Question about Eureka Vacuums
How do I replace on off switch on Eureka 2998 Uno upright vacuum?
  • Gib Souza
    Gib Souza Nov 27, 2014
    I am sorry but that is a very unhelpful answer. I figured it out myself. You simply take a thin blade screw driver and gently pry up the oval housing around the switch until it pops out. Replace the wiring and pop the new switch back in place.
  • Rocguy Nov 27, 2014
    I was not trying to be smart about it. I figured you would have a long wait getting a reply on an issue I suspected would be rather simple. I've taken a vacuum apart before and tested the switch. I was encouraging you to go for it. I'm glad you got it.
    Sergeant:
  • 252 Answers
When you take it apart, it should be pretty self apparent.
Posted on Nov 27, 2014
Testimonial: "Terrible answer. See my comment for solution that I came up with."
reddevil6
  • 1673 Answers
SOURCE: Eureka Uno brush not spinning
There are 2 or 3 screws on the top to take out and the top cover will come off. Belt is #61120A U long life, brush roll if you need it is #62365-2. If the brushs look ok and the ends turn freely, then it is probably ok. The belt goes around the brush roll then up to the motor shaft.
Posted on Mar 02, 2008
SOURCE: looking for Eureka belt 70646A for a Eureka The Boss upright
I just replaced the belt on my Eureka The Boss Smart Vac (Model 4870D). I purchased a namebrand Eureka R belt from a local vendor. I did my best to follow the instructions printed on the bottom of the machine. I turned on the vacuum cleaner and the belt brush was spinning! I dropped it into vacuuming floor mode and the belt wouldn't spin no matter what level I put it on.
I called the manufacturer (1-800-282-2886) and spoke with a very nice woman on the phone. While I was speaking with her I noticed that a silver screw was lodged within the "brush roll control" yellow selector switch. With some shaking it became dislodged and I was able to put the "brush roll control" into the hard floors setting and turn the "carpet height adjustment" all the way to the right, so that it was facing the word "low." I then followed the instructions for replacing the belt again.. (1) remove base plate (2) remove brush roll (3) place new belt around motor shaft and then around brush roll (4) insert left side of brush roll before right side (5) rotate brush roll to be sure belt is centered (6) replace base plate, making sure to insert under 4 little tabs before securing with screws.
It appears that it is very important that the carpet height and brush control adjustment are set to their highest point possible (hardwood setting) in order to get the brush to roll in a carpet setting.
"R" is the correct belt for the 4870 and should be correct for all other 4800 models.
Thank you for posting your problem to this website. If I hadn't seen that others were having trouble, I would have just given up. I hope this long post helps someone that was in my situation.
Posted on Aug 06, 2008
  • 22 Answers
SOURCE: how to put on a belt on eureka uno bagless vacuum cleaner
Unplug the vacuum.
Turn it over so you have access to the bottom of the unit (you should see the brushroll)
At the base where the "head" attaches to the body there is a small silver button that you must depress to remove it from the body. Press the button in with a screwdriver or unsharpened pencil while pulling the "head" away from the body.
Use a #2 Philips screwdriver to remove all the large screws from the bottom. They are all the same size and type so you can collect them for safekeeping without worrying about which one goes where. There are 2 smaller screws (if I remember correctly) that are for the upright lock that you do not need to remove. They will be on the small plastic piece near where the bottom brush "head" attaches to the vacuum.
Remove the clear plastic clog cover.
Gently pry the gray cover off. This shouldn't be too difficult as the cover goes loose when you remove the screws.
Flip the gray side over and you should see the innards including the brushroll, the motor, wiring, etc. Facing the assembly like you were looking head-on at the vacuum the belt should be on the right.
Pull up the far end (non-belted end) of the brushroll and then the belted end.
The brushroll should now be free and you should check the teeth on the belted end of the brushroll to ensure none are broken.
Remove the old belt from the motor (also toothed) and replace with new belt (a second spare would be handy to keep around and this is a good opportunity to clean up the air path).
Put toothed end of belt into the belt loop and stretch it a bit to get the toothed end back into place. The belt should auto adjust but just in case you may want to manually rotate the brushroll a few times after replacing the far end (non-toothed end)
Repeat the rest of it in reverse order to put it back.
Posted on Feb 03, 2009
SOURCE: Eureka boss smart vac 4870 upright-How to replace on/off switch
This just happened for the second time with our 4870. It about $8 part with shipping (total of $12) from 24x7 vaccum. Pretty easy to change out.
Posted on Apr 08, 2009
  • 3 Answers
SOURCE: I want to replace the belt on an upright eureka
I just replaced the belt on my 4481. Very simple. Be sure unit is unplugged. Unlock handle and let it lay down. Remove two screws on plastic cover. I purchased my belt at target for 2.54. Part number anywhere is Eureka U. Remove the roller brush. Loop belt around drive motor first and then around roller brush inserting the roller back into place belt side first. Replace cover and your ready to go. 10 min fix.
Posted on Sep 04, 2009
Eureka Uno Model 2999. I need instructions on how to replace the belt.
I think you will find the free manual at this URL to be helpful
http://www.eureka.com/service/manuals/80247.pdf
Oct 13, 2010 | Eureka Uno 2998AZ Bagless Upright Vacuum
Hi i am trying to find a manual for my eureka power paw model 8852..but have hand no luck finding out where you can get one..any where you know of i am in great falls, mt
You can download the owners manual from below site. About midway down the page, click on "Owner's Guide" tab. Right click on "Owner's Guide" and left click "Save Target As". Save to a file dedicated to your Vacuum.
http://www.eureka.com/CapturePlus-Pet-Lover-8852DVZ-upright-vacuum
Oct 04, 2010 | Eureka Uno 2998AZ Bagless Upright Vacuum
Eureka Model 8852 bvz belt for beater bar belt is broke
You need to replace it. Here is a link to the belt you need and the manual which has instructions:
Eureka 8852 Belt
Owner's Guide (1.36 MB download)
Dec 17, 2009 | Eureka Uno 2998AZ Bagless Upright Vacuum
What type of belt does the Eureka Uno take?
Here is a link to the belts for the Eureka Uno models and a manual you can view which has instructions.
Eureka Uno Belts and Manual
Dec 15, 2009 | Eureka Uno 2998AZ Bagless Upright Vacuum
It smells like something is burning and then I saw smoke coming from the bottom, where the roller brush is.
That means that the belt is very worn and it is slipping on the motor. You need to replace the belt. Here is a link to the belts you need and a manual you can view with instructions:
Replacement Belts
Owner's Guide (3.4 KB download)
Dec 08, 2009 | Eureka Uno 2998AZ Bagless Upright Vacuum
My eureka bagless uno vac problem is when I use it the belt gets really hot and starts smoking
try to manually turn the brushroll. if it feels tight then u will need a new brushroll. otherwise try replacing the belt
Jul 13, 2009 | Eureka Uno 2998AZ Bagless Upright Vacuum
Handle from my Eureka Uno 2999 AVZ broke off
try a company called cds they r in the midlands but they courier parts out 2u dont have their no 2 hand u will need the model number try the web marting
Mar 17, 2009 | Eureka Uno 2998AZ Bagless Upright Vacuum
How to put on a belt on eureka uno bagless vacuum cleaner
Unplug the vacuum.
Dec 03, 2008 | Eureka Uno 2998AZ Bagless Upright Vacuum
Mar 01, 2008 | Eureka Uno 2998AZ Bagless Upright Vacuum
Vacuums Logo
74 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Irene Tulloch
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
