Question about Ricoh Corp Aficio GX7000 GelSprinter Print Cart
I am getting ink spots on the images printed from a Ricoh Afficio GX7000. Spots are in 2 lines on the same place in each picture
Printing blank pages
    Top Expert:
  • Ricoh Master
  • 74,666 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Nov 27, 2014
How do I stop printing blue spots : (
the print head is at fault .The instruction manual will tell you the way to clean it .If all else fails remove the head flush with warm water till it runs clear of ink . obtain some Windex glass cleaner ,place head in a bowl cover with cleaner leave over night then flush and dry ,it has worked for me worth a try.
Jul 11, 2014 | Kodak EasyShare Photo Printer 500
Ricoh gx7000 error code 993
This signal is triggered by the HVPS due to an accumulation of
condensation or ink spillage onto the transport belt.
?? Clean the transport belt.
Feb 28, 2014 | Ricoh Corp Aficio GX7000 GelSprinter Print...
Ink spots on envelopes
Hi rebecca,
Go To Below official Hp Printer Forum Page For Your problem And Solve Your Problem Black ink stains envelopes when printing HP Support Forum 955951
Feb 24, 2014 | Canon PIXMA MX340 Wireless Office...
I have a ricoh gx 7000 used for sublimation. Everytime I turn it on, I get a "paper misfeed" message. HELP!!
Dear .
Paper miss feed error indicates to :
1- Piece of paper inside duplexer unit check out from the back side..
2- magnetic strip (encoding tape on the top of linear steel bar) is dirty or it has some ink spots
use alcohol & cotton pass along the strip from the 2 side.
Note turn your machine off and un-plug the power
To clean behinde the head area you should first turn the machine on, when the head move to the left side unplug the power cable
I hope it may help
Yasir Risay
Aug 20, 2011 | Ricoh A3 Gel GX7000 InkJet Printer
I just purchased the Ricoh GX7000 for sublimation. Unfortunately, my son set up the printer and did not realize the inks that come with it are not to be installed. He did. I have not printed anything, but...
I would call your vendor. Or if you bought the sawgrass technologies ink, give tech support a call and have them help you download the necessary ICC profile for your printer. Often they can walk you through setup. You will need to delete the current one you son installed.
Narri
Nov 04, 2010 | Ricoh A3 Gel GX7000 InkJet Printer
Power Outage
Unfort don't have a solution but curious as to the ink you were using. Were you using OEM inks or dye sublimation ink from like Sawgrass ?
Jul 27, 2010 | Ricoh A3 Gel GX7000 InkJet Printer
Spots on master
THE DRUM THAT MAKE THE COPIES IS DURTY OR HAS DRYED INK ON IT AND IT TAKES A SPECAL CLEANER, I CAN NOT EVEN SAY THE WORD OR EVEN SPELL IT FOR YOU
TRI ETHI LINE, CALL A COPY MACHINE COMPANY OF GO ON LINE TYPE IN MANIFACTURE NAME ONLY RETURN ,
THE CORRONA WIRES THAT MAKE THE ELECTRO STATIC IMAGING MAY ALSO NEED TO BE CLEANS, Q-TIP AND ALCOLHAL WITH A VERY SOFT HAND OR YOU WILL BRAKE THE WIRE AND THAN YOU WILL BE WITHOUT A COPIER
CANDYMANGANDY
Jan 29, 2009 | Riso RZ310 Duplicator
My printer now only prints blank pages.
try wiping the contacts (gold colored spots) with a tissue, and after wipe the ink despensing end.
Dec 03, 2008 | Lexmark Z600 InkJet Printer
Getting spots on photos
I pulled out the cartridge that was causing the spots, dabbed at the small pool of ink that collected with a very soft paper towel, re-cleaned the print heads and that seemed to solve it...
Jul 11, 2008 | Epson Stylus 1400 InkJet Photo Printer
Spots when printing
It sounds to me like you may have 2 low or defective toners, the Cyan and the Magenta. If you have another machine like this available to you try swapping these 2 toners out to test the theory or you can take these 2 toners out and spin the drum manually (by only touching the gear) checking to see if the spots you see on the pages correspond on the applicator roll of the toners...
May 09, 2008 | Lexmark C524 Laser Printer
Ricoh Corp Aficio GX7000 GelSprinter Print Cart Logo
116 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
