Question about PIAA 2001 Mitsubishi Montero Sport - All Montero Sport models - Xtreme White Bulbs
HOW DO I FIX IT
NO START. SO I PUT MY CODE READER ON IT . AN THIS IS THE CODE THAT COMES UP P1610
  • 406 Answers
Info here seems relevant... too much to explain here. You will have to review and see.
Make: Mitsubishi Code: P1610 Definition: Immobilizer System Malfunction Also posted by Steve Brock @ fixya
have 2001 Mitsubishi Montero Sport wont star scan it got code p1610 no...
Posted on Nov 27, 2014
Suzuki swift 2011 not start code p1610
not start, so, car cranks, ok and will not start, , RIGHT?
That code is from a real scan tool???????
which engine is there, of the 5 or so?
1.2 L I4 (petrol)
1.3 L M13A I4 (petrol)
1.5 L M15A I4 (petrol)
1.6 L M16A I4 (petrol)
1.3 L I4 (diesel)
in what country is car, (1million posts here and not one ever said that)
and varies by guess what?, COUNTRY.
P1610 (is power train code =p)
i have no books on non USA cars. nor access to them
so not saying COUNTRY , forces me to guess engine and codes.
so i did what you failed to do , i searched on FIXya forum
and found this.
my best guess , would be... as per below. (no real FSM)
I see only 1 , a Reno. wrong car, but my online source shows no usa swift data at all. 2011
P1610 is a resulting DTC from the "LOCK MODE" condition which is set for various NATS malfunctions or an improper key being used. It prevents the car from starting (for some period of time, even if the key issue is rectified).To reset a NATS lock mode, a proper key must be cycled three times again to get the car to start
we only have 2001
here
https://suzukipitstopplus.com/Products/1173-2001-swift-service-manual.aspx
sorry
Oct 11, 2014 | Suzuki Swift Cars & Trucks
Solution p1610 codes
Check fuel pump is working check module in distributor or sensor on front pulley.
Aug 30, 2014 | 2005-2008 Suzuki Swift 4dr D Speed Full...
What is p16ff code for nissan
all of my research keeps coming back to p1610 for the P16ff Code but I am not sure.
The code P1610 is a problem with the NATS, or better known as system of vehicle immobilizer. And this arose out of the following:
-are using a q-key is not registered or not transmitting the code
- BCM or ECM are evil, and
now is in "locked mode"
you can do something quick:
1. Confirms the code q yields
2. EXIT THE LOCKED MODE. If the code is p1610 continues with the following with a copy of the vehicle key:
(1) -Place the switch to OFF
(2) -Place the switch in ON with the key registered(do not start the engine). Wait 5 seconds
(3) -Returns the switch to the off position. Wait 5 seconds
(4) -Repeat step 2 and 3 two more times (being a total of 3 times) (
5) -Starts the engine
with this test and write us if t worked. If this is not the case there will be q enter to detail by checking with the diagnostic charts and other things.
The other code does not exist or does not comply with the structure of a code
Aug 03, 2014 | 2007 Nissan Tiida 1.6
How to fix code p1610 on 2002 mitsubishi montera sport
P1610 - SBDS Interactive Codes Possible defective PCM.
Aug 29, 2012 | Mitsubishi Cars & Trucks
Nissan x-trail wont start. error code p1610 and p1612 come up
P1610 is loss of serial bus Data.
P1612 is a NATS error. this is the Anti-Theft system
It effecttively immobilises the car and it wont start until you have the faults cleared.
This can happen after a low battery voltage.
Feb 27, 2012 | Cars & Trucks
2003 Nisson Altima code P1610 and P1612. Anti theft problem how do I reset without taking to Nisson dealer?
P1610=Lock Mode--1 turn ignition switch OFF 2 turn ignition switch ON with registered key. (Do not start engine.) Wait 5 seconds. 3 Return the key to off position. 4 Repeat steps 2 and 3 twice ( total of tree cycles). 5 Start the engine. Does engine start ?? Yes...System is OK. Now system is escaped from LOCK MODE...if no start...Go to 3
P1612 is a lot of testing.......get back to me....
Jun 04, 2011 | Nissan Altima Cars & Trucks
My nissan try to cranck up but it wont start code p1610 and p1612 came out
my nissan altima 2002 wont start the battery is brand new and code P-1612 was found out what does the code mean
May 05, 2011 | Nissan Pathfinder Cars & Trucks
2001 mitsubishi galant 2.4 p1610 no start condition
It looks like it is a problem with the anit-theft system. Code p1610 is for an Immobilizer System Malfunction, usually set because the wrong key code was picked up by the anti-theft system. The procedure for checking it says to use a spare key that has worked in the past and if that doesn't fix it, you'll either have to have a licensed locksmith with the ability to reprogram your car to your key come out, or take it into the dealership to have it reprogrammed. The most likely cause for this is that haveing no battery power for a while as you described allowed the programmed key information to be lost. Good luck and hope this helps. keep me posted be glad to help.
Jun 08, 2009 | 2001 Mitsubishi Galant
PIAA 2001 Mitsubishi Montero Sport - All Montero Sport models - Xtreme White Bulbs Logo
216 people viewed this question
Top PIAA Optics Experts
Lawrence Oravetz
Vernon Taylor
Are you a PIAA Optic Expert? Answer questions, earn points and help others
