Question about Amana Kitchen Ranges
My parents have a Halogen-Plus Counterange by Amana and the oven is turning on but as soon as it reaches 100 degrees it turns off, anyone know why or how i can fix this?
Stove top works fine, but oven only works to 100 degrees P8577204S E
    Problem Solver:
  • 59 Answers
Try RepairClinic.com. they have troubleshooting solutions for some models
Posted on Dec 03, 2014
SOURCE: Amana ARG7300w oven inop
It has a bad oven igniter.
Posted on Aug 27, 2007
SOURCE: Amana gas range ARGS7650 oven not working, stove top working
check clock has not accidently been switched to Auto this can also happen if someone has interupted the power supply
Posted on Dec 26, 2007
jumptrout51
  • 3361 Answers
SOURCE: GE Profile Oven does not work although stove does
Check and or replace the glow bar ignitor.
Posted on Feb 21, 2009
shinn8
  • 85 Answers
SOURCE: We have a Maytag Gas Range, Precision Touch
Likely your oven igniter is bad. Part number 74007498
Posted on May 18, 2009
shinn8
  • 85 Answers
SOURCE: maytog gas oven model 5765QDB--oven will not heat up
Sounds like your oven igniter is bad.
Part number is 74007498
Halogen tabletop oven
You can use any oven-safe dish that will fit inside the oven (preferably, with the low rack in place). I've seen 3 qt round casseroles that will fit when you aren't using the extender. (For example, this should fit: http://www.crateandbarrel.com/dining-and-entertaining/casseroles/lucerne-3-quart-casserole/s512853 ) Some casseroles are sold with non-oven safe lids. Make sure that you check the temperature range for the specific dish. Some are only rated to 400 degrees F.
Unfortunately, I do not know of any sources that sell the accessories separately.
I hope this helps.
Jun 03, 2013 | Fagor 12 Quart Halogen Tabletop Oven
Amana oven will not ignite
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/gasoventroubleshootvideo.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Jul 22, 2010 | Amana Ovens
My daughter's Amana gas oven ARGS765OSS turns off.
The F1 code is a faulty electronic control board EOC(clock).
Go to repairclinic. com and put in your model number for a good price.
Jan 03, 2010 | Ovens
Temp stays at pre-bake 170 degrees oven does not ignite
We are Amana factory authorized service and parts supplies. We have all the parts that you need for you oven.
You may contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we will give you all the information as well as get the correct part out to you asap.
We look forward to getting you up and cooking again.
Thanks, Ella
Nov 10, 2009 | Amana AOGD2750 Gas Double Oven
GE Self Cleaning Gas Range F2 Error, happens at 400 degrees and turns oven off any advice?
Your oven temperature sensor must be replaced. It is located in the oven compartment up high, may be right or left side depending on model. Smaller than a pencil about 3&1/2 inches long.
Jul 25, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Amana ACS3350AS stove temp in oven stays at 100 degrees . takes 1/2 hour to light or get to set tempeture. replace senor temperature and control panel. what should i do now
We had the same problem and it turned out to be a burned out lower heating element. Only the top one was heating and I could never get it over about 150deg or so.
Mar 16, 2009 | Amana ACS3350AS Gas Kitchen Range
Temp stuck on 100 degrees
try unplugging the range for at least 30 minutes
Feb 08, 2009 | Amana ACF3355AS Gas Kitchen Range
Errorcode F4 Amana ART6610E
Hello Welcome
F4 means on an Amana Range or Oven:
Condition is a open or shorted oven temperature sensor
Check and or Replace oven temperature sensor
Please remember to leave a solved rating before you leave
Huum at your service
Dec 21, 2008 | Ovens
My Kitchen Aid Supuerba top covection oven will heat to set temp 350-400 then drop over 100 degree's but still read on digital display 350 or 400
how do you know it is dropping 100 degrees ?
If the set temperature is 350-400 the heaters will work untill the thermostat will read that the temperature is reached - after that the heaters will shut down and the temperature will drop...and after few minutes when the temperature goes below thw set point (in this case 350-400) the heaters will turn on again - this will happen for the duration of the timing you have selected (example 45 minutes)
Oct 04, 2008 | KitchenAid Kitchen Ranges
Kitchen Ranges Logo
87 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
