Question about Viking Ovens
How do I replace a ribbon element in a Viking oven.
I am trying to remove the old element. It's hanging by the wires but I don't know how to get to the ends of them to unplug them.
  • Viking Master
  • 842 Answers
Hi, I would like to help you but I need more information. What is the model number and the first 6 numbers including the letter of the serial number please. Also I need to know what ribbon you are referring to as in the location of which component you are referring too wold greatly assist me to assist you. General questions get general answers, because I can't see it I need you to elaborate more information please. Thanks
Posted on Nov 27, 2014
ranger25
  • 72 Answers
SOURCE: GE Oven bake element not work
It sounds like a problem with the selector switch. You have to remove the back panel to get to the back of the switch in the head unit, and find what wire goes from there to the bake element. With a meter set on 240ACV, or whichever setting is on yours that's HIGHER than that i.e. 400ACV, with the red probe on the terminal and the black one going to ground, see if you are getting 210-240 through it. If so, then it's either a faulty neutral wire connection (the other wire coming out of the element) or the selector switch. Hope this helps.
Posted on Jan 29, 2008
murdozzz2
  • 75 Answers
SOURCE: Neff Fan Oven Element _U1661
hi there green and yellow is allways the earth connection which is usually the middle tag, what are the colours of the remaining wires and how many are there???
Posted on Feb 09, 2008
aborcass
  • 2651 Answers
SOURCE: Replacement of bottom oven element for Whirlpool oven
its only screwed in to back wall no???if screws rusted well then drill htem out.hidden bake elemnet??hidden under oven cavity??in that case right side wall of unit comes off( a few screws down back side of panel and it removes from the side.(shut power first this element is always live!!!!!!!
Posted on Feb 24, 2008
dgjtex
  • 405 Answers
SOURCE: Install bake unit in GE wall oven model JKP07J
I honestly believe you are right. you should be able to wiggle it back and forth and pull it out.
Posted on Dec 27, 2008
SOURCE: replacing electrolux eob944 fan oven grill element
...If you can help me to remove the grill element from my EOB944, I will be able to tell you the wirings.
Posted on Jul 08, 2009
I have a Thermodor SCD302ZP Double Convention Oven. Does the lower heating element come out from the front of oven or do you need to gain access to rear in order to test/replace it? I removed the...
that model number doesn't come up.first make sure the power is off to the machine,you have 240 volts going to that element,all the thermodor ovens i worked on come out from the front,there should be two phillips screws holding it in place,remove the screws and pull the element forwards,some of them you have to lift the element up the end that goes through the wall is bent up so the wires don't hit the metal wall behind it.on some the wires are very short so don't be surprised if they pop into the hole on you,try to hold it with a needle nose,have the other element in there and stick the wire right on the new element so you don't loose the wire into the hole,if that happens you might have to pull the oven and remove the back panel.good luck and i hope this helps you
May 11, 2011 | Ovens
I am trying to install my oven element. I am replacing old one. Oven is Westinghouse Model POL667S
tand pull the elelment out about 3". The element should lead back to a small plate at the back of the onen. Remove the two screwsi at the back of the oven.
Pull the element out about 3" and this will expose the connecting
wires, dissconnect them and remove the element. To install the new one, Just
do the removal procedure from last to first.
Nov 30, 2010 | Ovens
Needs bottom heating element where can I get the part?
If you are sure the element is out and I am sure you know, be sure to write down the name of unit, model, serial, and if it has one the product number. you can take out the bad element and take it along also to any appliance parts house. Just look in the yellow pages.
BE sure that you turn off the power before removing old element!
Sincerely, shastalaker7
Oct 28, 2009 | Viking VESO176 Stainless Steel Electric...
Wehre is model number located on viking oven?
It is usually on the stove at the bottom of the oven door. you might have to remove it to read it properly
Sep 18, 2009 | Viking Ovens
Oven element replacement- Simpson eziset electric
hiya
firstly make sure the power is isolated before removing any panels.
sometimes the element will just screw out from the inside of the oven and should pull through into the oven compartment with the wires attached, simply remove the wires, replace the element and refit any panels.
hope this helps
please dnt forget to rate the helpfulness of this reply thanks kj
Nov 11, 2008 | Ovens
Frigidaire GM deluxe electri dean (electric oven wall unit)
if you feel through the insulation you can find the two wires that attach to the element pull them through to plug the element back on but there is no plug per say but first are you sure the element is good were there no wires on the element when you removed it should have been two spade connectors with wires on them attached to the element hold my rating till you reply
Jan 11, 2008 | Frigidaire FEB27S5A Electric Single Oven
Viking: VEDO205 Blew my inner glass door
If you can take the door apart then you can fix it. Remove all the retaining screws to access the inner glass.
Dec 11, 2007 | Viking DEDO205 Stainless Steel Electric...
Bake element in smaller oven replacement
I always unplug oven or turn off power make sure though it will bite ya and hard after turning power off if you do it at the breaker turn stove top on make sure it don come on remember its 220volts and it hurts open oven door remove all racks.Then remove the screws mounting element to oven pull gently towards you (you may have to lift the front up a little) pull old element out until you see the spade connector (plug ins with the wires attached) remove these should be two of them be careful not to let wires go back into the cabinet put new element in hook wires back up to wires push back into the hole and put screws in turn power back on and test. this can also be done by taking the back off also and doing the same thing in the oven.hope this helps ya
good luck
Dec 07, 2007 | Ovens
Viking oven won't turn on
I had same problem (twice) with my Viking dual fuel range. In my case a relay that supplies power to the oven heating elements failed. The convection fan would run. The elements were warm to the touch. If you have a free standing range, it may be that relay (part number PM010026) which is located in the front of the stove. Remove a long narrow stainless steel panel (1 screw each side) located under where the door hinges. You can hear the relay click when you turn up the oven thermostat. That will help you locate the relay.
Note: Viking does not sell parts. You have to find their parts distributor for your part of the country.
Sep 20, 2007 | Viking DEDO205 Stainless Steel Electric...
Ovens Logo
77 people viewed this question
Top Viking Ovens Experts
Dan Webster
Dan Webster
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Viking Oven Expert? Answer questions, earn points and help others
