Question about Cell Phones
Is there some type of a smartphone screen calibration software for windows
I have looked in the settings menu under display for a calibration setting as directed by every answer I found on the web but none to be found. Can you help...? the lower 1/3'd of my touch screen is not reading my movements at all but the rest works fine.
  • 711 Answers
It sounds as if digitizer has failed on part of screen.need to replace digitizer.
Posted on Nov 27, 2014
nk_07
  • 154 Answers
SOURCE: Iphone touch-screen
sir whats ur model\????
Posted on May 28, 2008
SOURCE: p990i touch screen problem
I encountered the same problem but was able to fix it. Just don't know if it's just temporary. Go to tools, control panel, other, set up wizard, tap yes, tap the second button before cancel, keep on clicking to the right direction until the numbers 1, 2, 3 and 4 appears. Tap the center of each number until blinking stops, save settings. For the first few steps you may use the jog dial found on the left side of the phone if the touch screen does not follow your tappings.
Posted on Sep 17, 2008
SOURCE: nokia 5200 invalid web settings
how to save gprs setting for nokia5200
Posted on Apr 01, 2010
SOURCE: Touch pad keys don't work, except the one to turn phone off
I just want to add that the same thing happened to my phone this weekend and holding down the command button really does work. I noticed that right before the problem occured, I accidently hit the command button...I think this problem is related to the command button getting "stuck" in the pressed position. Therefore, banging on the knee or holding down that button for 5 seconds to "unlock" the keys resolves it. Thanks everyone.
Posted on Jun 06, 2010
  • 184 Answers
SOURCE: i cant acess my setting to calibrate my phone.
Ok there might be a battery issue. Or there might need to be a touch calibration reset. To do that go to your settings and select touch calibration and do it again.
ALSO IF YOUR PHONE IS STILL IN WARRENTY AKA WITHIN 1 YEAR OF PURCHASE THEN CALL 1800 801 1101. THEY WILL HELP YOU. YOU WILL NEED YOUR IMEI NUMBER OFF THE BACK OF THE PHONE. IF NOT CALL THE INSURANCE HOTLINE WHICH IS ON THE AT&T WEBSITE.
Posted on Jun 24, 2010
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Tip
How To Reset Your Blackberry Smartphone
<span style="font-weight: bold;">Soft Reset</span><br /> <ol> <li>Press and hold the <b>Alt</b> key. </li> <li>While holding down the <b>Alt </b>key, press and hold the <b>Right Shift</b> key. </li> <li>With both of those buttons still pressed, press the <b>Backspace/Delete</b> key.</li> <li>The display turns off to indicate that the reset has started, and the keys can now be released. </li></ol><span style="font-weight: bold;">Hard Reset</span><br /> <ol> <li>Remove the battery cover. </li> <li>Remove the battery, and then reinsert it after a few seconds. </li> <li>Replace the battery cover.</li></ol><span style="font-weight: bold;">Factory Reset</span><br />The following will delete all data and applications on the BlackBerry smartphone. Back up the data on the BlackBerry smartphone before proceeding. The process for deleting all data and applications can take up to an hour to complete. Do not remove the battery while data is being deleted.<br /><br /> <br /> <b>Note:</b> To identify the version of BlackBerry Device Software on your BlackBerry smartphone, go to <b>Options</b> &gt; <b>About</b><br /><br /> <p style="font-weight: bold;">BlackBerry Device Software 2.6<br /> Note:</b> If a password is already set, go to step 5.<br /> <ol> <li>From the Home screen of the BlackBerry smartphone, click <b>Options</b>. The Device Options screen is displayed. </li> <li>Click <b>Security</b>. The Security screen is displayed. </li> <li>In the Password field, press the <b>Space</b> key to enable the password. A dialog box will prompt for a password with at least four characters. </li> <li>Type a password. Click the trackwheel. Type your password again to verify it. </li> <li>On the Home screen, click the <b>Lock</b> icon. The Lock screen is displayed. </li> <li>Type your password incorrectly 10 times to trigger a security wipe. </li></ol> <p style="font-weight: bold;">BlackBerry Device Software 2.7<br /> <ol> <li>From the Home screen of the BlackBerry smartphone, click <b>Options</b>. The Device Options screen is displayed. </li> <li>Click <b>Security</b>. The Security screen is displayed. </li> <li>Click the trackwheel, and select the <b>Wipe Handheld</b> option. </li></ol> <p style="font-weight: bold;">BlackBerry Device Software 4.0<br /> <ol> <li>From the Home screen of the BlackBerry smartphone, click <b>Options</b>. The Device Options screen is displayed. </li> <li>Click <b>Security</b>. The Security screen is