Question about Tablets & eReaders
I accidentally pressed the wrong off button to turn off my tablet it asked for my password non of my passwords worked there is a plus box and my tablet is locked. I don't know anything about computers
I accidentally pressed the wrong off button to turn off my tablet it asked for my password non of my passwords worked there is a plus box and my tablet is locked. I don't know anything about computers help 7
  • 1,150 Answers
Hi Janie
Dont panic... I'm sure there is a simple fix. But you really must remember your passwords better. There are many Apps and software programs to help you with this. Find a good method & stick with it. The future of passwords & security can only get harder.
You haven't mentioned what brand / model you are dealing with. This does make it hard for anyone to troubleshoot.
Find your manual. get an online PDF manual to learn the key sequences to press to wake it up or reset the device. Where did you purchase? Perhaps they can help!
Cheers
Posted on Nov 27, 2014
byteguy
  • 2229 Answers
SOURCE: forgot password
Tablet PCs aren't my specialty, but as long as you are running Windows XP. it should work like any other version of Windows XP.
Start up in safe mode and log on as administrator. If your computer is like most others, whoever set it up forgot to password protect the administrator profile. If so, you can log on as admin and go to users and change your password.
Good luck.
Posted on Mar 05, 2009
ajuhere81
  • 256 Answers
SOURCE: locked hp windows xp tablet edition
hi,
try to login with username as Administrator if you are using some another username.
there is one software also to reset the usename and password naming ERD Commander
Posted on Aug 21, 2009
steve_e_uk
  • 1675 Answers
SOURCE: I bought a Archos 9
hi, you could try...archos9...maybe that is it?, that is device archos, and number 9..if not try the serial number or model number, there should be a label on it with this on, if not check out the paperwork see if the model number is there with that..good luck hope this helps
Posted on Sep 15, 2010
SOURCE: how to factory reset toshiba thrive tablet. can't get past log on due to previous owners lock, unlock password
taking the battery out will do it
Posted on May 06, 2012
  • 15 Answers
SOURCE: how do i reset my kurio 7 tablet my daughter forgot the password
factory reset true Recovery mode
vol+/- homebutton last power key
realease home key and - vol when boot
in recovery mode select "FACTORY RESET" enter
"ERASE CACHE" enter
REBOOT DEVICE-
Done
Posted on Jan 11, 2013
Konica tablet I put wrong password how I reset I have tried reset button but still need password any ideas
The only way is to Factory reset which will erase all data. here are some instructions.
Step 1. With your tablet off, press and hold the volume up (+) button and power button until you see the RCA splash screen with Nipper and Chipper. Release both buttons to reveal the Android bot on his back with a caution symbol above him.
Step 2. A new screen will appear asking you to use your volume up/down keys to move and the power button to select.
Step 3. Use the volume down (-) button to highlight "wipe data/factory reset." Once highlighted, select using the power button.
Step 4. A new screen will appear asking you to confirm your selection. Use your volume down (-) button to highlight "Yes -- delete all user data." Press the power button to select once highlighted.
Step 5. Once the tablet is finished wiping data, you may press the power button to select "reboot system now." This will restart your tablet.
Jul 29, 2016 | Tablets & eReaders
How to restart my tablet without turning it on because I forgot my password?
Look in your tablet instruction book for a procedure called 'hard reset' or a location for a small hole on the edge or back of the tablet where you can push in something non-conductive, like a toothpick to press a hidden reset switch. Without having a make and model for your tablet, it is hard to determine what exactly to do because each make and model is different. You talk about pressing the power and low volume buttons- are you holding them both in simultaneously for 10 seconds? This might be the reset procedure for your tablet, but that is not clear. One last thing to try is to hold in the power button for 10 seconds and see if you get a power off screen. If you get this, try powering off the tablet and then restarting. Also make sure the keyboard isn't on caps lock when you type your password.
Jan 03, 2015 | Tagital Taital TM 7" Android 4.0 4B MID...
Log in not working
Hi If you forget your password the only way to make your tablet working is default reset. Turn it of then press and hold volume + with power button this allows you to enter service mode from there using volume buttons go to wipe data/ factory reset and confirm by pressing power button.
Apr 21, 2014 | Kocaso M752 Black WiFi 7" Android Tablet...
To many pattern attempt
  1. With the Samsung Galaxy TAB turned off, press and hold the VOLUME Down button, and then briefly press the POWER button.
Note: If you see "Downloading" on the screen with an Android shoveling you pressed the wrong Volume key. Remove and reinsert the battery and try again.
It should hard reset any of these tablets:
Reset GT-P6210 Galaxy Tab Plus 7.0 WIFI
Reset GT-P6200 Galaxy Tab Plus 7.0 WIFI + 3G
Reset GT-P6810 Galaxy Tab 7.7 WIFI
Reset GT-P6800 Galaxy Tab 7.7 WIFI + 3G
Reset GT-P7310 Galaxy Tab 8.9 WIFI
Reset GT-P7300 Galaxy Tab 8.9 WIFI + 3G
Reset GT-P7510 Galaxy Tab 10.1 WIFI
Reset GT-P7500 Galaxy Tab 10.1 WIFI + 3G
Apr 15, 2014 | Samsung Galaxy Tab Tablet PC
Mt son forgot password on RCA 7" tablet it is a pattern password
Hi, you can try resetting by following the below steps. It works for most tablets.
1 turn off the tablet
2 press and hold the power button and keep tapping the volume down button at the same time.
3 it should take you to recovery screen. Go to factory reset by using volume button and select by using either the center button on the tablet or the power button if there is no center button.
Please reply if it helped
Mar 25, 2014 | Tablets & eReaders
Kindle say authentication problem when trying to connect to wifi
Im sure you would have typed wrong password. please make sure you have correct password typed.
-regards
Mar 01, 2014 | Amazon Kindle Fire HD
Put in wrong password for wifi and then accidentally hit forget and now it wont let me type in a password at all
You need to select the wi-fi website again, and enter the password again. It will then store the password.
If you forget the site, it forgets the password connection to the site and you have to start again.
Feb 14, 2014 | Kocaso 1.2GHz 4GB 7 inch Capacitive...
Password crack
hard reset press power and volume plus together when android gear appear release the power button and volume plus press volume down.wait if rebooting says ok
Jun 17, 2013 | Huawei mediapad 7 s7 931w wifi tablet
Forgot password on azpen G7 tablet,do not know how to access tablet
turn on tablet get the password wrong and press forgot password after you tried it 5 times.once you press forgot password the tablet will reset your tablet and let you put a new password in unless you dont want to
Feb 20, 2013 | Azpen G7 Android Tablet
Dgm t-909 tablet my son set a formation password has either forgotten it or tried too many times and locked it. i tried the reset button and nothing happened
Hold down the power button and the up volume button at the same time for about 30 -60 seconds. The device should go to the factory reset screen if not use power on button to get to the screen. You will lose all data stored. I know this works as I have just done the same to my nieces as she forgot her password.
Dec 28, 2012 | Tablets & eReaders
Tablets & eReaders Logo
54 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
