mar 29, 2008 | Dell E173FP (Black) (Dark Gray) 17" LCD...
Possible virus
Try starting in safe mode. If it works then you need a graphics driver.
Jan 01, 2008 | Gateway 832GM PC Desktop
HCL Monitor type HCM580M display problem
Information about the Linux / UNIX less command. Thus, various display problems may result, such as long lines being split in the wrong place. -R --RAW-CONTROL-CHARS, Like -r
Device Manager information and help This section will also display what COM ports are detected; for example, ... CODE 13 - System Failure - Possible problem in Device Driver or Windows 95 Code.
Good Luck, Please dont for get to Vote, Thank You.
Dec 19, 2007 | Computers & Internet
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
