Question about Honeywell Programmable Thermostat Heater
What can make the screen go off and the heat and airconditioning not work
We first noticed that the thermostat screen was blank and then the heat and airconditioning were not working it is all 2007 equipment
  • 42 Answers
Sounds to me like a breaker has popped. In the main power panel, see if one of the breakers is in the center position.
Posted on Nov 27, 2014
Thermostat is not coming on we are in san antonio is there help out there for us
Reasons for a Blank Screen on a Honeywell Thermostat ...
homeguides.sfgate.com > ... > Real Estate Rental & Lease Basics
Honeywell and other brands of programmable thermostats typically show a blank ...and the batteries can no longer provide power to the screen, it will go blank. ...electrical system, a blank screen indicates there is no power going to the unit, ...
programmable thermostat troubleshoot - YouTube
? 3:35
https://www.youtube.com/watch?v=pNVTAUcBx-U
Sep 26, 2011 - Uploaded by Maxxmentum
Programmable thermostat started to fail and behave erratically after being in service for a few ... My thermostat works but the remotes have stopped working. .... Honeywell CM907 Digital Programmable Room Thermostat user ...
HEAT WON'T TURN ON How Test if your Thermostat is ...
? 2:36
https://www.youtube.com/watch?v=lSJn69EAcAw
Nov 16, 2014 - Uploaded by You can Fix It!!!!
Heater fails to turn on it does not mean you have a faulty heating system ... 4th - Check programming on a programmable
Jan 10, 2016 | Honeywell Programmable Thermostat Heater
After a power cut, how do I set my Ultecon FAN0983
Seams that your device is NOT a Computer Router Issue, BUT Rather a Home Thermostat issue. I recommend looking up an AirConditioning/Heating Service, and/or Look up ULTECON online for better results. Thanks.
Jun 28, 2014 | Computers & Internet
I have ducted airconditioning in my home and the programmable thermostat is completely blank and the whole system is not turning on, could you please help me in trying to troubleshoot this matter...Thank...
The transformer or fuse is blown... check the circuit board for a fuse and then check the transformer for 24vac...
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Jan 15, 2011 | Carrier Heating & Cooling
I have a Honeywell 7 day programmable Thermostat. I've noticed that the screen goes blank every so ofter. Is this a problem?
Sounds like you are loosing the low voltage when this happens either from a loose connection or a possible short. Make sure all connections are tight
Dec 11, 2009 | Honeywell Electronic Programmable...
Honeywell thermostat t8400c intermittent blank screen
It actually sounds like the batteries are going dead if the 24v from the furnace are not providing the power to the thermostat.
Sep 28, 2009 | Honeywell Electronic Programmable...
Readings disappear on thermostat for awhile then come back
Hi Linda,
There are a few things that cause this:
  1. When the heat is starting, it will sometimes go blank for a few minutes and then resume.
  2. Most have batteries, replace them with fresh new ones, if the electricity goes out while you are away, the batteries will keep the settings.
  3. Have someone check the house when it is extremely cold or hire a service to monitor. Your alarm company can usually add temperature sensors to your home, it will add a little safety net for you.
Hope this was helpful, please rate my answer.
Thanks,
Paul
Jan 27, 2009 | Honeywell Programmable Thermostat Heater
Chronotherm III Thermostat Completely Blank Screen, No Heat
One of two things either the disply has gone out which is likely as it is a common failure for that thermostat or your heating unit is not sending control power. the older chronotherms were system (24volt ac) powered the new hardware/box store units are battery powered. Either way display should not be blank with fresh batteries. to get heat on remove the thermostat jumper or twist together the wire from the R terminal with the wire from the W terminal. note the color of each wire for later reference, heat up house disconnect wires from each other and go purchase a new thermostat
Dec 17, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
129 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