displayed. </li> <li>Click the trackwheel, and select the <b>Wipe Handheld</b> option. </li></ol> <p style="font-weight: bold;">BlackBerry Device Software 4.1 to 4.2.1<br /> <ol> <li>From the Home screen of the BlackBerry smartphone, click <b>Options</b> &gt; <b>Security Options</b> &gt; <b>General Settings</b>. </li> <li>Display the menu and select the <b>Wipe Handheld </b>option. </li> <li>Click <b>Continue</b>. </li> <li>Type <b>blackberry</b>, and then press the <b>Enter</b> key. </li></ol> <p style="font-weight: bold;">BlackBerry Device Software 4.2.2 to 4.7<br /> <ol> <li>From the Home screen of the BlackBerry smartphone, click <b>Options</b> &gt; <b>Security Options</b> &gt; <b>General Settings</b>. </li> <li>Press the <b>Menu</b> key, and select the <b>Wipe Handheld</b> option. </li> <li>Select the <b>Include third-party applications</b> check box to remove third-party applications. Clear the check box to preserve third-party applications. </li> <li>Click <b>Continue</b>. </li> <li>Type <b>blackberry</b>, and press the <b>Enter</b> key. </li></ol> <p style="font-weight: bold;">BlackBerry Device Software 5.0<br /> <ol> <li>From the Home screen of the BlackBerry smartphone, click <b>Options</b> &gt; <b>Security Options</b> &gt; <b>Security Wipe</b>. </li> <li>Select the appropriate check boxes to remove data and applications as intended. </li> <li>Type <b>blackberry</b>, and click <b>Wipe</b>. </li></ol> <p style="font-weight: bold;">BlackBerry Device Software 6.0<br /> <ol> <li>From the Home screen of the BlackBerry smartphone, click <b>Options</b> &gt; <b>Security</b> &gt; <b>Security Wipe</b>. </li> <li>Select the appropriate check boxes to remove data and applications as intended. </li> <li>Type <b>blackberry</b>, and click <b>Wipe Data.</b> </li></ol><br /><span style="font-style: italic;">To reset a legacy BlackBerry device (</span><span>Research In Motion&reg; (RIM&reg;) 850, 857, 950, 957 devices)</span><span style="font-style: italic;">, insert the end of a paper clip into the small hole on the back of the device.</span><br />
on Feb 15, 2011 | Cell Phones
Htc prophet touch screen issue
for window phones
1. Press the "Home" key and press "Start." Use the directional pad to highlight "Settings," then press the center or "Enter" button.
2. Use the directional pad to select the System tab. Select "Screen," then press the center or "Enter" button. Select "Align Screen."
3. Using your smartphone's stylus, tap the crosshairs as they appear on your screen. Do this for as many as appear, until the calibration tool finishes. Your screen is now properly calibrated.
for Android phone
4. Press the "Home" button or capacitive area, then press "Menu." Tap "Settings."
5. Tap "Language and keyboard." Tap "Keyboard settings." Tap "Tutorial" and go through the steps that appear on your screen.
6. Once this is finished, turn your phone off and on again. Your keyboard has been adjusted, which activates a re-calibration of the capacitive touchscreen. (Capacitive screens are technically far more accurate that resistive, and so a full calibration tool is not included with Android phones.)
Aug 20, 2012 | imate JAMin Smartphone
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
Brightness and contrast symbols
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
Labels aren't feeding through at right length
This sounds like a calibration issue.
Follow the instructions below to re-calibrate
Three readings are required:
· Empty: No media in the sensor.
· Gap (or Mark): Only the backing, notch, or reflective mark in the sensor.
· Paper: The label (with the liner attached) in the sensor.
To perform a Standard Calibration:
Step Operator Action Displayed Message Comment
1 (Media should be loaded and the appropriate Sensor Typeselected.)
2 Press the menu key.
Raise the printhead assembly.
MENU MODE
MEDIA SETTINGS
You are entering Menu Mode.
3 Press the enter key to enter
the Media Settings menu.
MEDIA SETTINGS
MEDIA TYPE
4 Press the FWD key and
scroll to 'Sensor Calibration'.
MEDIA SETTINGS
SENSOR CALIBRATION
5 Press the ENT key. SENSOR CALIBRATION
PERFORM CALIBRATION
You are beginning the standard
calibration procedure.
6 Press the ENT key.
Remove the media from the Media Sensor then press any key.
REMOVE LABEL STOCK
PRESS ANY KEY <yyy>
This sets the parameter for the
'empty' value.
Where 'yyy' is a numerical
value representing the current
sensor reading.
8 Position the label (and backing,
if any) under the Sensor Eye
Mark.
ã Note: If using preprinted
media, ensure the label area
under the sensor is free of
preprinted text, graphics or
borders.
Press any key to continue.
SCAN PAPER
PRESS ANY KEY <yyy>
'paper' value.
sensor reading.
The calibration was successful.
See note below if another
message was displayed.
