Question about Whirlpool Washing Machines
I have a whirlpool WFS1073CD and getting a red light indicator saying clean pump. It appears to be washing normally but wont go into the spin cycle. I have drained the water via the filter plug under
Have detailed above the procedures I have taken to correct the problem
  • Whirlpool Master
  • 1,150 Answers
Hi Maureen
Wow.... at least this model has an indicator light telling you what the problem is. Many machines don't!
I think the reason it won't go into the spin cycle is that the water can't exit through the pump.
The usual cause is that a sock or something is caught or blocking the pump.
Power OFF of course.
Follow the drain hose back to the pump & try unclipping the hose off either side to feel for a blockage with your finger.
Pump blockage is a common occurrence in washing machines.
Good Luck
Posted on Nov 27, 2014
Testimonial: "Hi Outback Jack For some reason all of my question didn't appear. Anyway I have already * blown up the out pump * Removed kick panel and emptied the blockage * tipped 1 litre of water down below the chemical dispenser as suggested in previous answers, although none of this has helped."
  • maureen wills
    maureen wills Nov 27, 2014
    Will try your suggestion now although am having trouble with not enough muscle to undo the screws
SOURCE: Whirlpool clean pump problem
This is from the Whirlpool user manual for the AWO\R 4205 - it tried it and it worked well, found a hair grip and some stones in mine!
We recommend that you check and clean the filter
regularly, at least two or three times a year.
Especially:
If the appliance is not draining properly or if it fails to
perform spin cycles.
. If the pump is blocked by a foreign body (e.g. buttons,
coins or safety pins).
IMPORTANT: make sure the water has cooled
before draining the appliance.
1.
Stop the appliance and unplug it.
2. Remove the plinth by using the separator of the
detergent dispenser (fig. .A.).
3. Place a container beneath it.
4. Open the filter but do not remove it completely.
Slowly turn the filter counterclockwise (fig. .B.) until
the water begins to drain out.
5. Wait until all the water has drained.
6. Now unscrew the filter completely and remove it.
7. Clean the filter and the filter chamber.
8. Check that the pump rotor moves freely.
9. Re-insert the filter and screw it in clockwise as far as it
will go.
10. Pour about 1 litre of water into the detergent drawer
to reactivate the .Eco system.. Check that the filter is
inserted properly and securely.
11. Reinstall the plinth.
12. Plug in the appliance again.
13. Select a programme and start it.
Posted on Jan 18, 2009
cbrown801
  • 3 Answers
SOURCE: washer wil not spin or drain out after cycle completed
sounds like drain is plugged. this is a fairly easy fix,and you actually get paid to do it. unscrew the bottom panel of your washer should be 3 screws on the very bottom then you will see a white plug that is about 2 1/2" unscrew it (make sure you have a bowl under it water will leak ) and pull it out. this is where you get paid you will find all kinds of change and junk just clean it out reinstall and your clothes will be a lot drier after the spin cycle
Posted on Mar 30, 2009
  • 57 Answers
SOURCE: Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Posted on Oct 10, 2009
barkencoa
  • 3463 Answers
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Posted on Jan 19, 2010
TheMobilian
  • 8220 Answers
SOURCE: Tub won't drain
The lid switch has a green ground wire and 2 hot wires. Jump them 2 hot wires and see if she pumps out.7bce33c.jpg025e16d.gif
More here
bypass it here for testing purposes. How it works: direct drive washer
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 12, 2010
I have a whirlpool wfs1073cd. Problem started with a blocked drain which I cleared ,restarted but the light came back on again .After many more starts and empting I replaced the drain pump .Cut long story...
replace the drum motor brushes perhaps {check there condition is at least 3/4" long}
check the fload protection switch in the machines base is level
if it has one
you can reset it by turing off the mains
press and hold the start stop or some use the on off
and turn the mains on wait a few seconds
and it will reset all cleared faults
Dec 04, 2014 | Whirlpool Washing Machines
Red indicator light on the cycle dial stuck blinking
Chek that the door lock is activated if not replace the door lock the other possibility is the anti flood device is activated so chek for a leak in the bottom of the machine
Jul 06, 2014 | Whirlpool duet Washing Machines
Whirlpool washing machine WFS1273AW manual
I have a whirlpool WFS 1273 AW front loader that gets stuck in the spin cycle. The timer counts down from 18 minutes to 17 minutes and starts to spin but before it gets to full speed the control panel lights all flash, go blank, and the. The timer resets to 18 minutes. I have cleaned he drain pump, removed the clothes and tried it when empty and it does the same thing. It does not appear out of balance.
Jan 04, 2012 | Whirlpool Washing Machines
Cannot find the exact machine i have which is WFS1073CD but this one looks similar. Red light is on to say clean pump, where is pump?The book we have is not in english
Your machine should have a lower front panel attached below the door. This would be a full width panel that goes from the floor up to almost the bottom of the door. Unplug the machine. Remove this panel with 3 or 4 screws. The pump is behind this panel, facing forward. The pump has a twist plug clean out. Use a shallow baking pan to catch the small amount of water that will come out of the pump when you open the twist plug. After cleaning the pump, assembly is the reverse of what you just did.
Good luck.
Jan 30, 2011 | Whirlpool AWM6141/1 Front Load Washer
Washing machine wont drain keeps bleeping ERR2
Jan 19, 2010 | Haier Washing Machines
BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
Feb 16, 2009 | Maytag PAV2300 Top Load Washer
Washing machine
bottom right corner behind the little door
Sep 27, 2008 | Whirlpool AWM5125/1 Front Load Washer
Whirlpool 6th sense awm8163 programes never stops now cannot get it to work at all
The pump is at the lower left of the front of the machine covered by a white plate. Use a bowl to catch any remaining water when opening the screw thread inside and then clean and replace. If it is truely beyond repair then a new filter pump can be bought from ebay for £3 or thereabouts.
I have just drained mine manually in this way and am going to run it empty with soda crystals to glean a few more days use whilst the new pump arrives.
Good luck :)
Jan 20, 2008 | Whirlpool AWM8143 Front Load Washer
Washing Machines Logo
310 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
