Question about Refrigerators
When I press the ice depenser lever nothing happens no noise at all and no ice in glass.
The ice maker is working fine it has ice that part is working normally it is just the ice depenser lever no ice coming out there.
    New Friend:
  • 11 Answers
Your dispenser is probably broke. You should get someone to come repair it for you. I have had something similar happen to me before.
Posted on Nov 27, 2014
Ice despensor is switch is not working but it is still making ice that I retrieve by pulling ice bucket out and dumping in bowl or glass?
EDIT: Go to the end of my reply and try the last suggestion first please? Sorry, I got ahead of myself.
You should cut off the water supply to the fridge and empty the ice receptacle then you can start removing the ice/water dispenser cavity while looking for the switch that the ice dispenser actuates to get the motor turning. I would start there and use a multimeter (VOM) to test the switch, if it checks okay I would then look at the motor that drives the auger (screw looking thing that moves the ice to the dispenser tube).
Though, if you hear the motor running when you hit the switch? The ice could have just fused around the auger and gently as possible, breaking it up may be the fix the problem and you'll be good as new. Put your ear against the freezer door while pressing the ice dispenser switch to listen for the motor as it may be very quiet through all of the insulation without the noise of the ice that usually is getting pushed through?
PS: I would try my last suggestion before emptying the bin and checking the switch and motor as if you hear the motor running this will tell you that the switch and motor are functioning.
Apr 18, 2015 | Refrigerators
Samsung refrigerator ice maker
could be the micro switch. need model number.
Oct 14, 2013 | Refrigerators
I put a glass in the ice cube tray to chill it and forgot about it. The ice depenser froze over but that was easily fixed. Now the ice cube maker isn't making cubes.
You may have pushed the bail up which cuts off the I M
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 19, 2011 | Whirlpool Refrigerators
The ice maker works perfectly in my Sears Kenmore Elite Refrigerator, but the ice crusher doe snot work. When i put the glass under or I push the lever, no ice comes out. I have removed all the ice sevral...
Push the lever to dispense ice and listen for a small click sound,(the micro switch). If you hear a click you will have to determine if there is a broken wire to the dispenser motor or if the motor itself is defective, This will not be a visual diagnosis unless you fine a broken wire in the hinge area.
Nov 19, 2009 | Frigidaire FRS-26DR7D Side by Side...
The ice maker works fine but we can no longer dispense ice from the door. No sound, nothing. Water dispenser works fine though.
There is a micro switch behind the panel above the dispenser lever. It's the switch that the leaver presses on when you push a glass into it to fill with water. Pop the panel off and you will see the little black switch I'm refering to.
Aug 15, 2009 | Whirlpool GD5SHAX Side by Side...
Ice Maker frost and freeze where ice drops into refrigerator door
You need a service guy to look at it. It could be water leaking or a simple case that the flap isnt sealing and the ice melts and then freezes the flap open
May 14, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
The ice maker may need to be reset or the ice dispenser lever pulled. You posted on the samsung unit page, so I'm giving you the site to purchase anything from: samsungparts .com. The troubleshooting for pulling the lever is basically to watch the flap to see if it moves when lever is pulled. If it doesn't move, write here for more troubleshooting or call samsung.
Feb 26, 2008 | Samsung RM255LASH Side by Side...
Icemaker doesn't work - no ice ejected
Krakus, there is no fuse in the dispenser assy., but there are two switches mounted on the control bracket. The posts on the brackets that hold the switches are really thin and it's possible that it broke. Therefore when you are pressing the lever you are not making the switch and sending the juice to the auger motor. Remove the dispenser cover by inserting a flat blade screw driver in the slots at the bottom. Pry out gently and the cover should pop off. Then slide it up and off. Now you will be looking at the control bracket and see the switches on the left and right side. See if the switch holder is broken. If this is the case your part number is 2183771. Not a hard job, just have to take your time. Im assuming that when you tested the auger motor you verified that the drive coupler was not broke. back
Dec 18, 2006 | KitchenAid KSCS25FKSS Side by Side...
Refrigerators Logo
89 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
