Question about Whirlpool Washing Machines
My Whirlpool washing machine died after 15 years. I pulled out out the thing to start the wash and nothing happened. Is it advisable to repair the machine? This is the first time in the 15 years th
The model is Ultimate Care II washer 33932/7.
  • Whirlpool Master
  • 1,150 Answers
Hi Christine
Wow... Nice going. You must be taking care of it to last that long without a fault. If it is in good condition I would have someone look at it. Might be a simple repair like a wire vibrated off / fuse / cord etc.
I know we are in a throw away world but....
Weigh up the cost of opening the back for a look vs calling a tech and cost of a new water saving whiz.
Good Luck
Posted on Nov 27, 2014
  • 262 Answers
SOURCE: Whirlpool Ultimate Care II washing maching but will not spin.
lid switch is bad chance are you can by pass this by removing the timer header and crossing the outer wire on the lid switch that it mounted closest to the lid not the power cord this will tell you if you need a switch
Posted on Dec 03, 2007
  • 1314 Answers
SOURCE: whirlpool ultimate care II topload washing machine
Well I'm going to do my best to fix your washer. First unplug the washer and turn off the water. If you have a shop vac take the drain hose out of the drain,and through the drain hose vacuum the water out of your washer. If you don't have a shop vac go to the auto parts store and buy a pair of radiator hose clamps . Then facing the washer locate the two screws. They will either be in the front or rear of the control panel and back them out far as you can. Once you have done that pull the control panel slightly forward, and tilt it back on the hinges. Now unplug the lid switch wire but don't forget to plug it back when your done. Next locate at the rear of the washer body the two gold clips then push forward, and take careful note of how they fit. Then pop them out with a screw driver tilt the washer body forward at 45 degree angel and walk forward with the body, and set it down. Now you will see the white pump and motor assembly. You should see two clips holding the pump to the motor pop them off, and pull the pump off the motor shaft. Now if you fell the need to remove the pump use the radiator hose clamp. take them and clamp the hose coming from the tub but its not necessary for the repair. Next disconnect the wiring harness from the motor (note the position of the harness for reassembly). Remove the two 5/16 inch screws from the motor clamps and pop the clamps off. Once that is complete, remove the motor put the new coupling on the motor and transmission shaft. I use a socket and a hammer
Posted on Jan 26, 2008
mikedurland
  • 481 Answers
SOURCE: Ultimate Care II - Rinse Cycle does not start
sounds like a lid switch problem. is there a clicking noise when you open and close the lid?
if not then the lid switch may need to be replaced; inexpensive.
this could also be caused by a bad timer.
also try a different speed for the rinse cycle, it may be a bad motor and it is not going into a certain speed. instead of gentle or slow speed try fast or normal, something like that.
Posted on Jun 28, 2008
  • 1028 Answers
SOURCE: Whirlpool Ultimate Care II, model LSQ9010KQ0
lid switch lift lid and listen for click when lid shuts.. believe switch on rear left just behind lid hinge or on older models right side about half way opening (ck for boken lever or screw holes)also hinge may not be fully contacting switch ckd hinge screws just in case first if too much play in hinge will fail to contact switch..switch may be acessed by removing screws in bottom rear corners on back of console and lifting console
Posted on Jul 30, 2008
washdryman
  • 154 Answers
SOURCE: Upper agitator on Whirlpool Ultimate Care II washer
replace agitator "dogs"
Posted on Mar 01, 2010
Hi I am using Whirlpool 650d model washing machine. Today while the machine was washing, suddenly the front panel was switching off and switching on by itself. This happened many times and then it went off...
Visit the link for your Washing Machine Problem hhttp://ameriproappliancerepair.com/washer-repair-los-angeles.html,it guide regarding your problem otherwise contact with me or meet with me.
Contact No. : (800) 657-0765 ,
Address : AmeriPro appliance repair services ,9461 Charleville Blvd, 365, Beverly Hills, CA 90212
Aug 17, 2011 | Whirlpool Washing Machines
Tip
Washing Machine Motor Coupling Repair
How do you tell if your washer motor coupler has gone bad? Motor couplers are used on "Whirlpool" direct-drive washing machines. In some Whirlpool or Whirlpool-made washing machines, the motor coupler connects the drive motor to the transmission. It operates under extreme conditions and stress. Mostly during start-up and stopping of the motor. The main symptom of a bad motor coupler in the Whirlpool made washing machines is that there is no agitation or spinning action, along with the sound of the motor running. Since the motor is running, but there is no connection to the transmission, the machine will not agitate or spin the clothes out. The motor will simply run, but nothing else happens. In this case, the coupler is most likely cracked. To replace the coupler in the Whirlpool made washer, you must first unplug the washer, remove the top console by either removing the screws or using a putty knife to unsnap the top clips, rotate the console back, pull the washer front off by tilting back,and set the cabinet aside. Remove the clips holding the pump and motor on. Remove the bolts holding the motor on. Inspect the coupler and replace with a coupler if necessary. Re-assemble the motor and pump assembly. Re-assemble the washer in reverse order of disassembly. Plug in and test by running the washer through it's paces.Here is a video on repairing the motor coupler.
on Oct 18, 2011 | Whirlpool Washing Machines
My washer went through the wash cycle and into the rinse cycle and just stopped at the drain/spin part. When I pull the knob on there is a buzzing noise for about 10 to 15 seconds and then nothing. I...
I would call a local appliance store that sells and does repairs. Explain what's happening. They will probably be able to tell you if it needs service, and what type of problem it has.
Feb 11, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Power is on, still will not start
Too many clothes
washer door not opened between washes
low power/extention cord
kinked hose
Door not shut tightly
hoses connected backwards
inlet screens clogged
circuit breaker tripped
unbalanced load
excessive suds
wrong detergent
Repair Manual
Jan 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Wash cycle does not start!
if only rinse cycle work. it mean the cycle timer in no good. you need to replace it. i will tell you the cost of it later.
Feb 05, 2008 | Whirlpool LTE5243D Top Load Stacked...
Washer will fill but won't "wash"
what kind of click are you hearing like a timer advancing or a hum them a click about every 10 minutes and dont rate me yet till were done
Jan 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Calypso - Will not start
You ever hear of dog years? Well Calypso follows those same guidelines. So your machine is 35 years old. These are the Edsel's of washing machine fame. I had a Calypso for 6 1/2 years. 3 pumps, numerous circuit boards, drive motors, phone calls and arguements with Whirlpool, along with machine downtime. I finally junked it and bought a Whirlpool Duet 9200 HT (get the made in Germany machine). A world of difference in wash quality. Fresh smelling unballed clean clothes. The Calypso was removed from the market and the subject of a class action lawsuit. Just Google it and start reading. Get comfortable first. There's a lot to read.
Nov 06, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
29 people viewed this question
Dan Webster
Dan Webster
Sal De
