Question about Sharp LC52LE640U 52 inch 120hz AQUOS LED TV [LC-52LE640U]
I have a Sharp LC-52LE640U LDC 52" TV.. I bypassed the single blinking error code by pressing channel down and volume up buttons while plugging it in.. I got a picture and everything looks good....
I have a Sharp LC-52LE640U LDC 52" TV.. I bypassed the single blinking error code by pressing channel down and volume up buttons while plugging it in.. I got a picture and everything looks good.... except that the right half of the screen is a couple of shades dimmer than the left?? Is this the backlights? or power supply? or what else might it be? Thanks in advance..
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 53 Answers
It's probably one of the cathodes going to hell
Posted on Nov 27, 2014
SOURCE: Sharp LCD LC-46D64U
Try resetting the TV. Here's how to do it - Unplug the TV's power cable. Keep the Channel Down and Volume Up buttons on the TV pressed and plug the power cable back into the outlet. You will hear a click when you plug it back in if the reset is successful. Hopefully this should restore your video and audio.
Posted on Feb 06, 2008
SOURCE: TV No Picture
My 32D40U would turn on for 5-10 seconds (Please Wait would appear) and the screen would go black. Sound Normal. It would also sometimes do this after running 5-10 minutes. I read somewhere that the inverter board would come loose and lose proper ground. I took the set apart, removed the board, and cleaned up the grounding points. I reassembled using some copper paste on the ground points and LockTite on the screws. I used some contact cleaner on all the connectors going to the board. I noticed two cables that are covered with copper shield tape where too tight at their connectors and repositioned the tape to give them some slack. The problem hasn't occurred since the fix.
Posted on Mar 22, 2008
  • 8457 Answers
SOURCE: power light blinking green and cannot turn off or display anythin
power inverter board is dead.
need a new one.
Posted on Sep 14, 2009
SOURCE: Sharp 52" Aquos LCD Will Not Turn ON-Blinking LEDs
I had a similar problem. Fleeting video, then audio only for few seconds and then nothing except the green power LED blinking on and off.
I changed the power inverter board, backlight inverter boards and power supply board but still the problem is not gone.
Just 18 month old TV and out of warranty.
Posted on Sep 20, 2009
satavlad
  • 405 Answers
SOURCE: Sharp AQUOS LC-46D85U green LEDs blinking, no picture, no sound
Sharp warranty is the way to go.
Posted on Oct 25, 2009
How do I download latest firmware onto my Sharp Aquos LC-52LE640U?
hi does your tv have usb port if so, go to the sharp website look enter the model number of your tv look for firmware for your tv download it, then load it on to a usb flash drive, thanks
shaun
Mar 16, 2017 | Sharp LC52LE640U 52 inch 120hz AQUOS LED...
Mom's Sharp Aquos TV no sound or picture there is a green flashing light where the power light is I heled the volume up and channel down while the TV was unplugged. plugged it back in sound no picture
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 24, 2016 | Sharp Televison & Video
Sharp aquos TV lc-42d64u has blinking power light
Jun 07, 2016 | Sharp Televison & Video
I have a Sharp LC 52LE640U TV. It has a 1 Blink Fast and 1 blink SHort. I can Power Tv on with CH down/ Vol Up upon power up and it will show display. Only problem is; half the backlight on left si
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Some models Sharp TVs uses Philips kit. If yours is such, the blink count procedure is entirely different. It is not direct.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Jan 11, 2016 | Sharp LC52LE640U 52 inch 120hz AQUOS LED...
Any experience with a main board swap on a lc52le640u Sharp Television?
I would start by checking power supply voltages which should be printed near the output connectors.
Feb 03, 2015 | Sharp LC52LE640U 52 inch 120hz AQUOS LED...
Sharp aquos LC70LE650U 5 short flashes 2 long, no display
Try unplugging the unit and hold the volume up and channel down buttons down and plug the unit in. Let go of the buttons and the unit should come on up the service mode. There will be a small k on the screen. With the remote press the channel up button . This should bring up a menu that will show a lamp error line. If the lamp error is = to 5 the unit is in lamp error shut down. Use channel down to highlight that line and the curser right arrow to highlight the lamp error #. Hit the enter button to clear the lamp errors. Now unplug the unit and let it sit for a minute and plug back in. If the unit does not come on by doing this or if it does and you do not find lamp errors the power supply pcb may have been damaged .
Nov 20, 2014 | Sharp AQUOS LC-70LE650U 70" 1080p LED-LCD...
LC-32SB24U LCD HDTV... Brand new, just out of box. Turn on, goes to language menu for about 1 second max,too fast to adjust, then screen goes black and little green led power light starts to blink. And...
Good Day, texxastam;
Do this:
1. UNPLUG TV
2. HOLD IN VOLUME DOWN &INPUT buttons on TV
3. Plug in the TV. (the TV will turn itself on).
4. A blue "K" should now be showing on the TV screen, release the buttons.
5. Press and release the VOLUME DOWN & CHANNEL DOWN buttons simultaneously on the TV. (A blue service menu will appear on the screen).
6. Using the remote, press the DOWN SELECT button once. (The highlighted line should read INDUSTRY INT (+CAUSE) OFF
7. Using the remote, press VOLUME UP once (OFF changes to ON).
8. Press ENTER. After a few seconds the screen turns green and shows - Industry INIT success - at the top of the screen.
9. Unplug the AC cord for 10 seconds then plug back in.
Good Luck, big IRISH.
PS; I did not make this up... it's from SHARP> again good luck...you may have to do this several times....too...get the timming down.
Aug 07, 2008 | Sharp Televison & Video
Lcd sharp tv flashing green light
Try unplugging the unit and while unit is unplugged hold the volume up button and channel down buttons down and while depressing both buttons plug the unit in. Let go of the buttons and the unit should come on in the service mode. There will be a small k on the screen. With the sharp remote press the channel up button once. This should bring up a menu that will show a lamp error line. If the lamp error is = to 5 the unit is in lamp error shut down. User channel down to highlight that line and curser right arrow to highlight the lamp error #. Hit the enter button to clear the lamp errors. Now unplug the unit and let it sit for a minute and plug back in. I hope this corrects the problem. If the unit does not come on by doing this or if it does and you do not find lamp errors the power supply pcb may have been damaged by the surge.
Jan 06, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp LCD LC-46D64U
Dec 25, 2007 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp LC52LE640U 52 inch 120hz AQUOS LED TV [LC-52LE640U] Logo
305 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