10 Exit upon successful
calibration: Back out of the
menu tree by repeatedly
pressing the key.
If using gap or reflective media,
press and hold the FEED key.
The printer will begin
advancing media; allow at least
one label gap (or mark) to
advance under the sensor.
READY
Aug 19, 2011 | Datamax I-4208 Thermal Label Printer
How do I reduce the brightness of my AOC monitor?
If you are using windows XP :
1.Right click on desktop
2.Properties
3.Settings
4.Advanced
Windows 7:
1.Open Display Color Calibration by clicking the Start button , and then clicking Control Panel. In the search box, type calibrate display, and then click Calibrate display color. If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
2.In Display Color Calibration, click Next to continue
Aug 01, 2011 | AOC Monitor
How do i callibrate the screen for my samsung i5510i galaxy android phone?
If you are asking about the touch calibration
Goto Settings (in the program menu) > Language & Keyboard > Touch Input
Here you can calibrate the touch settings.
If you are asking about Display Calibration
Goto Settings (in the program menu) > Display Settings. Here you can calibrate settings for Animation, Brightness, Screen Timeout etc
Jul 01, 2011 | Samsung Cell Phones
How to master reset a blackberry pearl 8220
To delete all data and applications from your BlackBerry smartphone, complete the appropriate set of steps below depending on the version of BlackBerry® Device Software you are running. Warning: The following procedures will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the data prior to wiping your BlackBerry smartphone. If content protection is turned on, the process for deleting all data and applications from the BlackBerry smartphone can take up to an hour to complete. Do not remove the battery from the BlackBerry smartphone while data is being deleted. To identify your BlackBerry® Device Software version go to Options > About (For example, 2.6.x.x, 2.7.xx or 4.0.x.x) For BlackBerry smartphones running BlackBerry Device Software version 2.6 Note: If a password is already set go to step 5. On the Home screen, click the ?Options? icon. The Device Options screen is displayed. Click ?Security?. The Security screen is displayed. In the Password field, press the Space key to enable the password. A dialog box prompts you to type a password with at least four characters. Type a password. Click the trackwheel. Type your password again to verify it. On the Home screen, click the ?Lock? icon. The Lock screen is displayed. Enter your password incorrectly 10 times to trigger a security wipe. For BlackBerry smartphones running BlackBerry Device Software version 2.7 On the Home Screen, click the ?Options? icon. The Device Options screen is displayed. Click ?Security?. The Security screen is displayed. Click the trackwheel and select ?Wipe Handheld? For BlackBerry smartphones running BlackBerry Device Software version 4.0 On the Home Screen, click the ?Options? icon. The Device Options screen is displayed. Click ?Security?. The Security screen is displayed. Click the trackwheel and select ?Wipe Handheld?. For BlackBerry smartphones running BlackBerry Device Software 4.1 to 4.2.1 From the Home screen of the BlackBerry smartphone, go to Options > Security Options > General Settings. Display the menu and select Wipe Handheld. Click Continue. Type blackberry, and then press the Enter key. For BlackBerry smartphones running BlackBerry Device Software 4.2.2 to 4.7 From the Home screen of the BlackBerry smartphone, go to Options > Security Options > General Settings. Display the menu and select Wipe Handheld. Select the Include third-party applications check box if you wish to remove third-party applications. Clear the check box if you do not want third-party applications to be removed. Click Continue. Type blackberry, and then press the Enter key.
Oct 29, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
My phone is deleting my text messsages and my calls I have made. When I go to check if my message sent, it says there is nothing in my inbox or outbox. How does my phone delete my stuff without me doing...
