Question about Alps MD 1300 Thermal Printer
Is the test print from an Alps MD 1300 supposed to be black print only?
I powered on the printer, loaded paper and pressed the Insert button for 5 seconds.
    Problem Solver:
  • 6 Answers
Wow.... last made in 22007 according to the ALPS USA website. From what I read, it should be a dynamyte printer. Several things to consider.....
1) how long has it been since you thoroughly cleaned the machine... or spent the$$ to have maintainance done on it. 6 years of use and rubber rollers get slippy, paper feed mechanisms need cleaned and resurfaced (this isgeneric info.... i never have worked with an alps)
2) this is a dye "sublimation" printer whose print mechanism moves the sheet through the mechanism 4 times (one for each color) so check and see if there is buildup of dry print medium or lint--paper dust blocking. (Airblast first, then clean with one of those long wood stick q tims. Dipped in alcohol.
3) check your printer drived ssset-up. Some printers can be set to greyscale only. reload your driver. I believe I saw a link saying drivers can be had at driver.com (or was it drivers?)
Also, frim 2007 may not be compatable with win 8. Or win 7. Probably will work with good ol windows xp. Put a good firewall on XP and limit it to only allowing printer calls assigned to whatever port.
Good luck
Sam
Posted on Nov 27, 2014
fcollingwood
  • 58 Answers
SOURCE: Alps md 1300 only prints in black
First of all, Alps MD inks do not "Dry up". They are dry to start with!
It sounds like you may be running XP, with the Microsoft driver for this printer installed. You need to load the Alps driver, which you can get by joining the alps or alpsdecal group at http://groups.yahoo.com. You can find the driver in the files section of one of the groups.
Posted on Mar 20, 2008
fcollingwood
  • 58 Answers
SOURCE: lines through my md 1300 alps printer
It sounds like the head has been damaged. Unfortunately, there is no fix for this, as Alps stopped production of these printers years ago, and now do not offer repairs for these printers.
If you still want a dye-sub capable Alps printer, the only model available is the MD-5500, which you can find here: http://www.alps-supplies.com
Posted on Mar 21, 2008
  • 758 Answers
SOURCE: Problem Printing with Alps MD-1000
Have you ininstall the device and reinstall it? Do you have any pending print job?
Posted on Apr 22, 2008
fcollingwood
  • 58 Answers
SOURCE: Alps MD 1000 self tests okay, but printing gives "nonvolatile error" (fast blink)
This is a symptom of the following:
You are running XP, and have installed SP3 and, you are using the microsoft driver bundled with XP.
The solution:
The m$ driver will have created a printer with "(MS)" as a suffix. Leave this intact, as it will cause major trouble on every reboot if you delete it.
Download the appropriate driver from the Files section in the Alps YahooGroup found at http://tech.groups.yahoo.com/group/Alps/
With your printer unplugged, install the downloaded driver
Shut down your computer and hook up the printer
Reboot
XP will detect the printer, and create a new printer in Control Panel without the "(MS)" suffix
Make the new printer your default printer.
The reason why you do not delete the printer with the "(MS)" suffix, is because every time you reboot, XP will ignore the fact that you have the correct Alps driver loaded, and will create a new printer using the m$ drivers, and set it to default. Of course, the m$ Alps driver is fundamentally broken
Posted on May 24, 2008
fcollingwood
  • 58 Answers
SOURCE: Alps MD 1300
The printers are out of production, and out of support.
Posted on Oct 23, 2008
Is there a way to determine the number of pages an Alps MD-1000 has printed, like a mileage gauge on a car.
Yes. It's very easy. Turn the printer off, unplug it, and disconnect the printer cable. Insert two sheets of paper, and make sure the paper feed is set to automatic. You need to have a black cartridge loaded into the 1st slot.
Plug in the printer and wait for the lights to turn off. Press and hold the power button at the same time press and hold the "ready/Insert" button. Release the power button, but keep holding the "ready/Insert" button for at least 4 seconds. After 4 seconds, release the "ready/Insert" button and quickly press it again. The printer will start the selftest.
For the 1300, the number of bands printed will be on page two. On the 1st page, there will be a black bar on the bottom of the page. It should be a solid black bar with no lines - this is the test for bad elements on the print head.
Aug 29, 2011 | Alps MD 1300 Thermal Printer
How to test the MD 1300 , also look on how to get error codes...
One test you can run is the self print test. Discount the printer from your computer. Load a single sheet of paper and the CMYK cartridges. Turn on the printer. Press and hold the "reset" button until the lights begin to flash. Release the "reset" button and the printer should do a self print test.
Dec 26, 2010 | Alps MD 1300 Thermal Printer
I'm looking for the manual for the Alps MD-1300 printer, I need to know how to print spot colors
The 1300 prints spot colors the same way as the other ALPS printers. To print spot colors, create a mask or layer using only black with your artwork. Select the spot color you want and the black areas on the mask will be printed in the spot color. Make sure that you check the overlay box so the printer retains the printer. You also need to make sure you are using the ALPS printer driver supplied with the printer and NOT the default Windows plug and play driver.
Nov 26, 2010 | Alps MD 1300 Thermal Printer
Will not print. turns on lights up makes noise
There are two self tests you can try to test the printer. With only the black cartridge and on sheet of paper. Disconnect the printer from the computer and unplug it. Plug it back in and do the following:
Press and hold the power button. At the same time, press and hold the Ready/Insert button. Release the power button, but keep holding the Ready/Insert button. After 4 seconds, release and press the button again and release. It should print a one page diagnostic test.
The second self print test using all 4 cartridges. Turn the printer on, press and hold the Ready/Insert button for a few seconds and release the button. The test will use all 4 inks.
Jan 02, 2010 | Alps MD 1000 Thermal Printer
Button sequence for head test (to look for banding)
Turn the printer off.
Load a sheet of white laser paper.
Press and hold the "Power" & "Ready/FF" buttons at the same time.
Release the "Power" button, and keep pressing the Ready/FF" button.
Right after you release the "Power" button, count 4 seconds, and release the Ready/FF" button.
Immediately, press and release the "Ready/FF" button one last time.
The printer should start printing a series of letters, numbers, horizontal lines and a black solid bar at the bottom of the sheet.
Once this test page is completed, turn the printer off to stop the test.
Feb 06, 2009 | Alps MD 1300 Thermal Printer
Diagnostics Mode
you can find that at their website, under tutorials or get the user guide there.
Aug 19, 2008 | Alps MD 5000 Thermal Printer
Apr 22, 2008 | Alps MD 1000 Thermal Printer
Oct 05, 2007 | Alps MD 1300 Thermal Printer
Alps MD 1300 Thermal Printer Logo
Top Alps Office Equipment & Supplies Experts
Jesse Walters
Jesse Walters
Andrew Taylor
Andrew Taylor
Are you an Alps Office Equipment and Supply Expert? Answer questions, earn points and help others