Cause 1 A number of large applications are installed on the BlackBerry smartphone. Resolution To resolve this issue, complete the following steps: Make sure that the BlackBerry® Device Software is installed on the computer to display the correct total application space. Determine the application space that is available on the BlackBerry smartphone by completing the following steps: Connect the BlackBerry smartphone to the computer. Open the BlackBerry® Desktop Manager. Double-click Application Loader. At the Device Application Selection screen, under the application selection window, note the total application space. Note: Select the List additional applications that are installed on the connected device check box to include the applications that are installed outside of the BlackBerry Device Software applications and the file sizes. Remove applications that are not required. For example, remove additional language packs and themes. Cause 2 A large amount of BlackBerry smartphone user data is present on the BlackBerry smartphone that cannot be removed by the Low Memory Manager. Resolution To resolve this issue, complete the following steps: On the BlackBerry smartphone, click Options > Status. Display the menu, and select Database Sizes. Reduce the number of items that are increasing the size of the database. For example, if the Address Book database is large, remove out-of-date contacts. If the Content Store database is large, move media files from the BlackBerry smartphone memory to a media card. Cause 3 Media settings may contribute to low memory capacity. Resolution Modify the Device Memory Limit settings by completing the following steps: On the BlackBerry smartphone, click Media. Select a media application. Display the menu, and click Options. Set the Device Memory Limit to the lowest setting field. Display the menu, and click Save. Note: Some BlackBerry smartphones have integrated cameras without a media card. As a result, some features have been added to handle picture storage on the BlackBerry smartphone, including the following: · Reserved Pictures Memory: In BlackBerry Device Software 4.2.0, the default value setting is 10 MB. In BlackBerry Device Software 4.2.1 - 4.7, the default value setting has been reduced to 2 MB. This setting reserves memory for pictures that the BlackBerry smartphone might take, and reduce the File Free amount that is displayed in the BlackBerry smartphone. This makes sure that the BlackBerry smartphone has memory available for pictures that are taken when a media card is not inserted in the BlackBerry smartphone. · Device Memory Limit: The default value setting is 20 MB. This prevents the BlackBerry smartphone from storing more than the specified amount of memory use. Cause 4 An application has expanded beyond intended memory boundaries. Resolution Note: In the Java® operating environment, applications increase and reduce memory usage when the applications launch, run required processes, and close processes. An application may use more memory than it is intended to use. Please make note of the values outlined in the following steps: On the Home screen of the BlackBerry smartphone, click Options. Click Status and note the values listed for File Free and File Total. Divide each of these two values by 1024, so that they are measured in kilobytes (KB). Record the new values, and name them as Displayed File Free and Displayed File Total. Display the menu, and click Database Sizes. Record the value shown in the Total Size field at the top of the screen. Open BlackBerry Desktop Manager, then open the application loader tool. Click Next on the Welcome screen. Connect the BlackBerry smartphone to the computer and allow the application loader tool to detect it. You might be prompted to type a password. Click Next on the Device Application Selection screen. Verify that the List additional applications that are installed on the connected device check box is selected. Record the value for the Total application space, located at the bottom of the window. Calculate the Reserved Pictures Memory for BlackBerry smartphones that have integrated cameras. If a camera is not integrated, proceed to step 12. On the BlackBerry smartphone, open the Media application. Display the menu, and click Options. Note the Reserved Pictures Memory value and multiply that value by 1024. Record the value. For example, 2 MB * 1024 = 2048. To calculate the Total Amount of Memory In Usage, add the values for Total Application Space, Total Size, and Reserved Pictures Memory (if applicable). To get the Calculated File Free value, subtract the value for Total Amount of Memory In Usage from the Total Flash Memory supported by the BlackBerry smartphone.
Oct 29, 2009 | AT&T Blackberry Curve 8300 Smartphone
Describe your AT&amp;amp;T BlackBerry Curve
BlackBerry smartphones support individual security passwords between four and 14 characters in length. The use of the password is designed to make sure that only the BlackBerry smartphone user can access the information stored on the BlackBerry smartphone.
The BlackBerry smartphone rejects less secure passwords, such as those composed of identical characters or those that consist of natural sequences (for example, 1234). In instances such as these, the BlackBerry smartphone will display the message The password cannot be a sequence.
Set a BlackBerry smartphone password
  1. From the Home screen of the BlackBerry smartphone, click Options.
  2. Click Security Options.
  3. Click General Settings. Note: If you are running BlackBerry® Device Software 4.0.2 or earlier, click Options, and then Security.
  4. Change the Password field to Enabled.
  5. Display the menu and click Save.
  6. Type your new password and click Enter.
  7. Verify your new password by typing it again and click Enter.
Change the BlackBerry smartphone password
  3. Click General Settings. Note: If you are running BlackBerry Device Software 4.0.2 or earlier, click Options, and then Security.
  4. Display the menu and click Change Password.
  5. Type your existing password and click Enter.
Turn on password protection using the Security Timeout feature Security Timeout is a feature that, after a predetermined amount of inactivity, will lock the BlackBerry smartphone automatically.
To turn on Security Timeout, complete the following steps:
  4. Set the Security Timeout field to the amount of inactive time the BlackBerry smartphone is permitted before it is locked automatically.
Note: Clicking Lock on the Home screen instantly locks the BlackBerry smartphone.
Unlock the BlackBerry smartphone
  1. Press any key on the BlackBerry smartphone to display the Enter Password screen.
  2. Type your BlackBerry smartphone password. Press Enter.
Important: If a password in incorrectly typed ten consecutive times, all of the information on the BlackBerry smartphone is automatically deleted. This is a security feature.
Additional Information When the Security Timeout feature is set for a longer duration than the Backlight Timeout feature, the BlackBerry smartphone will lock automatically when the combined duration of the features has elapsed. For example, if the Backlight Timeout feature is set to dim after two minutes and the Security Timeout feature is set for 20 minutes, the BlackBerry smartphone will not automatically lock until 22 minutes has elapsed.
Sep 10, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Cell Phones Logo
27 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
